Go to Post Your GPA in High School and College is a reflection of your cooperation with educational processes, nothing more. It is NOT a measurement of how much you know or how much you can learn. - Mike Martus [more]
Unread 14-03-2004, 22:46
Andrew Andrew is offline
Andrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to all
Operator Interface LED Drivers
Has anyone programmed the OI LED drivers in the new RC?
In the old OI/RC combo, the LED drivers were tied to outputs 12, 13, 14, and 15. Despite the documentation saying that pwm1_red, etc. are the output drivers, those drivers are only tied to the blinking lights on the OI itself and do not drive the four drivers available on ports 2 & 4.
If anyone has figured this out for the new RC, I would appreciate knowing what variable connects to these drivers.
Unread 14-03-2004, 22:56
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Re: Operator Interface LED Drivers
from page 10 of the 2004 rc manual from ifi;
In general, the user cannot control the team color, because it is set by the Arena Controller during competition.
Also i saw it somewheres else saying its not allowable to controll the flash rate or color of the led displays.
-Michael Dessingue
Unread 14-03-2004, 23:03
The Lucas's Avatar
CaMOElot, it is a silly place
The documentation says that the LED drivers are on pins 15, 8, 9, and 5 of Ports 1 & 3 (not 2 & 4). I use them and they work (LEDs on these pins mimic the lights on the OI). [EDIT] Just set the corresponding variables mentioned in the document to 1 or 0. [/EDIT]
Robot Inspector
Unread 14-03-2004, 23:05
Dez, he is refering to the LEDs on the Operator Interface, which are completely seperate from the team color LEDs on the Robot controller that you refered to.
Unread 15-03-2004, 06:07
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Yes, they are very easy to use. As was stated early, to turn on, set the one you want to 1 and to turn off set it to 0.
Unread 15-03-2004, 06:39
mattf mattf is offline
#0168 (The Flashbacks)
mattf is on a distinguished road
Send a message via AIM to mattf
they are indeed very easy to use; however, there is a bug in the documentation. the led's mimic the relay lights, so use Relay1_green, Relay2_red, etc.
2004 UCF Quarterfinalists! (168, 79, 710)
2003 UCF Regional Champions! (212, 168, 108)
Unread 15-03-2004, 07:02
Programming User
If you are refering to the fact that it says the PWMs, they do both. Port 3's pins are controlled by the RelayX_green etc. while port 1's pins are controlled by the pwm LED names (don't remeber them right now. )
Unread 15-03-2004, 11:27
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
I use the default code doc because it's got tables for each port. I believe they are the same as the LEDs on the OI itself.
Making a beacon indicator LED burn its brightest without burning out DanL Electrical 7 26-01-2004 08:05
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
2003 IRI: A driver's last hurrah or a new rookie driver's experience? Amanda Morrison Off-Season Events 14 23-05-2003 17:39
LED colors archiver 2001 1 24-06-2002 00:04
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
