Go to Post The first was a fish, all silver and spotted. “An opah?” I asked. “Yes,” my friend nodded. I knew not what it meant as I sat there and stared, But I appreciated the thoughts that the posters had shared. - Robotics692 [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 01-03-2004, 23:46
kacz100 kacz100 is offline
Battle Cattle!
#1466 (Webb Robotics)
kacz100 is on a distinguished road
Send a message via AIM to kacz100 Send a message via Yahoo to kacz100
Access Database help...
Currently I have tasked myself to create an Access database for scouting. I can easily create/delete fields quickly and do cool stuff BUT I am having 1 big problem. I want to put a picture of the robot next to the information I am gathering. After struggling for a couple days I have almost giving up. Access uses hand written code and I am lost at that. I have tried to borrow the code from other databases that do a smiliar thing, but nothing really works properly anything that would help would be appreciated. thanks!
Kacz
Team #40 Alumni 1999 - 2002
Team #885 College Student/Mentor 2003
Team #1466 College Student/Mentor 2004
Unread 01-03-2004, 23:58
gl75 gl75 is offline
AKA: Greg
#0075 (RoboRaiders)
gl75 is an unknown quantity at this point
Send a message via AIM to gl75
Re: Access Database help...
I'm not completely familiar with Access, but you could probably do one of 2 things:
- Upload the image data to a BLOB data type and store it directly in a field
or, since Access probably has a limited buffer...
- Upload the image to a directory and store the pathname in the field
Greg Liebowitz
Team 75 - RoboRaiders
Webmaster/Programmer
www.roboraiders.com
Unread 02-03-2004, 00:02
Battle Cattle!
I tried the BLOB thing and I can search for the file on the computer and save the pathname but cant display it next to the data collected.
Kacz
Unread 02-03-2004, 00:10
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
You would use an column of OLE Object data type. OR you can store the pictures in a directory with a common nameing convention (<teamnumber>.jpg) then use vba to retrieve and display that picture in a form.
Greg
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Unread 02-03-2004, 00:18
Battle Cattle!
How would I use vba to do that, I don't know how to code.
Kacz
Unread 02-03-2004, 12:38
I don't know (sorry), I'm not real big on visual basic. You can probably figure it out through google though, or use the microsoft access help and look up OLE.
Greg
Unread 03-03-2004, 13:46
Lindsey Lindsey is offline
Lindsey will become famous soon enough
I had this problem last year (I can't write code either)
I ended up figuring out how to put pictures in after the season was over.
1. Create a field in your table to hold the pictures (Design View)
2. Set the Data Type to OLE Object
3. Switch to Data Sheet view and right click in the cell instead typing in data
4. Select Insert Object
5. Select Create From File
6. Chose Browse and select the file or type in the location
The picture won't show up in Data Sheet view, you can only view the pictures through a form or a report
Hope this helps
Lindsey
Unread 17-03-2004, 15:45
Smrtman5's Avatar
Smrtman5 Smrtman5 is offline
Dr. Bridgeport
AKA: Jon H
FRC #0041 (Robo-wariors)
Smrtman5 is on a distinguished road
Send a message via AIM to Smrtman5
i am trying to make a scouting database for my palm, with dropdown menus. However, i dont know where to start. Hopefully someone could tell me what program to use and how to make a dropdown menu. Or if anyone has a program they could give me so i could add/ edit it, that would be great. Thanks
Art is just an excuse for poor craftsmanship.
- Jon H
Team 41
Rowan University '10 Mechanical Engineering
Unread 17-03-2004, 16:43
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
I know that last year Wildstang and the SigmaC@ts used a palm scouting database that you could load off of the wildstang site and download it all to SOAP. I don't know if they are doing it again this year but it would be an easier way to do it instead of making it yourself. I would check with Wildstang and SigmaC@t to see if they have it available again this year.
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 17-03-2004, 21:00
Greg's Avatar
Greg Greg is offline
FRC #1075 (Sinclair Sprockets)
Greg is on a distinguished road
Send a message via ICQ to Greg Send a message via MSN to Greg
This is an interesting problem I have done quite a lot of VB, so I wrote the code that shows an image of the robot on the form in an Access DB. Since you probably use a form for data entry/display, this should be what you want.
The only thing I wanted to point out is that the images are not actually stored in the database. The code only stores the path to the images. So they still have to sit on the hard drive in some folder. Why? Because Access is very inefficient at storing images and has a file size limit of around 1 GB. And this limit is reached very quickly with just a hundred JPEGs stored as OLE objects.
You can grab the example database off our web server here: http://www.sinclairsprockets.com/imagedb.zip. I hope you find it useful. And if you rename the database table you'll need to edit the code.
Unread 18-03-2004, 10:23
Greg's Avatar
I just found a very stupid bug in the DB I made yesterday Anyway, its fixed now and I uploaded the new version to the web site. If you already downloaded the old one please get the new version instead. Sorry
Unread 18-03-2004, 11:00
WCS V WCS V is offline
#1168 (Malvern Prep Robotics)
WCS V is an unknown quantity at this point
Type "Make It Work " and slam the keyboard repeatedly. - This usually works well for me.
WCS - Chief Technology Officer Malvern Prep Robotics #1168
"I can only do that in the code if its physically possible for it to happen."
Unread 18-03-2004, 19:18
Pierson's Avatar
Pierson Pierson is offline
Pierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of lightPierson is a glorious beacon of light
Send a message via AIM to Pierson
Hope this helps
Lindsey
One thing you will need to remember is that you will most likely need to resize the picture to something like 200x200 or 300x300.
I created our team's DB in access and got pictures working in January and I now have queries that figure out how long a person has been on a team, how much money they have brought in and other fun things.
If you have any questions, please feel free to PM or e-mail me: PC@BPRobotics.com.
Pierson
Former Captain & Fundraiser of Team 360
Join in on these fun threads:
Three Worded Story
Word Association
[IMG] code is Off
Scouting Database Robert Hafner General Forum 4 20-02-2004 23:37
ms access database starting point. swando Scouting 10 19-05-2003 16:47
Übergeeks scouting database, and the competitions Jeremy_Mc Scouting 10 09-03-2003 00:26
Playbook now included with Team 340 database archiver 2001 0 24-06-2002 01:33
We have to organize to win archiver 2001 18 24-06-2002 00:00
