Go to Post Remember those two words people. Gracious Professionalism. - Elgin Clock [more]
  #31   Spotlight this post!
Unread 12-03-2004, 20:16
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: quick question: TIMERS
I just relized something. In the initialize routines for the timers, the first 2 lines are address setters (I think). Most of mine are 0x00! Does this make a difference?
  #32   Spotlight this post!
Unread 12-03-2004, 22:21
No. Those just mean the timer starts at 0.
Believe I found the problem.
TICKS is declared as char (-127 to 127)
You are checking for 255 as an overflow.
TIME will never increment.
I grabbed Kevins interrupt code and added your code to the interrupt handler.
Only difference is I just declared your globals as static just within interrupts.c for my ease of duplicating your results.
TICKS and AUTOCLOCK increment as you wanted.
In Initialize_Timer_1 I changed:
PIE1bits.TMR1IE = 1;
T1CONbits.TMR1ON = 1;
  #33   Spotlight this post!
Unread 12-03-2004, 22:47
Xufer's Avatar
Xufer Xufer is offline
8 Seasons and as stable as ever
AKA: Working, 2/4 degrees complete still schooling...
FRC #1740 (The Cyber Colonels)
Xufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to behold
Send a message via AIM to Xufer Send a message via MSN to Xufer Send a message via Yahoo to Xufer
before i enable one of those timers, is there anythign i should know about which one would work best are there significant differences for them, i noticed you can change the ammount of time each tick increses the clock by.
once i enable one im still confused as far as the state switches and the case statements, idon't understand how the whole thing works is there any documentation or sample code i can look through, im really stumped and i would like to get a timer working.
If saftey is first and i put FIRST ahead of everything, then i must be the safest guy in the world.
Team 521 Alumni -- Team 1740 Mentor-- Go Go 1740!
Sometimes I think I've been doing this too long and other times I think I haven't done this enough... but all the times I'm sure I'm crazy
Photonics, It's Your Future
  #34   Spotlight this post!
Unread 13-03-2004, 22:58
10intheCrunch's Avatar
10intheCrunch 10intheCrunch is offline
Who's John V-Neun?
AKA: Alex Baxter
None #0254 (Cheesy Poofs)
10intheCrunch is a jewel in the rough10intheCrunch is a jewel in the rough10intheCrunch is a jewel in the rough10intheCrunch is a jewel in the rough
Send a message via AIM to 10intheCrunch
OK...I really want to help you dude but it seems like you don't understand what we're trying to say each time, or I can't explain it well enough...why don't you IM me (sn: TenintheCrunch)? I think I'll be able to help you more talking directly
Cheers,
~Alex Baxter
Programming, Arms operation, Team 254
  #35   Spotlight this post!
Unread 15-03-2004, 07:29
AKA: Jamie Bliss
I changed a compiler option to assume Char is unsigned. I only use a signed char one place, -1 - 1, and it's declared as signed. I also sent TICK to dashboard, and it didn't work. I didn't have IE set to 1, but I didn't think it would make a difference (it would just be slower, right?)
  #36   Spotlight this post!
Unread 15-03-2004, 10:14
Who's John V-Neun?
AKA: Alex Baxter
Where's the option for making chars unsigned by default? Does that affect ints and longs as well?
~Alex Baxter
  #37   Spotlight this post!
Unread 15-03-2004, 10:36
You set compiler flags in MPLAB
Project->Build Options...->Project
under tab "MPLAB C18"
There is a quick radio button for treating "char" as unsigned and one for forcing all calculations to be performed at least as int rather than the smallest type included in the calculation.
You can also enter your own flags by clicking on "Use Alternate Settings" and typing into the box that becomes enabled. You'll find the available compiler flags documented in the MPLAB C18 C Compiler User's Guide that came on the MPLAB installation CD, Appendix C. e.g., -k is the flag for treating char as unsigned. When you click on the radio button you'll see "-k" appear in the "Inherit global settings" window.
  #38   Spotlight this post!
Unread 15-03-2004, 10:41
If you mean:
INTCON3bits.INT2IE = 1;
Yes, this is required. It's your on/off switch for individual interrupts. It enables the interrupt which is disabled by default. Otherwise, nothing will happen.
  #39   Spotlight this post!
Unread 15-03-2004, 11:24
AKA: Jamie Bliss
Banner interupts work, but not timers.
  #40   Spotlight this post!
Unread 15-03-2004, 11:49
Sorry I mistyped and used the external interrupt flag. I meant to type:
This is required to turn on interrupt on timer overflow.
  #41   Spotlight this post!
Unread 15-03-2004, 16:23
Xufer's Avatar
i got my ded reckoning worked out and i have a switch wired up to switch between the two modes how would i do that using case statements?
it should be something like
case1 if (rc_dig_in_10=1)
{auton 1}
case2 else(rc_dig_in10=0)
{auton 2}
i read about them but how would they be used to work with a digital input from the rc
  #42   Spotlight this post!
Unread 15-03-2004, 16:48
{auton 1}
{auton 2}
You don't need a case statement if you only have two choices.
if (rc_dig_in_10 == 1)  //or just "if (rc_dig_in_10)"
{auton 1}
else
{auton2}
  #43   Spotlight this post!
Unread 15-03-2004, 23:26
Xufer's Avatar
{auton 1}
else
{auton2}
will that work if my autonmode begins in if statements though ? i tried something along those lines and it didnt seem to work...
  #44   Spotlight this post!
Unread 16-03-2004, 10:37
It will work.
If you try it and it doesn't behave as you expect post the error here and we'll help you debug any problems.
  #45   Spotlight this post!
Unread 16-03-2004, 13:26
Who's John V-Neun?
AKA: Alex Baxter
{auton 1}
{auton 2}
You don't need to use case statements, but there are a couple other things you have to do.
When you enter autonomous mode, all inputs are reset to neutral, so you have to capture the value from rc_dig_in_10 before autonomous turns on. Create a prevRcDigIn10 variable, and set that equal to the current one at the end of every loop (right before putdata()), then when you move into autonomous, look at that previous varialbe, not the real one (the "real" one will always be zero).
~Alex Baxter
Quick Question Burgabot Programming 31 02-12-2003 19:22
Quick <hr> question Jack Website Design/Showcase 1 31-01-2003 22:19
A quick question Joelster Technical Discussion 6 10-02-2002 09:09
quick question about qualifying points Hymnson General Forum 4 25-09-2001 21:19
Quick Question, i guess Andrew Rudolph Motors 1 12-08-2001 14:39
