Go to Post me: "Was I on fire!?" Roberto: "Sure you were. We only let you burn for about 10 seconds.":yikes: - El Geffe [more]
Unread 14-03-2004, 02:51
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
How to measure wheel revolutions
What is an easy/reliable way to measure wheel rpms? using optical sensors? reed switches?
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 14-03-2004, 03:31
10intheCrunch's Avatar
10intheCrunch 10intheCrunch is offline
Who's John V-Neun?
AKA: Alex Baxter
None #0254 (Cheesy Poofs)
10intheCrunch is a jewel in the rough10intheCrunch is a jewel in the rough10intheCrunch is a jewel in the rough10intheCrunch is a jewel in the rough
Send a message via AIM to 10intheCrunch
Re: How to measure wheel revolutions
We have proximity sensors with a very short range (a few mm) pointed directly at the sproket turning our back wheel. The sensors are rigged to interrupts in the program (which can be either rising edge or change). From there it is pretty easy to go to RPM.
~Alex Baxter
Programming, Arms operation, Team 254
Unread 14-03-2004, 04:45
Avarik Avarik is offline
Avarik is an unknown quantity at this point
Rotary encoders work well, provided your robot doesn't bounce too much.
Unread 14-03-2004, 10:19
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
There are "banner" sensors in the kit. White or Red reflective tape is legal for pulse generation. This years banners need to be adjusted as at full out they tend to false positive at close range. Search for sensors, or quadature, on this site for threads on coding.
Good luck.
Unread 14-03-2004, 15:57
WebWader125
Posts: n/a
Our team (663) used the banner sensors to measure drive sprocket rotation very successfully. Rather than use reflective tape, we used Microsoft Word to draw circles that were divided into 8 slices, with every other slice colored black. Printed this on sticky paper, and attached that to the sprockets. That allowed us to count 1/8 rotations, which given our wheel size meant accuracy to about 4 inches.
Unread 24-03-2004, 20:22
LauraN's Avatar
LauraN LauraN is offline
Holder of the Missile Keys
FRC #0097 (RoboRuminants)
LauraN is a splendid one to beholdLauraN is a splendid one to beholdLauraN is a splendid one to beholdLauraN is a splendid one to beholdLauraN is a splendid one to beholdLauraN is a splendid one to behold
Send a message via AIM to LauraN
See this thread for an explanation of Team 30's method:
http://www.chiefdelphi.com/forums/sh...570#post239570
It's similar to the one used by 663, but a little more accurate.
-Laura Nicholson
Team 97 (RoboRuminants) Mentor
Team 30 (FURY) Alumna
Unread 24-03-2004, 20:46
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Do you happen to know what kind of proximity sensors you're using? Are they ultrasonic? magnetic? Maybe even a part number? Thanks in advance.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 24-03-2004, 21:32
Who's John V-Neun?
AKA: Alex Baxter
Magnetic, and I'll get you the part number in a few minutes...just gotta wait for Jay to get back...
~Alex Baxter
Unread 24-03-2004, 21:52
The Paco's Avatar
The Paco The Paco is offline
The dynasty has come to an end...
AKA: Goose
FRC #0048 (Delphi E.L.I.T.E.)
The Paco is a glorious beacon of lightThe Paco is a glorious beacon of lightThe Paco is a glorious beacon of lightThe Paco is a glorious beacon of lightThe Paco is a glorious beacon of lightThe Paco is a glorious beacon of light
Send a message via AIM to The Paco
we use optical encoders which provide input to a custom circuit which then converts that input into output like wheel direction speed and distance. everything you need for a decent autonomous mode. the shaft of the encoder is directly attatched to the output shaft of our transmission. its excellent and reliable. we may have replaced them once last year but overall i definately reccomend these encoders to measure wheel revs!
If you tell people where to go, but not how to get there, you'll be amazed at the results.
- George Patton
"Quenching your thirst for FIRST"
Buckeye Regional Chairman's Award - '05 '06
Safety Award - '05 Pittsburgh
Website Award - '05 Buckeye
Imagery Award - '05 Buckeye
Sportsmanship Award - '05 GTR
Regional Finalists - '05 GTR
Optical Sensors Used as Encoders? uvabrad825 Technical Discussion 22 03-05-2004 13:22
Clamping wheel hubs sanddrag Technical Discussion 7 29-02-2004 00:20
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
Tape measure proboscus tito General Forum 24 29-04-2002 15:56
