Go to Post Is it really that bad to ask a team to be able to do more than just drive? It's like asking a student to do more than just show up to class... - Katie_UPS [more]
Unread 08-03-2004, 17:15
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Thunder Chickens CVT?
Someone mentioned that "The Thunderchickens" had a CVT (in this thread ). Anyone know anything about this? It's an interesting idea and I'd be curious to know how they pulled it off. There are a lot of different ways to do a CVT, and I'm impressed that someone pulled it off.
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 08-03-2004, 17:24
Joel Glidden's Avatar
Joel Glidden Joel Glidden is offline
My heart pumps diesel.
FRC #4293 (Komodo)
Joel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of light
Re: Thunder Chickens CVT?
Here's the White Paper.
-Joel
Unread 08-03-2004, 17:31
matt111 matt111 is offline
#1024 (McKenzie Kilabytes)
matt111 will become famous soon enough
its patent..so...we cant use it?
Unread 08-03-2004, 17:34
Eric Bareiss's Avatar
Eric Bareiss Eric Bareiss is offline
It's a Bird
AKA: BoogyShoes
FRC #1492 (Team Caution)
Eric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of light
Send a message via AIM to Eric Bareiss
Other teams have used a CVT in years past. Team 64 had one last year. They had trouble getting it working. I have no Idea how it worked something about planetary gearsets, I never really got to see it.
Here's a pic: 64's 2003 CVT
Unread 08-03-2004, 17:42
phrontist's Avatar
Proto-Engineer
This isn't really a CVT , although I must admit it's interesting. It seems as though this design is far too complicated a heavy to be worthwhile. I was thinking about something like this:
http://www.gizmology.net/images/cvt5.gif
Just as the disk CVT evolved into the cone CVT, the toroidal CVT has evolved toward a cone-shape as well. The result is a much more compact transmission. This type is peculiar in that the speed ratio may be controlled by directly rotating the wheels, or by moving them slightly up or down, causing them to rotate and change the speed ratio on their own. - Taken from http://www.gizmology.net/
Has that ever been done before in FIRST?
More importantly, is there a good reason it hasn't been done?
Unread 08-03-2004, 18:08
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Team 190 did this a couple or three years ago. As I recall it worked pretty well. You'll have to ask them why they haven't used it since.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 08-03-2004, 18:48
Swan217's Avatar
Swan217 Swan217 is offline
RoboShow Producer
AKA: DJ Royal Fusion
no team (RoboShow)
Swan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond reputeSwan217 has a reputation beyond repute
Send a message via AIM to Swan217
It says in the white paper that we ask that you mention credit to us if you base your transmission off of it. One team used our CVT last year and got a design award for it, even though they didn't design it - we did.
Basically, you can use it, just don't say that you invented it
Orlando Regional Planning Committee & Cohost of The RoboShow & RoboVision
Follow The RoboShow on Twitter @RoboShowLive & check out our website, www.theroboshow.net
Follow RoboVision on Twitter @RoboVisionOD & check out our website, www.robovisionod.com
"As president, I believe that robotics can inspire young people to pursue science and engineering. And I also want to keep an eye on those robots in case they try anything."
— President Barack Obama
Unread 11-03-2004, 01:45
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
The thunderchickens planetary CCT inspired us (701) to build a simplified version of one this year and from the little testing we have done it seems to work very well. I absolutely credit Team 217 for inspiring our design - but it is different from theirs. Our planetary transmission is not really a CVT, just as the thunderchickens transmission isn't a true CVT either, it's closer to being a two speed transmission that doesn't require any mechanical shifter. Basically, we use the CIM as our sun and the drill drives an external ring gear which is connected to an internal ring gear. The planetaries (output) rotate between the sun and internal ring gear. Thunderchickens (as explained in their white paper by Paul C.) use the drill and FP motor driving a worm gear on their external gear. This was to prevent backdriving of the motors when the output is stalled. We are able to overcome the backdriving effect by gearing down both the CIM and the Drill motor to the almost the same output torque. We thought this would be much simpler than incorporating a worm gear system. Since it is next to impossible to perfectly match them up we compensate for backdriving by using the current sensor to monitor the CIM current. As it begins to spike, we reduce the power to the Drill motor. Important Note: we are a small outfit that had to machine many of the parts ourselves on a mill / lathe that we got just after kickoff - thus we didn't finish it until Feb. 20!! There is so much more testing we need to do - but we did test it briefly and it supplied a high torque and low speed when the sun and external gear were moving opposite of each other and low torque and high speed when moving in the same direction (an effect the Thunderchickens CCT doesn't provide according to Paul C. - I'm still confused as to why...). We were able to manually adjust the backdiving effect and sure enough were able to stall both motors together. The one part of the system that was never finished was the programming of the current sensors - we'll give it a shot at competition and see what happens - but we are very pleased with the results so far. And it required very little machining (housing is probably the hardest part!). We'll provide more info after the Sacto Regional. Regarding the Thunderchickens patent pending design.... If we are presented an award solely on the planetary design - we would not except it. If we are presented an award for the overall drive / control system, we would graciously except it. I would very much like some feedback on this sensitive issue from the CD community.
Unread 11-03-2004, 06:42
Swan217's Avatar
RoboShow Producer
no team (RoboShow)
Good job! It sounds like you put a lot of effort into this. I hope it works great, and hopefully I'll get to see it at the Nationals.
Unread 11-03-2004, 20:28
FRC #0701 (RoboVikes)
Thanks.........haha......its funny we designed it a while before comp. got our mill a week into competition.....spent a while learning to use it ....then around Feb. 20 we finally got it working and man.........it is even faster then our calculations...we're pretty happy for it...
btw.. unfortunately we won't be at Nats but hopefully if we win a regional or something we could get some $dollars$ and make it ....kind of a long shot tho
Team 701
pic: T3 Controlls (team 68 truck town thunder) CD47-Bot Robot Showcase 37 02-03-2004 00:24
Probots, thunder chickens, robodawgs edomus Thanks and/or Congrats 15 30-03-2003 01:08
Team 980 Thunder Bot's "Jaws" David Brinza Robot Showcase 4 25-02-2003 00:38
Thunder Chicken CCT Simon G Motors 4 03-01-2003 13:18
Everyone's counting their chickens... archiver 1999 0 23-06-2002 22:17
