Go to Post 1) Field reset will want to do mean things to you. They have to remove the tubes. - EricH [more]
Unread 09-03-2004, 19:15
FRC #0701 (RoboVikes)
Question Wierd gyro code problems...pls help
Hi, i've coded a VERY simple code for a gyro ..... the gyro outputs 10bits so i shifted 2....but now the gyro stays at 135 even when not moving or being shaked etc... I can't figure out the problem...the gyro is working (we monitored voltage)
can you please read the code and help thank you
gyro1=rc_ana_in01;
2<<gyro1;
if(gyro1>136)
heading++;
if(gyro1<119)
heading=heading-1;
if(mode==1)
if(heading<turn+error)
pwm01=184;
pwm02=70;
if(heading>turn-error)   //error is a tolerance!!!! i set it to 400
pwm01=70;
pwm02=184;
Thank You
Salik Syed Team 701
btw we are using the BEI gyro from 2k3 (we know...its not allowed...we'll get another gyro soon)
Team 701
Unread 09-03-2004, 19:23
Re: Wierd gyro code problems...pls help
you cant equate the gyro to the analog input - you have to use the Get_Analog_Value() function like this:
gyro1 = Get_Analog_Value( rc_ana_in01);
its detailed in the 2004 Programming Reference Manual from innovationfirst.com - page 16
and if you want to shift it down to 8 bits its the other way
gyro1 = gyro1>>2;
You will find your answer on page 16 of the 2004 Programming Reference guide, or in several other threads here on chiefdelphi.
edit: Ken beat me by seconds
Unread 09-03-2004, 21:24
haha ......lol i'm a noob.......thanx both of you
one more question........you know how it says : gyro1=>>gyro1 (or whatever) ..... will it shift every time the cycle loops.....like one loop it is 8 bit then 6 then 4????I hope not!....we have the shift in our program loop (outside of initilization) because we have to shift it after making it equal to the analog ....is that correct?
Team 701
Unread 14-03-2004, 01:29
only if you stop reading it in with the Get_analog statement in each loop.
if you put shift right (gyro>>2) statements after each other, then yes, each statement will shift it right another two places
but in your code Im sure you are reading in new data on each loop, the old data is overwritten, so the new data is whats getting shifted.
IR reflective (tape) sensor code problems Argoth Programming 8 07-02-2004 21:32
problems assigning unsigned chars in FRC Code LoyolaCubs Programming 6 26-01-2004 23:21
ADC problems with C library and new code Larry Barello Programming 1 09-01-2004 22:31
gyro code odin892 Programming 2 08-04-2003 14:50
[white paper] Auto-Balance Gyro Code Brandon Martus Technical Discussion 3 21-06-2001 10:36
