Re: pic: 710 Hanging
Was this the match with us? Or did you hang earlier? I always knew you could hang, I never even thought about it. So when we we're up with you guys it was a no brainer. You guys did a great job, I wish we could've picked you in the second round. But you were prime meat.... How did you guys do with the 2x ball?
well we did fairly well, but most of the time just because the nature of our bot we had to play defense and did not have time for the 2x.
Also the different ball hurt us a bit. We recapped the mobile goal a few times.. never did anything with the big goal tho. In our style matches it was just more time effecient for us to hang or play defense than use the 2xer ball |
Yah, there's not enough time to fit in more than 2 things, either cap and hang or cap and cap. We never got to hang cuz we focused harder on capping. I think if we were with a rugged hanger we would have gone all the way. But they we're sucked up fast. When we get to nats we're going to be hanging regularly if it works out. I don't think anybody thinks we can hang either. Which we did fail a couple times but it was very possible, heh. George on 1083 and I felt we could win playing the game strictly with the balls. It worked great during seeding, but once in the finals everyone gets more aggressive.
to Quote myself....
"Dan, If you Hang, We WILL Win this Match" |
lol i remeber that quote...it was said 4 or 5 times
too bad we didnt win 4 or 5 times.... Only Once
![]() Match 97 http://www.soap108.com/2004/events/fl/matches.cfm Last edited by Tytus Gerrish : 15-03-2004 at 19:46. |
#7
We put ourselves in a position to win. All you can hope for after that is a little luck to help you through. We didn't have it. On topic, though: Congrats, 710! I can't wait 'til we get to steal Dan and Ryan away next year! =-] |
#8
I must admit, you guys pulled off what I was skeptical about. I remember you telling me about that in week 1 or 2... and I kind've laughed, but I'm really glad you guys did it... Once you guys are connected to that bar... your the fastest one to pull up
Only recommendation I'd make is to make a hook-on system for your grabber... so like if you KNOW in a match you won't need the 2x ball, you can put it on... so that it takes less time to grab that bar cause that did hurt you one or two times when it slipped off. Maybe even a switch of some sort to indicate to you when the arm is high enough to close in case a scenario comes up again where the 2x ball on the mobile goal blocks your view... would make it simpler for Dan to work. Great job guys! |
#9
starts designing and then brain blows up |
#10
Well I had been thinking of adding a hook that would be perpendicual to the arm, so that when we got up the second step we wouldn't have to turn the whole robot and line it up just run up to the bar and swing the arm at it.
#12
well it would be at the same height so that the hook came on the side of the arm kind of spaced out a bit and would only be as tall as the arm allready is.
#14
well.. yeah.. only problem is if we only hang from the one side the bot wouldn't balance itself.. tho I have been thinking of how we could balance it self
The one match your talking about where we did slip off.. we where hanging on 1 side.. but the right side of the bot tilted down. Tho in that match we didn't have enough time to do much we weren't really even supposed to hang or even go on the platform.. but our alliance partner broke and our shoots got blocked.. so the only way to effeciently score points was hang. We tried to do it for the first time and we had way too little time. At nats watch for us to play more hanging defense and less everything else :-) I still hold to the fact that while working ( that discludes the finals where our drivetrain had untightened sets screws and didn't run ) that no one has hung against us :-) .. See if we can keep that going. Dan |
| pic: A hanging mess! | CD47-Bot | Extra Discussion | 5 | 08-03-2004 15:35 |
| pic: Team 710 Drive module | CD47-Bot | Robot Showcase | 20 | 04-03-2004 01:21 |
| pic: Team 48 Robot Hanging | CD47-Bot | Robot Showcase | 1 | 01-03-2004 20:22 |
| pic: Team 340 Hanging and Uncapping | CD47-Bot | Robot Showcase | 1 | 23-02-2004 11:02 |
| pic: ROBBE Hanging | CD47-Bot | Robot Showcase | 6 | 16-02-2004 20:26 |
