Go to Post PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part. - dlavery [more]
Unread 09-03-2004, 21:39
Re: Where can I buy Gyros that fit requirments?
the gyro chip itself is a tiny little thing, about a 1/4 inch square, and its a ball grid array device (BGA) - instead of pins it has a matrix of solder balls on the bottom that melt down onto a grid of pads when assembled onto a printed circuit board
thats why we advised everyone to get the EB version - its the gyro chip already mounted on a small printed circuit board, the size of a 20 pin DIP package if Im not mistaken, and it already has decoupling and filter caps on it
you could mount it on some of the protoboard they gave us in the KOP - the stuff you used to make the beacons - cut a piece big enough to put mounting screws through with the EB device in the center - attach the three wires (I think you have to connect power to two pins)
and you will be ready to fasten it to you bot.
We put ours in a black plastice 1x2x4" project box from radio shack, just to protect it.
BTW - you need to mount the board/box solidly to your robot frame - it cant be just hanging loose, or even on tape -you want a solid mechanical connection to the frame so the sensor moves exactly the same as the frame moves.
Unread 10-03-2004, 10:21
Re: EB is the only way to go.
Like Ken said, it isn't difficult.
You'll be attaching 5 wires total to the chip. Several of them combine, so you end up with three wires going to the RC.
pins 8 & 12 = Ground
pins 1 & 13 = +5v
pin 2 = signal
Where to buy Balls? Bduggan04 Kit & Additional Hardware 61 28-01-2004 05:21
where to buy treads? illumanat'i Technical Discussion 11 11-01-2004 22:05
FIRST FYI: Best Buy Children's Foundation Grants Rich Wong FIRST E-Mail Blast Archive 16 01-12-2003 20:57
Sing me a SONG! Biggs717 Chit-Chat 78 09-05-2003 07:59
help! team 497 needs bearings (or info on where to buy) Andrew Dahl General Forum 1 21-01-2003 17:49
