Re: Non-Standard Broaching
If you have a non-standard keyway in a shaft and you want to use a standard piece of keystock, so you're thinking of using a non-standard key in the shaft, may I suggest looking into stepped keys? Essentially on different sides of the stock they are different widths. This may make your job a bit easier and a lot cheaper, if this is indeed why you want a bigger keyway. Matt |
We have standardized on 1/8" keys for 3/8 and 1/2 shafts. For smaller gears (12-14T) we cut only the first pass of the broach in the gear and cut the shaft keyway deeper. --For the 1/8" broach a shim is included, it takes two passes to cut full depth.--- We also cut the depth in the shaft at .063", this is a little shallow per Machinery's but works for this size shaft.
Sanddrag, those are the correct McMaster #'s. |
| White Paper Discuss: Standard Drive Photos | CD47-Bot | Extra Discussion | 5 | 20-11-2003 20:00 |
| Standard Operating Procedure | K. Skontrianos | General Forum | 7 | 01-03-2003 14:02 |
| Developing a standard | Jack | Scouting | 23 | 03-01-2003 23:04 |
| Seeding Calculations | archiver | 2000 | 50 | 23-06-2002 21:57 |
