Go to Post In engineering, it's important to use the appropriate tools and not more resources than are required. - AdamHeard [more]
Unread 09-03-2004, 10:22
10intheCrunch's Avatar
10intheCrunch 10intheCrunch is offline
Who's John V-Neun?
AKA: Alex Baxter
None #0254 (Cheesy Poofs)
10intheCrunch is a jewel in the rough10intheCrunch is a jewel in the rough10intheCrunch is a jewel in the rough10intheCrunch is a jewel in the rough
Send a message via AIM to 10intheCrunch
Re: Do you write functions for your code?
We have a few more... =)
This list I can recall atm: 254_arm, 254_auton, 254_drive, 254_encoders, 254_utilities, 254_interrupts, 254_timers, 254_recordable (recordable autonomous, work in progress)...hmmm, I think that's it, might be one more somewhere.
We're also working on breaking our pump and gear shifting code to functions for ease of use in autonomous mode.
~Alex Baxter
Programming, Arms operation, Team 254
Unread 09-03-2004, 13:38
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Originally Posted by KenWittlief
actaully, the SW we are creating for these machines is realtime embedded code
remember that the C compiler will convert your code into assembly code, and from that into machine code
breaking your code up into many little functions makes it look nice, but it actually takes longer for it to run, and takes up more code space, because the function calls are actully jumps in assembly code
its shorter and faster to have sequential code all in one routine that simply falls through to the next statement.
not that we really have to be concerned with optimizing our code for size or speed.
well wait, I have seen some people posting that they have used up all the available code space this year - so maybe some of us got a little carried away with the functions :^)
Im not sure, but don't good compilers make using functions not so ineffecient? If not, can't you just use inline to get the same effect as not using functions?
Team 1257
Unread 09-03-2004, 13:57
velocipenguin velocipenguin is offline
#0246 (Overclocked)
velocipenguin is on a distinguished road
Send a message via AIM to velocipenguin
I would have suffered greatly if not for the ability to divide everything into functions this year. Even if some of them are only called once, they still make it much easier to keep code organized, readable, and easy to debug. Our (failed) autonomous code has about 8 separate functions, each of which contains 20-30 lines of code. Trying to keep all that organized within Process_Data_From_Local_IO() would have been a nightmare, but dividing all of it into separate functions made coding a breeze. Sure, it might take another CPU cycle or two to jump to the appropriate memory location, but that's not much of a problem when the thing's running at 40 MHz.
Unread 09-03-2004, 14:14
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Cool Re: Do you write functions for your code?
I did a lot of the stuff your taliking about. I'll post some of my hardware-driver code. (don't have it on me) It includes #defines for every motor, victor, spike, pot, and whatnot. And to top it of, to move the shoulder to a certain position, you call Shoulder_Check(Target). It also includes macros to scale (and translate) the analogs.
Unread 09-03-2004, 19:34
SeanCassidy's Avatar
SeanCassidy SeanCassidy is offline
Antiregistered User
#0263 (Aftershock)
SeanCassidy is an unknown quantity at this point
I used many functions, many just like:
#define square(a) a*a
And also a nice function to turn based on degrees you want to turn. Kickin'.
Unread 09-03-2004, 19:42
dont get me wrong- there is nothing wrong with using functions for your code on this project - I was only pointing out in a reply to a post on the 1st page that using functions is not more effecient from a performance perspective, and if the function is only called from one place in your code, its takes up more code space after being compiled than simply putting the same code inline.
there is a balance somewhere, between breaking up every 3 or 4 lines of code into a separate function, and writing one long monolithic block of SW with no functions.
Unread 09-03-2004, 20:01
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Functions? We wrote a whole math library worth of functions! Actually, it was the other programmer who did, not me, because he actually can understand CORDIC.
Otherwise, we only used functions in such situations where they would be called in more than one different place, such as our joystick auto-calibration function.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 09-03-2004, 20:09
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
you mind sharing some math libs? a bunch of people are looking for some good ones, if you dont want to write a white paper i could.
"You're not a real programmer until all your sentences end with semicolons;"
Unread 09-03-2004, 20:41
If I get my CORDIC implementation functional, I'll put it somewhere for others to read. In the meantime, maybe your "other programmer" would like to post his work?
Unread 09-03-2004, 21:31
Circuit Breaker
We should be posting a white paper containing our math library in the next week EDIT: day or so, keep an eye out for it. It should be good enough for any team's use; I believe we managed to get our CORDIC trig functions accurate to within 6 decimal places.
Patrick Fairbank
patfairbank.com
Unread 10-03-2004, 07:34
AKA: Jamie Bliss
Here's SOME of my code.
Unread 11-03-2004, 07:04
Circuit Breaker
You can now find 296's math library here.
Patrick Fairbank
patfairbank.com
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
Interrupt timer, executing code asap? SeanCassidy Programming 10 07-03-2004 01:47
RC bootup sequence Venkatesh Programming 17 18-11-2003 20:56
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
