Go to Post Brainstorming and creativity are great, but you do actually have to build the ideas you come up with sometime. - Chris is me [more]
Unread 09-03-2004, 14:21
FRC #0701 (RoboVikes)
Wierd error (With edu bot ...
Okay i am using the Edu robot controller when i program and run it it seems the program is not looping or something the wheels keep moving forever and there is no Message like IFI user process initialized...i tried printf in stuff and nothing shows up in the IFI COM window
any help appreciated
thanx
Salik
Team 701
Unread 09-03-2004, 14:24
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Wierd error (With edu bot ...
Are you using the headers made for the EDU? there is a diference.
In txdata (defined in main.c), set the user_byteX to an output. It shows up in dashboard. (txdata.user_byte3 = 123)
Unread 09-03-2004, 14:28
The Lucas's Avatar
CaMOElot, it is a silly place
Are you using a custom code or the default code? If you are using a custom code then you probably have an initialization problem (please post some code). Try to load the EDU default code. If you can't get the default code working then talk to Innovation First, because it is most likely a hardware failure.
Robot Inspector
Unread 09-03-2004, 14:41
Was there a point at which it did work that you can back off to, or is this your first cut at testing some of your FRC code on the EDU?
Are you trying to run all your FRC code or just selected functions like autonomous?
Any warning lights on the EDU controller?
Using the proper EDU compiler flags, e.g., not _FRC_BOARD?
Unread 09-03-2004, 21:34
We were running the WRRF code (Its the western regional robotics forums or something like that...) but we switched to FRC ... now it works
Team 701
worst experience mike pawlak Chit-Chat 15 06-12-2004 07:04
Help! My 2003 Bot compressor won't shut off Jack21 Control System 10 11-02-2004 12:24
Team 1072 (Harker Robotics Team)'s bot: Tork AlbertW Robot Showcase 8 19-02-2003 13:19
what did people think of my teams bot this year (263) Rob Colatutto General Forum 8 22-05-2002 19:03
Multiple Regional Winners and a little jab JamesJones General Forum 32 10-04-2002 23:38
