Go to Post Polycord. It was used in all sorts of ball systems in 2009, and on some of the 2007 claws. It's not too hard to fuse together by hand with some heat and patience. - AustinSchuh [more]
Unread 14-03-2004, 22:46
Andrew Andrew is offline
Andrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to all
Operator Interface LED Drivers
Has anyone programmed the OI LED drivers in the new RC?
In the old OI/RC combo, the LED drivers were tied to outputs 12, 13, 14, and 15. Despite the documentation saying that pwm1_red, etc. are the output drivers, those drivers are only tied to the blinking lights on the OI itself and do not drive the four drivers available on ports 2 & 4.
If anyone has figured this out for the new RC, I would appreciate knowing what variable connects to these drivers.
Unread 14-03-2004, 22:56
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Re: Operator Interface LED Drivers
from page 10 of the 2004 rc manual from ifi;
In general, the user cannot control the team color, because it is set by the Arena Controller during competition.
Also i saw it somewheres else saying its not allowable to controll the flash rate or color of the led displays.
-Michael Dessingue
Unread 14-03-2004, 23:03
The Lucas's Avatar
CaMOElot, it is a silly place
The documentation says that the LED drivers are on pins 15, 8, 9, and 5 of Ports 1 & 3 (not 2 & 4). I use them and they work (LEDs on these pins mimic the lights on the OI). [EDIT] Just set the corresponding variables mentioned in the document to 1 or 0. [/EDIT]
Robot Inspector
Unread 14-03-2004, 23:05
Dez, he is refering to the LEDs on the Operator Interface, which are completely seperate from the team color LEDs on the Robot controller that you refered to.
Unread 15-03-2004, 06:07
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Yes, they are very easy to use. As was stated early, to turn on, set the one you want to 1 and to turn off set it to 0.
Unread 15-03-2004, 06:39
mattf mattf is offline
#0168 (The Flashbacks)
mattf is on a distinguished road
Send a message via AIM to mattf
they are indeed very easy to use; however, there is a bug in the documentation. the led's mimic the relay lights, so use Relay1_green, Relay2_red, etc.
2004 UCF Quarterfinalists! (168, 79, 710)
2003 UCF Regional Champions! (212, 168, 108)
Unread 15-03-2004, 07:02
Programming User
If you are refering to the fact that it says the PWMs, they do both. Port 3's pins are controlled by the RelayX_green etc. while port 1's pins are controlled by the pwm LED names (don't remeber them right now. )
Unread 15-03-2004, 11:27
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
I use the default code doc because it's got tables for each port. I believe they are the same as the LEDs on the OI itself.
Making a beacon indicator LED burn its brightest without burning out DanL Electrical 7 26-01-2004 08:05
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
2003 IRI: A driver's last hurrah or a new rookie driver's experience? Amanda Morrison Off-Season Events 14 23-05-2003 17:39
LED colors archiver 2001 1 24-06-2002 00:04
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
