Go to Post To ANY Robowrangler students reading this thread: If any of you ask me about the game hint, at any time, you will be assigned 4 hours of shop cleaning duty during week 1. No exceptions. - JVN [more]
Unread 16-03-2004, 15:49
Natchez Natchez is offline
#0118 (Robonauts)
Natchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond repute
We can extend beyond the playing field with our ball-knocker-offer???
Before I have to brief my team about the WRONG path that I led them down and pay the ultimate price (one million dozen Krispy Kreme donuts), I would like your opinion on rule G04 that states
ROBOT mechanisms used to remove the BONUS BALLS may extend beyond the playing field border as long as they are within the vertical pipe structure surrounding the BALL TEES. If a BONUS BALL is removed from the BALL TEE by a ROBOT that violates this rule, a 25 point penalty will be deducted from that alliance’s final score.
This rule was interpreted by my team to mean that if our "ball-knocker-offer" is extended beyond the side boundary, flexes as it goes by the vertical pipe that frames the 10 point balls, and ultimately knocks off a 10 point ball then we would be penalized 25 points. I have just learned that many teams are using this strategy. I must admit I'm feeling like an idiot because I obviously missed something.
Please let me know what I missed and send all of your extra Krispy Kreme donuts to 555 Pennsylvania Blvd, Houston, TX.
Thanks,
Lucien
Unread 16-03-2004, 15:59
Re: We can extend beyond the playing field with our ball-knocker-offer???
your question is a little fuzzy - to get the release ball your robot can only reach through the opening infront of the balls - see the playfield drawings in the manual to see what Im referring to
if you hit the release ball by reaching around the opening, deliberately or by wayward auton mode, the small balls will still fall, but you will get a 25 point penalty
maybe your students saw that happen, and did not realize they also got a penalty?
BTW, your robot can extend out over the sides of the playfield at any point in the game, but if you touch the floor your robot will be disabled for the rest of the match.
if that is the best your bot can do - get the ball from the side and incurre the penalty, I guess thats better than not having the balls drop for 45 seconds? maybe? if you cap the goal thats only a 2.5 ball penalty, right?
Unread 16-03-2004, 16:01
Rich Wong Rich Wong is offline
NYC FIRST Planning Committee Member
no team (NYC FIRST)
Rich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond repute
Send a message via AIM to Rich Wong
Thanks,
Lucien
From your description, it sounds ok, as long as the flexible appendage does not touch the outside of the field; carpet, supports, or a volunteer. Lol
But if the “appendage” hits the ball from the outside of the tee frame, a 25 point penalty will be given.
I will send you my address for the KKs.
popularis de ob instinctus agnitionis scientia technologia
Home website: www.nycnjfirst.org
Member of NEMO & e^(i*pi)+1 Fraternity.
Member of Friends of Robots
Member of NYCFIRST Planning Committee
Unread 16-03-2004, 16:02
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
I think it's illegal and should cost 25pts. You're definitely extending outside the field and not within the constraints of the bars that contain the 10pt balls.
[edit]To respond to someone's question above. The issue is whether or not it is legal for a robot to extend a flexible device outside the boundaries of the field and drive alongside the field to the 10pt ball. The flexible device would bend at the vertical frame that contains the balls and would thus 'flap' into a ball. I definitely think this is illegal... having anything outside the field is bad. I think FIRST's rule clearly says that the only time you may legally extend outside the field during autonomous is when your extension is within the frame that holds the bonus balls. Otherwise, it's a safety hazard and will cost you 25 points. Team 254's autonomous video does something very similar to what I described above. I'm not sure whether it extends outside the field though.[/edit]
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 16-03-2004, 16:08
oh wait - I see what you mean
your asking if the restriction is only the vertical pipes?
can you reach over the opening as long as you are between the vertical pipes when you hit the ball?
oooooh that is interesting - what do they mean by the vertical pipe structure? does that include the horizontal pipes?!
Unread 16-03-2004, 16:13
I think FIRST's rule clearly says that the only time you may legally extend outside the field during autonomous is when your extension is within the frame...
no! it doesnt say that!
it says you get the penalty ONLY if you get the release ball that way.
other wise if someones auton mode went off a little, and poked at the ball outside the bars, then they would get a 25 point penalty
but its ok for your bot to extend outside the field borders in driver mode as long as you dont touch the floor, or reach into the drivers area
so why would you incurred a 25 point penalty for doing that in auton mode?
that would be unnecessarily strict and would be a double strike against a team whos auton missed the ball by a few feet - the balls dont fall AND they get a 25 point penalty!
Unread 16-03-2004, 16:14
Aidan F. Browne's Avatar Unsung FIRST Hero
Aidan F. Browne Aidan F. Browne is offline
Engineer
AKA: The Aidan-bot
Aidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond repute
You may only remove a Bonus Ball by using a mechanism that protrudes through the Ball Tee Frame - not around it. (i.e., not from the left, right, or top)
The intent of this is twofold - as a safety rule and to protect the fragile components of the tee frame (sensors and lights).
Aidan
Unread 16-03-2004, 17:02
Kris Verdeyen's Avatar
Kris Verdeyen Kris Verdeyen is offline
LSR Emcee/Alamo Game Announcer
FRC #0118 (Robonauts)
Kris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond repute
No, it says that you get the penalty if:
where "this rule" means:
That means that, if your mechanism that knocks the ball off extends past the field border while not within the pipe structure, you are in violation. If a robot violates the rule, then knocks the ball off, that's a penalty. It might not have been the way that it's been called, but this is the way that it's been written.
...Only a few people are awake and they live in a state of constant total amazement. -JP Shanley, Joe vs. the Volcano
Unread 16-03-2004, 17:09
thats what I said
if the ball IS REMOVED (then you get the penalty)
not just if you extend past the field border
you are reading more into it than it says
Unread 16-03-2004, 17:21
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Aidan
Aidan,
Here's where the rule is fuzzy to me, and I would like your "insider" interpretation.
(BTW, I have seen this happen at competitions this year):
A robot starts heading toward the 10 pt bonus ball. The robot extends a small flexible arm off of the side of it's robot. This arm extends beyond the field boundaries. As the robot drives by the Vertical Pipe Structure (VPS), the VPS causes the flexible arm to bend (forcing the arm to go out of the way of the VPS). Once the robot clears the VPS, the flexible arm snaps back and then removes the bonus ball (now the arm is within the VPS).
Here is why the rule is fuzzy:
Rule: "ROBOT mechanisms used to remove the BONUS BALLS may extend beyond the playing field border as long as they are within the vertical pipe structure surrounding the BALL TEES. If a BONUS BALL is removed from the BALL TEE by a ROBOT that violates this rule, a 25 point penalty will be deducted from that alliance’s final score. "
1) The mechanism does extend beyond the playing field border (outside of the vertical pipe structure).
2) The mechanism is used to remove the bonus ball.
(here's the tricky part)
3) When the bonus ball is being removed, the mechanism is within the vertical pipe structure.
Here is what is not clear: The rule states that the mechanism may not extend beyone the playing field border unless it is within the vertical pipe structure. Does that mean: a) it can NEVER extend beyond the field border; or b) it can extend beyond the field border, just as long as it is within the vertical pipe structure while removing the ball.
Lastly, does the mechanism I describe above violate the rule of not designing a mechanism to purposely react off of the playing field border (because this mechanism uses the vertical pipe structure to deflect the little flexible arm.
To be honest, if teams use the flexible arm mechanism, I don't care all that much, but I would like to know your opinion.
Unread 16-03-2004, 17:51
Not to beat a dead horse, but, I already have my bat out and everything, so here goes....
As it's written:
As it should be written, if the intent is what Ken (and others) have said:
Originally Posted by TFM, as it might be
ROBOT mechanisms used to remove the BONUS BALLS may extend beyond the playing field border as long as they are within the vertical pipe structure surrounding the BALL TEES. If a BONUS BALL is removed from the BALL TEE by a ROBOT while it is violating this rule, a 25 point penalty will be deducted from that alliance’s final score.
As it should be written, if the intent is what Lucien and I think:
ROBOT mechanisms used to remove the BONUS BALLS may extend beyond the playing field border as long as they are within the vertical pipe structure surrounding the BALL TEES. If a BONUS BALL is removed from the BALL TEE by a ROBOT that has violated this rule, a 25 point penalty will be deducted from that alliance’s final score.
At the very least, this requires some clarification - it's starting to look like the tape measure controvery from two years ago - where a cheap, light, simple and obvious solution (curb feelers, in this case) that was apparently outlawed by the rules (causing teams to turn to expensive, heavy, and complicated solutions) turned out to be legal after all.
Unread 16-03-2004, 18:01
so then by your definition, if any part of my robot extends out of the field in my first match, then I get the release ball with that same part in the second match, I get the penalty, because that part extended at some point in the past, so my robot 'has violated the rule'
so everytime I get the release ball in every match after match 1, i get a 25 point penalty, even if i reach through the opening.
it should say, if the party of the first part builds a machine, mechanism, device.....
I think this thread has gone to the lawyers- as the game was demo'd at the kickoff the intent was clear, you have to reach through, you cant reach around.
Unread 16-03-2004, 18:14
so then by your definition, if any part of my robot extends out of the field in my first match, then I get the release ball with that same part in the second match, I get the penalty, because that part extended at some point in the past.
Nope, not gonna bite.
And the reasoning behind that rule is one of safety - if the people on the sidelines are expecting robots to come through the hole in the side of the field, then they can just avoid that part of the field. But now, we can have the curb feeler that conks every one of the judges, refs, and field resetters on the head on the way to the ball, and then folds back and gets the ball too. Even if it is following the letter of the rule (which is what the ruling will probably be if there is one), the intent is being violated.
Unread 16-03-2004, 18:23
Yan Wang's Avatar
Ithaca is Gorges
AKA: John Wayne
I completely agree with Kris. The reason there is a 'cage' around the bonus balls is for the protection of the referees and volunteers. Although some of those 'flappy' mechanisms aren't dangerous, they still violate the rules by extending outside of the field. There shouldn't be an exception to the rule. If your robot breaks the plane of the ball corral by just an inch, you lose points. Robots that extend outside the field while attempting to remove a bonus ball should be penalized, regardless of whether it was accidental or intentional.
Unread 16-03-2004, 18:31
There's a subtle point here - if the team extends beyond the border while attempting to hit the ball and misses the cage (accidental), then they are already penalized by not having their balls drop. But, if a team extends beyond the field and also gets the balls to drop, they are benefitting their position through the breaking of a rule, which is forbidden, so the extra penalty is warrented.
See the playing field in 3D Glasses General Forum 2 20-06-2005 20:57
Can we use tape if it contacts the playing field? archiver 2001 1 24-06-2002 01:01
Looking for full playing field archiver 2001 1 24-06-2002 00:13
playing field updates? archiver 2001 0 23-06-2002 23:03
Many inexpensive playing fields archiver 1999 5 23-06-2002 22:57
