Go to Post GP is a measurement that can only apply to yourself. To apply it to another is unfair to that person/group. - Andrew Schreiber [more]
Unread 07-03-2004, 12:38
pryoplasm's Avatar
pryoplasm pryoplasm is offline
Pit Crew/Electrical
AKA: Russ
#0069
pryoplasm can only hope to improve
need some help with the OI, and wiring a display
most likely a light of some sort, i know the programmers can probably do something along the lines of this, maybe a simple printf statement, but i was wondering what kind of device should be used, and how to connect it to the OI?
any help will be gladly appreciated
Cut these eyes, but I will see,
Kiss these lying lips for me,
Stroke this skin, and I will kneel,
Brutalize me, I will heal...
-KMFDM
Unread 07-03-2004, 16:57
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
Re: need some help with the OI, and wiring a display
You have a few choices, all with different difficulties.
You can't printf anything to the OI, the hardware doesn't support this. You can use the LEDs in the OI if you want though, have your programmers look in the ifi_aliases.h file for controlling those, I don't know off hand what the variable names are.
The other option is to make a dashboard program. If you have any C++ or Flash MX gurus, it'll be pretty easy, I made a program that you can use with a few additions on your part. Look here for that.
If you can, please be a bit more specific on what you're trying to do, it helps us help you .
AIM --> Woloi
Email --> ian@woloschin.com
Unread 08-03-2004, 00:06
pryoplasm's Avatar
Pit Crew/Electrical
AKA: Russ
#0069
well, its not necessary, but something nice that i thought up for one of the drivers. in practice during the 6 weeks of hell (an affecionate name i assure you) she was able to listen to the compressor that creates a vacuum (which uses the helicopter theroy of engineering, where if you can't make it silent, then make it loud as hell) and was able to know whether or not the compressor was on or not.
in short, whenever the compressor is on, i want it to have a light or something go on at the drivers station.
thanks for listening
-KMFDM
Unread 08-03-2004, 00:26
KevinB's Avatar
KevinB KevinB is offline
AKA: Alum
That would be easy. IFI's website has information on how to wire LEDs to the Operator Interface and you can search ChiefDelphi for information on how to program them.
Unread 08-03-2004, 09:25
College? What?
No problem, this should be pretty easy, I had a similar problem two years ago and came up with a easy answer.
Know those LEDs right on the OI? Those are controlled by two bytes, led_byte1 and led_byte2, that are broken up into their bits. I'm not sure off the top of my head what the bits are called, but look it up in ifi_aliases.h, I seem to remember it being fairly obvious what the variables were for.
Once you find those variables, drop something like this into the code that controls you compressor (I'm writing pseudo-code, don't copy and paste )...
 if compressor is on:
    led_1 = 1;
 else:
    led_1 = 0;
That way, when your compressor turns on (I'm assuming by the pressure switches), an LED on the OI comes on, when the compressor turns off, the LED turns off.
I'd write more, but I've got to run to my next class now, hopefully this is helpful, otherwise I'll check back this afternoon if you need more help .
AIM --> Woloi
Unread 08-03-2004, 09:34
Greg McCoy's Avatar
Greg McCoy Greg McCoy is offline
boiler up!
FRC #3940 (CyberTooth)
Greg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond repute
Send a message via AIM to Greg McCoy
We use our "user byte" selectable in the little display on the OI to show the pressure from the sensor, nicely converted to PSI in the software. We also have a telemetry select switch on our OI that lets us select different data (the pressure, arm sensor positions) to send to the user byte...another simple solution...
Unread 08-03-2004, 23:38
pryoplasm's Avatar
Pit Crew/Electrical
AKA: Russ
#0069
for our compressor, its for a vacuum, so psi isnt that hard, thanks for the info, and i talked to one of our programmers, and he should be able to spit something up by the next regional
thanks everyone
-KMFDM
Unread 09-03-2004, 00:10
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
just take a look in the default code - down at the bottom of Default_Routine there's code the sets the state of the LEDs on the OI - play around with that to your hearts content.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 10-03-2004, 20:46
pryoplasm's Avatar
Pit Crew/Electrical
AKA: Russ
#0069
well, i dont have a problem with the programming, but more of not having the interface in front of me, so i dont know where to place something. also, i found out i can use the RS232 port for output on the OI, but it needs its own power source, and i am worried of toasting the OI with too much ampage...
-KMFDM
