Go to Post My own opinion is that any truly great student can succeed with any teacher, and any truly great teacher can succeed with any group of students. - DampRobot [more]
Unread 10-03-2004, 20:31
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: 222 3 speed closeup/cutaway
Unread 10-03-2004, 20:36
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: pic: 222 3 speed closeup/cutaway
Sweet looking tranny. I like the idea, it's nice and simple. I'm just curious if you guys have any bearing surface between the free spinning gears and the output shaft. Is it just steel on steel with lots of lube, or is there a bronze bushing in there?
Also, how do you guys index it so that shifting rod only moves part way?
Other than that, it's a really awesome, simple idea.
Unread 10-03-2004, 20:42
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
I agree that it is a sweet tranny and an amazing idea, but is it really that simple? The concept might seem simple, but the production seems very difficult. Kudos to team 222 for doing it though.
Also, are those trannies powered only by the CIM motors?
See you in DC!
Unread 10-03-2004, 20:57
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Yes the shaft and gears are steel on steel. Both of which I think are heat treated. We also used some kind of spray on lubricant that sticks to the gears.
If you look on the other pictures there are shifting stops to keep it from shifting too far.
Since this is our first year ever building a tranny we went overboard. The production could be simplified greatly. There are lots of different things we could modify such as the side plates and the whole shifting mechanism could be redesigned!
Once I finish the inventor award (due 3/15) I hope to find time to make a white paper and redesign it!
thanks for the comments
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 10-03-2004, 21:07
tkwetzel's Avatar
Good Luck Teams!
AKA: Tyler Wetzel
I'm looking foward to seeing a white paper on this beautiful tranny.
See you in DC!
Unread 10-03-2004, 21:10
In that case, for your redesign I'd suggest a bronze bushing or some such between those free running gears and the shaft. I just got lectured by my design prof about galling, and it wasn't pretty. Apparently, two very similar metals have a tendency to stick together. Thus, if your lube ever gives out, the gears will sieze and bad things will happen. so as a corollary, check the lubrication whenever you get a chance, just in case.
Unread 10-03-2004, 21:18
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
I hate to say this because I think I am only adding fuel to the fire* but... ...I like it!
The part I like best is your method of transfering the torque via the balls. Very elegant.
Nice job.
Joe J.
*I have discussed in many posts that I question whether all this shift on the fly mania (yes, I say mania) is worth the bother when you consider that you can make a relatively robust transmission shifter with a standard drill gearbox and servo.
The only thing that has me thinking is Jim Zondag's 4 speed with automatic shifting (and I suppose your 3 speed would work about as well). Perhaps there is a game where such things make sense. I am still pretty much for simplifying things, but perhaps I was too hasty to close my mind. Time will tell...
Unread 10-03-2004, 21:23
henryBsick's Avatar
henryBsick henryBsick is offline
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
As you can somewhat tell, the word, well, name "FRED" is on the inside of the tranny. I just noticed it myself but, I believe it is there because he is NOTORIOUS for greasing, greasing, and well, greasing. We should be ok and he should have some fun this year, but thanks for the heads up.
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 11-03-2004, 08:31
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
This is certainly a nice, compact design. Reminds me of my dual range Suzuki I had in the late '70's. I have looked at how to easily do the machining and am very interested in seeing your white paper.
As for the lube. We are lucky that we run short matches and that the total life of our robots is measured in hours. Greasing on a regular basis allows us to run on the edge with our designs. I do agree with Kevin's professor provided this was on production equipment. The Suzuki I had (actually I still have the motor and gearbox) was steel on steel but ran in an oil bath.
Andy Brockway
Team 716, The Who'sCTEKS
Unread 11-03-2004, 11:47
Speaking of Kevin....
I just had a test today in that class, and it reminded me that the issue is worst if the metals are of the same or similar composition, same hardness, and relatively low hardness. The threshold for same hardness is within 5 HRC of each other. Soooo.. if you have a hardened steel shaft there, and the inside of your gear isn't hardened you should be reasonably ok.
Also, I'd still be concerned even though this isn't production equipment. Our prof showed us a few examples of some coupling threads that suffered from galling, and that's obviously not a high-cycle kind of thing. so mostly, I'd just keep it lubed and keep these things in mind in your white paper.
Unread 11-03-2004, 22:02
AKA: Bradley Rigdon
Thanks for the heads up guys. We tried filling the bottom with oil but that got too messy.
We ran the trannies for hours and didnt have a problem. We give our robots the robust test every year...
Our robot never missed a shift once and that is almost amazing considering we always had problems with shifting the drills in previous years.
Unread 13-03-2004, 02:29
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Preface...Control systems guy with fetish for understanding mechanicals.
How do the balls capture the gear? And how do you control which gear gets captured?
Unread 13-03-2004, 16:42
henryBsick's Avatar
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
In the picture, the balls in the shaft sit down in thier holes, not above the exterior surface of the shaft. We have a rod that moves in and out of the shaft which pushes the balls up locking them into the little notches in the gears. The rod is on springs so when it touches the 4 balls (on one gear) on the inside of the shaft the balls do not jump up into the gear by force they go when ready so not to grind. the balls fall back into place once the rod is removed. So by moving the rod to different places it locks in different sets of gears choosing our speed.
I hope i didn't confuse anyone to badly.
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 15-03-2004, 09:05
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
How do you prevent the balls from moving radially outward when the shaft is spinning? I would think that the centrifugal force on them from the spinning shaft would tend to push them out into the slots in the gears.
I (and from reading this thread, many others also) would be very interested in seeing a photo or drawing of how your sliding rod works to move the balls in and out. I would also be interested in knowing how you cut the slots in the gears.
If you put a sensor on both shafts, I think you could make a really slick automatic transmission with this gearbox.
When the software figures it's time to shift up to the next higher gear, indicated by high motor speed, the control computer would put the gearbox in neutral, then drop the motor speed down so that the input shaft speed, as measured by the period between sensor input triggers on the input shaft, matches the period measured on the output shaft, adjusted for the gear ratio of the next desired gear. At this motor speed the desired input/output gears are spinning at exactly the same speed. Then the contoller would shift to the desired gear, the balls pop into place on the output gear, and the controller applies power to the motor, accelerating away in the higher gear. A similar sequence can be used to down-shift, where the motor speed is increased while in neutral to match gear speeds. The system would work like a sensor-controlled synchromesh. (I would call is "automatic sensor synchromesh" if not for the unfortunate acronym . Maybe "sensor controlled synchro - SCS would be a better term.)
In any case, this would be a neat project to work on. Any chance of getting some more details?
Unread 15-03-2004, 09:57
AKA: Bradley Rigdon
The force your refering to is just inertia (a body in motion will remain in motion unless acted upon by an outside force). This is a comon mistake that people make mistaking intertia with centrifugal (which does not exist). The ball bearings remain in the shaft until the air inside shaft pushes the balls out and locks the gear. Even if they did push out the balls would be forced back in by the rotation of the gears and shaft
pic: 716 Dual Motor/Dual Speed CD47-Bot Robot Showcase 18 23-04-2004 01:51
pic: 222 3 speed on the robot CD47-Bot Robot Showcase 6 11-03-2004 21:39
pic: dual speed gearbox CD47-Bot Extra Discussion 9 07-10-2003 15:04
pic: 716 single speed CD47-Bot Extra Discussion 2 09-09-2003 15:51
