Go to Post Only Dave knows [if the 2010 game is designed already], and he aint tellin' but he'll happily feed you lots of red herrings. - Koko Ed [more]
Unread 13-03-2004, 19:38
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
How do you do basic layouts/designs
How does your team do basic layouts for manipulators or chassis and such. I dont mean exact drawings specifying bolts and such, just an early drawing to make sure all your components can fit and stuff like that. If you use a CAD program, which do you use?
Team 1257
Unread 13-03-2004, 20:05
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: How do you do basic layouts/designs
Our team started out with just hand drawings and then later made CAD images in Inventor for some parts. We never made the whole thing in Inventor, however.
Unread 13-03-2004, 21:32
Alavinus's Avatar
Alavinus Alavinus is offline
Siege Weapon/Robotics Guy
AKA: Andrew LaVinus
Alavinus will become famous soon enoughAlavinus will become famous soon enough
Send a message via AIM to Alavinus
We made drawings and then modeled the robot out of cardboard. The advantages of cardboard are: it offers a life size mockup, is very easy to work with, and if you screw up, nobody cries!
We also did some CADing with inventor and plan to use that more next year as soon as we can get people trained.
Unread 15-03-2004, 17:18
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
We used Pro/Desktop from PTC for the students and I compiled all their designs into Pro/Engineer (also PTC). This gave us the ability to see most of our items would package. The problem with CAD is 3D programs can be memory hogs and it wasn't long before I had to export smaller files for the students because their PCs couldn't handle the files the way my workstation does.
I have to say though even as an engineer with a CAD system I live to use cardboard, wood, and PVC because nothing beats seeing the real size and relation of things.
Unread 15-03-2004, 18:22
Joshua May's Avatar
Joshua May Joshua May is offline
Go Bears!
FRC #1110 (Binary Bulldogs)
Joshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond reputeJoshua May has a reputation beyond repute
Send a message via AIM to Joshua May
We pretty much drew side, front, and top sketches of the basic components and lined up the parts or used scrap. We also measured out everything on the drawing to make sure everything fit right. We didn't really get anything on Inventor because none of our members were trained with it at all, and we got the software in the middle of the six-weeks because of a shipping problem.
The FIRST Wiki - openFIRST - Ultimate Robot Challenge - URC Wiki
I currently have 50 GMail invites, PM or email me for one.
UC Berkeley Class of 2009
2005 Las Vegas Regional Autodesk Visualization Award
2005 Las Vegas Regional #8 Seeded Alliance with 988 and 1505
2006 Southern California Regional #15 seed
Unread 15-03-2004, 18:39
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
I used Inventor to do low resolution sketches for the initial design. So C-channels get modeled as square bars, motors might be just a cylinder slightly larger than actual size etc. The key here is to use the parameters to figure out the relative size of things then go back and do all of the detailed nuts and bolts.
I've started learning ProE, because we can get enough copies so everyone on the team can have one. Eventually we want to do everything in ProE.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 16-03-2004, 12:20
Dick Linn's Avatar
no team (Synergy)
We used pencil sketches, chalkboard and dry-erase board mostly. I used the Visio program that was included this year to do some fairly detailed 2-D layout work. It is relatively easy to use and very quick once you get the hang of it. They used to call it "the drawing program for the rest of us" or something to that effect. I highly recommend it. It is pretty easy to create objects (motors, bearings, wheels) and scoot them all around to see where things fit.
I do wish they had included the professional version with all the engineering, software design and electrical templates. Still, you can create your own templates, which I've found useful over the years.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 16-03-2004, 13:03
what do you mean design...
Unread 16-03-2004, 15:30
Carlo Carlo is offline
FRC #0365
Carlo has a spectacular aura aboutCarlo has a spectacular aura aboutCarlo has a spectacular aura about
Send a message via AIM to Carlo
The Miracle Workerz have a few days in which we all come together and brainstorm. Once we decide a basic strategy, each student is required to submit at least one way at accomplishing our strategy. Everything from manipulators to chassis to drivetrain is normally covered by the end of this session. Once we have completed these initial designs, we vote on which we think will be the most efficient at accomplishing our strategy. Once these are complete, a basic robot is modeled in Pro-E for the main robot layout. Solidworks can be used from time to time, as it is more readily available for students to use in their own homes though.
University of Delaware
Mechanical Engineering- 2009
Dupont Advanced Fiber Systems
Unread 16-03-2004, 16:44
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
We used Rhino 3d to do all of our concept drawings, i can draw things relatively fast and with some accuaracy and scale so it works well, The first one i did took me about an hour and then that one kept being changed
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 16-03-2004, 19:13
Generally Useless
Maybe I should take some lessons from you. Here at work they scrapped Correl Draw and gave us Visio with no warning and no training. ( "Here's your new upgraded computer sir. All loaded with the latest standard software package. No sir, I'm afraid you'll have to learn this new stuff" ) As far as I'm concerned it MIGHT be good for flow charts and org charts, but since I never do those it's useless to me. I still can't figure out how to do an irregular polygon ...
I must be missing something that's supposed to be obvious, but isn't.
ChrisH
"Who is John Galt?"
Unread 17-03-2004, 10:45
Dick Linn's Avatar
no team (Synergy)
Visio - polygons
Use the straight line tool to click, drag, release in succession for each side. Just like connecting the dots. The last line should have the endpoint aligned over the starting point before being released and the wire frame will become a solid. You could also probably just stick a bunch of individual lines together if the sides need to be of precise length. There's a pop-up box available with some dimensions and you can alter them rather than eyeballing and dragging (I forget which menu bar option has this...they moved it in Visio 2003).
Alternatively, use a stock shape with the correct number of sides, select it with the straight line tool (click and release), select a vertex (which will change color) and you can then drag and reposition it. Also use this technique to correct any shape you draw.
Check out the Union, Combine and Fragment features for working with two shapes. Pretty interesting.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Visual Basic dddriveman Programming 12 20-03-2004 13:03
Impending BASIC Stamp Editor Beta 2 release Greg Ross Programming 9 19-09-2003 06:05
Help programming in Visual Basic xxlshortys Programming 0 06-04-2003 08:54
Basic Run Error BBFIRSTCHICK Programming 10 02-04-2003 22:43
Manchester Rgnl. ETREMELY basic scouting DB Rick Regional Competitions 9 24-02-2003 19:07
