Go to Post Water game. - dlavery [more]
Go Back   Chief Delphi > Technical > IT / Communications > Computer Graphics
Unread 17-03-2004, 07:45
Re: How do you upload an analog video onto a computer?
Originally Posted by Avarik
Hello, I am making a video for a school project, and I was wondering how to upload the analog video from my camera (Sony Handycam CCD-TRV308 NTSC) to my computer?
That's a Hi8 camcorder, so you're right about needing to capture analog video. The way to do it is with analog video capture hardware. You'll need either an external box or an internal card with analog video inputs. Such things come with software and instructions, and can cost between 50 and 500 dollars depending on quality and features.
It would be easiest for you to find a friend who has a computer with video capture capability. If you can't do that, visit a local computer store and see if you can find someone who understands what you want to do, and can recommend an appropriate solution.
Unread 18-03-2004, 00:19
Avarik Avarik is offline
Avarik is an unknown quantity at this point
Thank you very much!
Unread 18-03-2004, 01:15
evulish's Avatar
evulish evulish is offline
1010100
AKA: Grant Harding
#0084 (WATTNESS (bot: Chuck))
evulish is just really niceevulish is just really niceevulish is just really niceevulish is just really nice
Send a message via AIM to evulish
To list some products, an ATI All-in-Wonder card would do it, or a Hauppage WinTV (which won't be too great.. not really what they're made for), any of the products made by Pinnacle should be good. I'd recommend something like http://www.newegg.com/app/ViewProduc...144-019&depa=0 . That's probably the best bang for the buck. You can spend alot more, but those are pretty decent.
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
Unread 23-03-2004, 21:28
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
If you are getting an All-in-Wonder for a PC, stay away from the pre-Radeon models. They tend to have very little driver support, and are quite a pain to work with under both Windows and Linux.
At one time, I needed to transfer video from a camcorder to a PC and an adapter was not available. I used someone's digital camcorder and focused its lens on the viewfinder of the analog camcorder. The video quality was poor, but usable, so if you need to do this very cheaply....
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
Unread 23-03-2004, 21:30
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
my brain is all fuzzy right now and I can't think clearly, but if your camera has an ieee port (firewire) then you could always buy a firewire card at a local store. That is what i did for a school report a while back, just plug in the firewire and go to file: capture : movie capture in premiere then select ieee cable.
[edit] Now that i actually think about it, thats for digital video. bleh. I have an All-in-Wonder for that [/edit]
GizMOE Revealed - NEW VIDEO from team 365!! SuperJake Robot Showcase 14 25-03-2004 22:35
Projection TV's and Video Inputs (Xbox, Computer) MattK Chit-Chat 9 31-01-2003 00:53
List of UTC Hartford Teams archiver 2001 3 24-06-2002 01:09
Good video footage miketwalker General Forum 0 28-03-2002 17:14
A&E Special Amadkow Chit-Chat 4 11-08-2001 00:40
