Go to Post We use the engines of our imagination on the robot all the time. FIRST being an engine of change after all. - Mark McLeod [more]
Unread 13-03-2004, 21:06
Guest
Posts: n/a
Re: Shocking!!!
Originally Posted by Bduggan04
It really isn't that surprising because you really can't do that much in Auton and it is not as important last year. There were not many 5pt ball handling robots at GLR so releasing the balls was not an advantage, but more of an obstacle. You also don't really want to hang in auton. So the only thing a team that doesn't pick up 5pt balls can do in auton that would be of any advantage is grabbing the goal and returning with it. It is however, important if you hope to handle balls or be paired with someone who can.
Overall, I think the matches would be better without the auton period because this regional made it clear to me that it doesn't add much to the game. It simply makes teams scramble to complete their other objectives.
I disagree. Autonomous mode adds a whole new dimension to the game.
A) It makes the programming more advanced.
B) It lets the teams who do put time into it have a greater variety of strategies.
C) When you see a bot do something cool in autonomous mode, it is simply great.
Unread 13-03-2004, 21:19
2Crisis's Avatar
2Crisis 2Crisis is offline
Blaarg
AKA: Dave L
#1343
Team Role: Webmaster
2Crisis is an unknown quantity at this point
Send a message via AIM to 2Crisis
Re: Shocking!!!
I also found there was a lack of autonomous functions at the Arizona Regional this weekend. I think most teams just put their priorities in other systems, as the 15 second auton time didnt really have any necessity. The balls would drop later anyway.
In the case of our team we could get the robot to line-track, but our two-sensor system was just too inaccurate to function well enough so we didnt use it. Our one try resulted in hitting the wall at high speed and flipping over. :/ In my opinion, the Teams that WERE able to succesfully complete a function in auto did have an advantage, such as more time to herd balls, or get the movable goals or 2x balls without other robots in the way.
Team 980's autonomous was simply awesome, as they would grab the 2x ball, lift it, and swing its arm around to the other side of the robot all in one fell swoop.
another notable was 190 who would get on the bar and hang in auto mode if they had it lined up perfectly. then 190 would deploy their 'bar-shields' which would guard other robots from attaching, although I never really saw any other robots try after 190 was up. Getting up there in auto meant they didnt have to worry about 696 trying to ram em off the platform however.
Unread 13-03-2004, 21:22
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
Re: Shocking!!!
I have to ask though, what is a great auton? what exactly have you gained in those fifteen seconds. I'm sure someone is going to surprise me, but I'm afraid that auton will still have minimal impact on the match. I would love it if someone had concrete example that would make Auton more exciting.
Unread 13-03-2004, 23:04
Paul H's Avatar
Paul H Paul H is offline
Renegade of Funk
AKA: Paul Huston
FRC #0033 (Killer Bees)
Paul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant future
Send a message via AIM to Paul H
Re: Shocking!!!
I'm not sure about more exciting, but for us, the extra time to grab balls really helps. Plus, the balls on the ground hinder most other teams. We also have some additional things we hope to pull off that will be beneficial to our scoring strategies.
I guess it depends of the focus of the bot. For the small ball handlers, which is a minority, the autonomous mode helps out.
-Paul
Unread 13-03-2004, 23:15
Todd Derbyshire's Avatar
Todd Derbyshire Todd Derbyshire is offline
Alumni
Todd Derbyshire will become famous soon enoughTodd Derbyshire will become famous soon enough
Re: Shocking!!!
I have seen only one good autonomous mode and that was 190's. Basically they have the capability to hang in autonomous!!
119=190 right?????
Unread 14-03-2004, 00:41
Re: Shocking!!!
I took us all day friday to get our auton mode 'dialed in' - mostly because the gearheads on our team took up most of our time between matches getting some mechanical bugs worked out, so we did not have any time free to work on the code or sensors
but we did get it working by the last few matches on friday, and it worked in every match on saturday, including all the elimination rounds, except the last one - we were in the finalist alliance and played in the last match, and for some reason our bot did not see the beacon, so we missed the release ball
our bot is designed to collect balls exceptionally well, with a powered roller on the front, and room to hold 4 or 5 balls - I think that teams that focused on hanging in general did not bother to implement much of an auton mode, since they had no real means to herd the small balls anyway
but I did see some teams that were going for the bar atleast move very close to it in auton mode - our finals alliace partner, 211 (Kodak/Marshal) did that
I thought our auton mode was pretty cool - we go forwards using the gyro sensor to stay straight, when we see the beacon out one side we stop and back up a bit, drop our arm down to the height of the release ball, turn towards it exactly 90° (using the gyro again) - move forward to knock it off, back up, raise our arm, turn another 90° towards our drivers, turn the front roller on to capture some of those balls that are now all over the field, moving forwards at full speed till auton ends
its worked great once we got all the angles and distances down- we are looking forwards to our next regional, Buckeye - when it should be working on ALL our seeing rounds, instead of only on the last few.
Unread 15-03-2004, 00:28
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Re: Shocking!!!
That sounds awfully familiar. At that start of the practice rounds on Thursday at Phoenix, we had a single autonomous program (which I knew wasn't going to work, since our IR sensors weren't even hooked up yet.) By the second match, we had our first "working" autonomous program (the ever popular "Mars rock dance".) Eventually we gave up on the IR tracking in order to make weight, but by the start of the finals, we were up to 9 (dead reckoning) autonomous programs the drivers could choose from.
Unread 15-03-2004, 00:41
thewizard16 thewizard16 is offline
AKA: Matt McNelley
#0016 (Baxter Bomb Squad)
Team Role: Student
thewizard16 has a spectacular aura aboutthewizard16 has a spectacular aura about
Send a message via MSN to thewizard16 Send a message via Yahoo to thewizard16
Re: Shocking!!!
I also noticed that auto-mode seemed less-utilized so far this year. It just seems to me that everyone (including us) is having some trouble making their autonomous work right. I know that with having to redo all our programming in a different language this year, (and some design and mechanical delays) we didnt get to working on autonomous as soon as we'd have liked, and therefore didnt get to test all of our ideas. I don't think autonomous is less important, it's just not being used in strategy as much. I think you'll see that change by the time we're at championships and teams start realizing how tough it's going to be, and that those first 15 seconds could really help.
-Matt McNelley
Team #16
Unread 14-03-2004, 08:40
Jonathanb's Avatar
Jonathanb Jonathanb is offline
1037 S.C.R.E.A.M-a-holic
#1037 (S.C.R.E.A.M Team)
Team Role: Driver
Jonathanb is on a distinguished road
Send a message via AIM to Jonathanb
Re: Shocking!!!
Thanks for everyone's opinion's! I however think that having an autonomous mode helps out quite a bit. For example, if you release the 5pt. balls during autonomous, it does become a big obstacle for some teams that role right over them tip-seen too much of that at GLR. I was also surprised that so few teams did nothing with the mobile goals or didn't have mechanisms that were able to latch on well?
Jonathan
S.C.R.E.A.M 1037
www.teamfordfirst.org/team1037
2004 Detroit Website Design Award Winner
Circuit Breakers ark_1230 Electrical 28 09-04-2002 23:16
Shocking News about Circuit Breakers Joe Johnson Technical Discussion 0 19-03-2002 12:08
Update after weekend #1: Batteries & misc. FRCOps General Forum 8 12-03-2002 13:04
