Go to Post As goes with all of my advice on CD, try it yourself and make up your own mind. I'm just suggesting things based on experience. See what works for your team. Follow my suggestions to the letter, mix and match them, or even throw them completely out the window. It's all about you and your team. - DampRobot [more]
Unread 14-03-2004, 23:49
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: Spacer....heh
Unread 14-03-2004, 23:50
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: pic: Spacer....heh
How in the world could that have worked with the bent shaft. I hope you didn't run it like that. Spare Parts had tons of Van Doors and you can really swap those out fast.
Unread 15-03-2004, 00:04
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
wow....simply wow
-speechless
Unread 15-03-2004, 00:14
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
You can't swap them out as quickly when the driving gear is tack welded to the motor output shaft
--Madison--
...down at the Ozdust!
Unread 15-03-2004, 01:00
Sorry, missed that tack. Anyway, this was about the zip tie spacer. We've done that before (last year in testing). So many times it seems to be just the right width.
pic: Team PIC of 354 Westinghouse HS CD47-Bot Robot Showcase 4 29-02-2004 12:15
pic: Team 782 teaser pic CD47-Bot Extra Discussion 2 15-02-2004 23:53
TCP/IP on a PIC Venkatesh Electrical 1 18-11-2003 21:00
pic: heh heh heh CD47-Bot Extra Discussion 1 30-04-2003 12:02
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
