Go to Post If it's not on fire, it's a software problem. - Matt Leese [more]
Unread 11-03-2004, 09:17
dddriveman's Avatar
dddriveman dddriveman is offline
Former Driver 1038, 979
AKA: Driveman
FRC #1038 (Thunderhawks)
dddriveman has a spectacular aura aboutdddriveman has a spectacular aura about
Send a message via AIM to dddriveman
Unhappy Making .Hex files
We have our autonomous code the way we want it now we just need to make it into a .hex file. We are using MP Lab IDE and we cannot figure out how to turn it into a .hex file. I believe we got the code form kevin.org i am not sure but it is the navigate code and the tracker code. we modified it slighty and now we want to load it into the robot but we cannot make the .c file into a .hex file. Also do we need to load the default and other codes into it in order to use it in compeetition. Please help
"I'm sorry, after all he is just a wookie!"
Unread 11-03-2004, 09:20
CrashZero's Avatar
CrashZero CrashZero is offline
Computer Nerd
#1352 (Huskie Robotics)
CrashZero will become famous soon enoughCrashZero will become famous soon enough
Wink Re: Making .Hex files
Go to the Project menu and click on "build all"
Unread 11-03-2004, 09:22
also, make sure you are loading the project into mplab and not just the .c source file
Unread 11-03-2004, 09:28
CrashZero's Avatar
Computer Nerd
Lightbulb Re: Making .Hex files
Also when you download it make sure that it is the one that you want to download. The one that you make will have the name of the workspace as a .HEX as opposed to a .MCW
Unread 11-03-2004, 13:47
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
If hitting F10, Build all, etc. causes an error or doesn't build it right, make sure the mcc18 compiler is installed right.
Wiring Diagram for making a Joystick Nick Fury Control System 0 10-02-2004 23:10
**IMPORTANT FIRST EMAIL**/DXF files posted on FIRST website miketwalker FIRST E-Mail Blast Archive 0 19-01-2004 19:53
tga files for animation LizJJury General Forum 1 15-02-2003 16:36
VKOP igs files JeffO Inventor 0 15-01-2003 20:37
Multiple files usage punarhero Programming 2 12-01-2003 11:45
