Go to Post And remember, it's the fall semester. So FIRST isn't an excuse for a failing grade (not that it's ever an excuse)! - Billfred [more]
Unread 13-03-2004, 22:26
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: pic: a control box
If the heat sink is a completely passive device (ie. it is a big lump of aluminum that is nailed to your compressor) then it is OK. However, if it is an active device with forced cooling (ie. it is a big lump of aluminum that is nailed to your compressor, and it has an electric fan that forces air over the surface of the lump to speed the removal of excess heat), then you may be in trouble. The fans are electrical devices, and are subject to all the restrictions of such devices under the parts use flowchart.
Under the definitions used by FIRST, a fan is an electronic component (ie. it is designed to conduct electricity). Since it did not come in the kit, you have to ask the question "is the part a motor, solenoid, pump, or other actuator?" the answer is "yes" (the fan does contain a motor). According to the flowchart, the fan may not be used.
-dave
Unread 13-03-2004, 22:31
Just make sure you don't ruin the compressor by nailing this mythical heat sink to it
Unread 13-03-2004, 23:21
dlavery's Avatar
Curmudgeon
Liquid Nails!
-dave
Unread 14-03-2004, 00:07
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
All I was pointing out was that ruling "ID: 436 Section: 5.3.2 Status" (I read all the questons and answers one night) If you can use the fans from the kit all is well, that it. They did enclude two big ones and some little ones, we are using two of the little ones to cool our drill motors. So if you get challanged on it just make sure you have the supplied fans at the ready. That is all. BTW there would be no issue of a heat sink on your compressor, cooled by a fan supplied in the kit. Good luck, and it's still a very professional job with the layout and wiring.
Unread 14-03-2004, 00:08
velocipenguin velocipenguin is offline
#0246 (Overclocked)
velocipenguin is on a distinguished road
Send a message via AIM to velocipenguin
Originally Posted by TierraDelDiablo
I certainly hope not, cuz we have a heat sink on the top of our compressor. With out it, there is no way to keep the compressor cool, and we have the compressor on for the entire match cuz we have soo many pneumatics running all the time.
Make sure you have the new version of ifi_aliases.h included in your code. It sounds like you're among those who are having cooling issues with the compressor because IFI accidentally reversed the relay aliases in one of the earlier code revisions.
Unread 14-03-2004, 00:19
AKA: Tom Cooper
What he is refering to if the spike that drives the compressor is not green, the ifi_aliases.h file is the old one and the compressor is getting reverse voltage, you can also just wire it black to red, as I think all the relay outs were upside down, someone else may know that for sure, we didn't get our valve code started until after we were using the new file. If you are using the diode trick to use one spike to drive you double valves, things may get reversed. I may be all wrong about the new file, as far as the other relays go but it would pay to check first.
Unread 14-03-2004, 13:14
SteveC116's Avatar
SteveC116 SteveC116 is offline
SteveC116 has a spectacular aura aboutSteveC116 has a spectacular aura about
Is that Harry Potter in the background?
*Guarana Induced Happiness*
Steve Cohen
Team 116 Animation Captain
http://stevecohen.blogspot.com
Unread 14-03-2004, 13:17
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Originally Posted by edomus
What are the red boxes at the very bottom. Battery connectors?
yeah, looks like quick disconnects to me. (although I never find them quick. )
rufu5's Avatar
rufu5 rufu5 is offline
20something
FRC #5010 (Tiger Dynasty)
rufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud of
Send a message via AIM to rufu5
Sorry i couldn't post back quicker I was at the Great Lakes Regional. My name is rufu5 and I am a Sophmore in HighSchool and the Electrical team leader for team 447. We used SP50 battery connectors (just like the ones for the battery, since they can handle 50amps) to quick-disconnect all of our motors, and then we used 25pin d-ring connectors for all of our 20awg and up stuff like gyro sensors, hall-effect sensors, ect. This box can be completly dissconected and isolated from the robot for very easy troubleshooting (which i had to do at Great Lakes with help from team 45 the TechnoKats THANK YOU!!), so that is very handy. I also put in neon and LED fans for cooling but the judges made us turn off our neon because the said "they overpowered the team color lights."
If you have any questions about the box just keep posting, i will try to be online more often lol.
have no fear of perfection, you will never reach it.
-Salvador Dali
Unread 14-03-2004, 14:05
Roland's Avatar
Roland Roland is offline
Post-A-Holic
#1466
Team Role: Webmaster
Roland is infamous around these partsRoland is infamous around these partsRoland is infamous around these parts
Wow, that's a beautiful board. I like what you've done with the Anderson connectors for the motors. Our electrical guy does maddeningly beautiful wiring like this, too. While beautiful, it's a huge pain in the butt to modify: the identical wires make it very hard to see what goes where. Has your team encountered this problem?
Unread 14-03-2004, 15:32
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
You should get red and blue neon lights that you can easily switch between. They might then be allowed, and they would help everyone else out when trying to figure out what alliance each robot is on.
See you in DC!
Unread 14-03-2004, 16:47
rufu5's Avatar
20something
That is an awsome idea and I am going to try and follow up on that before Chicago.
Also, we labeled all of the wires (very tiresome process) so we could easily disconnect any pwm or motor cable for testing and then quickly reconnect them before the match lol.
-Salvador Dali
Unread 14-03-2004, 21:45
Ali Ahmed's Avatar
Ali Ahmed Ali Ahmed is online now
FRC #0004 (Team 4 ELEMENT)
Ali Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to beholdAli Ahmed is a splendid one to behold
That is a very nice electronics board. We are doing some thing like but it is 4 boards connected togeher w/ Andersons.
Student: Team 22
Mentor: Team 4
Unread 15-03-2004, 00:12
AKA: Tom Cooper
Glad the Inspectors didn't give you any trouble other than the lighting about the fans. Someday I hope our team has space and weight for a control box as sharp as yours.
Unread 15-03-2004, 00:16
rufu5's Avatar
20something
That sounds interesting, do you guys have a pic?
-Salvador Dali
pic: Team 294 Control Board: View 2 CD47-Bot Extra Discussion 17 11-08-2004 17:21
pic: 179's Control Box (unfinished) CD47-Bot Extra Discussion 14 11-03-2004 10:52
Control Box Sizes InnoVaZiAn DJ Control System 8 20-02-2004 18:00
control box size gail OCCRA 2 24-09-2002 05:30
control box archiver 2000 8 24-06-2002 00:20
