Go to Post Hasn't that always been the mission of FIRST? Don't settle for what works; strive for what amazes. - Sam Lipscomb [more]
Unread 15-03-2004, 20:53
Ryan Albright's Avatar
Ryan Albright Ryan Albright is offline
Just Browsing
AKA: ryan albright
Ryan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond repute
Send a message via ICQ to Ryan Albright Send a message via AIM to Ryan Albright Send a message via MSN to Ryan Albright Send a message via Yahoo to Ryan Albright
Re: pic: 710 Hanging
Originally Posted by miketwalker
I must admit, you guys pulled off what I was skeptical about. I remember you telling me about that in week 1 or 2... and I kind've laughed, but I'm really glad you guys did it... Once you guys are connected to that bar... your the fastest one to pull up Only recommendation I'd make is to make a hook-on system for your grabber... so like if you KNOW in a match you won't need the 2x ball, you can put it on... so that it takes less time to grab that bar cause that did hurt you one or two times when it slipped off. Maybe even a switch of some sort to indicate to you when the arm is high enough to close in case a scenario comes up again where the 2x ball on the mobile goal blocks your view... would make it simpler for Dan to work. Great job guys!
hmmm .:scratches chin:.
starts designing and then brain blows up
Alumni of 710 2001-2004
Mentor 1083 2005
2005 UCF regional lead safety advisor
2005 Championship Safety advisor
Unread 15-03-2004, 20:56
miketwalker miketwalker is offline
Robot Lifeguard
FRC #1902 (Exploding Bacon)
miketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond repute
Send a message via AIM to miketwalker
Hmm, I think if you simply made a different type hook... so that you could pull up with only connecting the one side, instead of relying on both... in case of shortness on time like that one match when you slipped. Perhaps it could connect on the inside of the 2x ball grabber area and just be a different type of hook coming up... that has more of a curve or something so it latches on easier. I think you could make it "snap-on" "snap-off" relatively easily, and make it in the pits at your next competition pretty easily.
Chopsaw? Chopsaw.
Unread 15-03-2004, 21:15
abeD's Avatar
abeD abeD is offline
FRC #4707 (Mentor FRC#4707 Alumni FRC#710)
abeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to behold
Well I had been thinking of adding a hook that would be perpendicual to the arm, so that when we got up the second step we wouldn't have to turn the whole robot and line it up just run up to the bar and swing the arm at it.
Penn Class 08
Unread 15-03-2004, 21:18
Robot Lifeguard
Hmm, do you guys have enough height to do that though? Doesn't your arm just barely reach over the bar as it is? If you add a hook perpendicular, you might not have enough height above the bar to easily get it over the bar. Then again, maybe you have more height then I think.
Chopsaw? Chopsaw.
Unread 15-03-2004, 21:20
abeD's Avatar
well it would be at the same height so that the hook came on the side of the arm kind of spaced out a bit and would only be as tall as the arm allready is.
Penn Class 08
Unread 15-03-2004, 21:22
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
well.. yeah.. only problem is if we only hang from the one side the bot wouldn't balance itself.. tho I have been thinking of how we could balance it self
The one match your talking about where we did slip off.. we where hanging on 1 side.. but the right side of the bot tilted down. Tho in that match we didn't have enough time to do much we weren't really even supposed to hang or even go on the platform.. but our alliance partner broke and our shoots got blocked.. so the only way to effeciently score points was hang. We tried to do it for the first time and we had way too little time. At nats watch for us to play more hanging defense and less everything else :-)
I still hold to the fact that while working ( that discludes the finals where our drivetrain had untightened sets screws and didn't run ) that no one has hung against us :-) .. See if we can keep that going.
Dan
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
pic: A hanging mess! CD47-Bot Extra Discussion 5 08-03-2004 15:35
pic: Team 710 Drive module CD47-Bot Robot Showcase 20 04-03-2004 01:21
pic: Team 48 Robot Hanging CD47-Bot Robot Showcase 1 01-03-2004 20:22
pic: Team 340 Hanging and Uncapping CD47-Bot Robot Showcase 1 23-02-2004 11:02
pic: ROBBE Hanging CD47-Bot Robot Showcase 6 16-02-2004 20:26
