Go to Post Nuts for breakfast!!! Thats just screwy!!! I guess you could just bolt it down..... - Wayne C. [more]
Unread 07-03-2002, 15:39
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Battery Flip-Flop...
I have heard that at the VCU regional, the officials are claiming only this year's batteries are legal -- not the ones from last year as was officially allowed via the Yahoo! board:
From Message #851
> Can we use different brand batteries other than exide?
A) The only batteries you can use on the robot are the exide
battery from this year's kit of parts or the Yuasa battery from last
year's kit.
From Messsage #661
> 2. Will batteries from previous years be allowed during the
> competitions? (assuming only one battery in system)
We have decided to allow Yuasa/Exide batteries from the 2001 competition to be
used, but not the green CSB or other batteries from prior years.
I have also heard that questions about chargers are also being raised, specifically, only the EXACT make and model that teams got this year are being allowed. If so, this conflicts with another Yahoo! message:
From Message #784
> Frcengineers:
> Rule C20 states that only the battery charger supplied or one with
equivalent
> specifications may be used.
> The charger manual indicates an output of 1 Amp hour, less than the
battery's
> capacity. We have some level of concern that this may be inadequate
for
> recharging during a match.
> Is it legitimate to use a charger of our own as long as its' output
does not
> exceed
> battery specifications? [For example, we have a charger that can
output 2 Ah
> in trickle charge mode or 10 Ah in quick charge mode.]
A) You may not use that charger. See rule C20. You may use another
charger that does not exceed the specifications of this years charger.
Please note that teams will be allowed to recharge their batteries in
the Pits overnight.
I hope that all this gets worked out before the competition starts tomorrow. We can easily suck a battery down to its dregs in 2 matches. If we have to get EXACTLY the battery that we got this year (i.e. not the Yuasa's we used last year and have several spares of as well), we had better order them NOW or we will not have enough batteries to get through the seeding rounds, yet alone the Elimination Rounds, which we hope to be in...
I hope that clearer heads prevail.
Joe J.
Unread 07-03-2002, 19:00
Matt Reiland's Avatar
'The' drive behind the drive
Thumbs down I can only hope too
If we can only use 2 batteries and the charger that came with this years kit, we are sunk. I still can't figure out why the chargers from last year are banned?! We have 4 or 5 of them now and only one wimpy one from this year. If this ruling holds up we will be fed-exing more of the winpy ones and some more of this years battery type, what a TOTAL waste of our time and money.
I hope they come to their senses also
Unread 07-03-2002, 19:36
Andrew Dahl's Avatar
Andrew Dahl Andrew Dahl is offline
#0497 (Orange Crush)
Andrew Dahl is an unknown quantity at this point
we had our chager go belly up on us so unless we get an excat replacemtn will be be dead in the water by our fourth match
- they will not let us use last years chargers at all
dahl
2002 VCU Regional winner of the GM Industrial Design award
whooot!
Unread 07-03-2002, 22:17
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Re: Battery Flip-Flop...
Joe J.
This is just great. (not)
We have looked for the past two weeks to find the exact same Exide model of charger, but we finally gave up. I found a pretty cheap charger (@ $18 each) that is the same strength, but from a different manufacturer... and we bought 6.
Sure, we couldn't use 6 if we had to, but I bet that we'll make friends if these are still legal.
We have also been going off of the rulings and notes from FIRST... it is way out of line for them to go against something that they allowed previously. If this happens I may just send FIRST the bill for our 6 chargers.
I'm assuming that this will be turned around and they will make sense of this... in time they usually make the right decision.
Andy B.
Unread 07-03-2002, 22:19
Kris Verdeyen's Avatar
Kris Verdeyen Kris Verdeyen is offline
LSR Emcee/Alamo Game Announcer
FRC #0118 (Robonauts)
Kris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond repute
Battery charger knife fight.
We have an issue with that as well. First of all, we have been trying (and failing) to find additional chargers. Does anyone know where some can be found?
I also think that the rule is foolish anyway. Has anyone given a reason for further limiting the chargers? Is it to ensure fairness to rookie teams who wouldn't have chargers from last year?
The trouble with this line of thinking is that everyone, including rookies, will have to buy more battery chargers and batteries in order to have enough power for their matches. So it's still lose-lose.
The only valid reason I could come up with is safety. If, for some reason, the less wimpy chargers were causing fires, or exploding, or threating people with knives, then that change to more wimpy chargers would be justified. But I haven't heard of any incidences of the above. (We did have a charger get ahold of an ice pick, though. - That was a mess.)
...Only a few people are awake and they live in a state of constant total amazement. -JP Shanley, Joe vs. the Volcano
Unread 07-03-2002, 22:33
Re: Battery charger knife fight.
Hmmm this is sorta like the mentality behind the Small Parts rule.
2 years ago at the Motorola Midwest Regional, one team blew up their battery by connecting the charger leads backwards... we had smoke, a few screams and scurrying people... it was kinda exciting.
Andy B.
Unread 07-03-2002, 22:37
AKA: Dr. Joe
FRC #0088 (TJ2)
Latest...
Batteries from this year and last year are allowed (and presumeably batteries that are identical to this year's and last year's).
Chargers: Only this year's chargers are allowed or ones with 1 amp capability.
This is going to be very interesting...
Joe J.
P.S. Just for grins: What does YOUR batteries from last year and this year look like? I think FIRST shipped out a variety of batteries this year and last year. FIRST even has two different pitures of batteries in this year one says, "Yuasa." The other says, "Exide." By the way, NEITHER look like our kit batteries which are Exide brand but say, "POWERLIFT" on them and have a different model number than the ones listed in the manual! Last year, our kit batteries said, "Exide" on them, but, I saw a ton of batteries that said, "Yuasa" on them being used in the pits
I suppose that ALL the batteries I have that are the right model numbers OR look like the batteries we got in our kit or look like batteries anyone else got in their kits are legal. What do others think?
These are the images in the 2002 manual -- neither look like the battery we got from the 2002 Kit, not even the model numbers match.
Unread 07-03-2002, 23:09
asher asher is offline
None #0031
asher will become famous soon enough
Due to some nasty things that happened to our team we never even saw this years batteries or charger. So if we show up and can't use last years (or any year before that) were really in deep. I hope there is an official word on this soon so we can at least get ahold some something if we have to.
asher
Unread 07-03-2002, 23:18
Kevin Ray's Avatar
Kevin Ray Kevin Ray is offline
None #0329 (Raiders)
Kevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to behold
Unhappy
Unless FIRST clears this up right now (well, yesterday), we're gonna have a whole lot of teams watching the final qualifying rounds when they're are supposed to be competing in them. This year more than any, we are using up the juice as fast as those batteries can put it out. Some teams said that they've been using up a fully charged battery in about three rounds with the loads they're drawing. This means that each team, especially those who make the finals, will have to have 4-5 batteries and the equivelant # of charges. As was said earlier in this thread, that causes EVERY team, rookie and vets alike, to buy more chargers and batteries--unnecessarily.
That especially amounts to big $$$ when we have to ship them to the nats and we will most definitely exceed the 400 lbs. allowed, thus, having to pay more money--which our team already doesn't have.
C'mon FIRST, don't leave us hanging!!!
Unread 08-03-2002, 00:38
Dima Dima is offline
Dima is just really niceDima is just really niceDima is just really niceDima is just really niceDima is just really nice
Send a message via AIM to Dima
Maybe that is what they want
Us to do is spend more money! I know this sound unreasonable but hey it could be happening that first didn't feel like spending a little extra on chargers and they found this great deal on the whipy once so they buy the whimpy once and make everyone use them
Unread 08-03-2002, 04:36
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
We had an enginner last year tape a 9.4V drill battery to the 12V battery charger to charge it faster. he let all the magic smoke out and now that battery dosn't work.
And he calls himself an EE....
Viva Olancho!
Unread 08-03-2002, 08:47
Stop the Presses! FIRST is allowing old chargers
I just got an update from VCU. Steve Shade from team 7 just gave me a call with a battery issue update. (you da man, Steve!)
FIRST is allowing the old chargers to be used. The rookie teams are being asked to go out and borrow old chargers from veteran teams. It looks like 4 amp hour chargers will be allowed.
But...
Old batteries are not being allowed. Only the batteries from 2002 are allowed.
In special cases, 2001 batteries will be allowed... these are in cases where the 2002 batteries are no longer useable (blown up) or they have been stolen, or whatever.
Just as we thought... the officials at FIRST must've gotten a good night's sleep and made a good decision.
Andy B.
Unread 08-03-2002, 08:53
AKA: Dr. Joe
FRC #0088 (TJ2)
Chargers Confirmed... ...still confused about batteries...
I have heard that last year's chargers are being allowed as well... so that makes it about as official as possible.
Concerning batteries though, do they really mean THIS YEAR's BATTERIES meaning only the batteries given out with the kit?
This is bordering on a "who's on first?" scenario!
Anyone with inside knowledge, do tell...
Joe J.
Unread 08-03-2002, 20:04
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
Who, first, FIRST, What?
Who's on first? FIRST is on first. Who's on second? Dr. Who. No, wait Dr. Joe. I'm confused; and speechless!
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Unread 08-03-2002, 20:43
combbat veteran combbat veteran is offline
#0021 (Combbat)
combbat veteran is an unknown quantity at this point
They are allowing last year's chargers to be used at a designated charging station at KSC. This years chargers may be used in the pits.
Have not seen any battery-gate at KSC. Either a lot of teams are using other year's batteries or FIRST gave teams many different types/colors. Even saw a red battery ??? Didn't look painted??
Few FIRST engineers at KSC regional this year. Most inspectors are volunteers that go by checklist alone. I expect this to be more common with more regionals meaning G. P. needs to be at an all time high.
Scott Strickland
Engineer
Team #21, ComBBAT
Quick release battery connector and 120 amps n[ate]vw Electrical 6 18-01-2003 23:41
Off-topic battery stuff. FotoPlasma Electrical 4 06-01-2003 12:19
Voltage Range of Analog Inputs Ulibrium Electrical 21 15-02-2002 14:11
connecting to the battery ahecht Technical Discussion 1 25-01-2002 17:15
