Go to Post In the end, we were successful, but the tale is one of such stupidity that it should be engraved in drool upon a failed math test. - AmLameBro [more]
Unread 16-03-2004, 07:20
Re: Limit of the atwood motors?
I am guessing here, but as that motor heats up the bearing clearances probably start to close down and eventually seize the motor shaft. I am guessing that if you take the motor out after it cools, it will likely rotate fine. However, once the shaft has seized, I would only use that motor in an emergency. The bearings are damaged and the high heat has boiled the lubricant. Even if it works, I wouldn't trust it any longer.
Where to get CIM (Atwood, Chiaphua) motors? DougHogg Motors 13 16-12-2003 13:21
atwood vs. NEW drill motors Solace Motors 36 11-03-2003 22:28
