Go to Post I'm frustrated by the world's reluctance to bend over backwards for FIRST. - Madison [more]
Unread 17-03-2004, 17:48
AsimC AsimC is offline
#0871 (West Islip Robotechs)
AsimC will become famous soon enough
Help! Programming question with triggers
its the day before competition and i really need help on this. Our team decided to make a trigger box for our robot and one trigger controls 2 motors. What i what it to do is, when i hold the trigger forward, the motors go forward, and when i let go the motor stops. For some reason i cant get it to work. What happens is, i hold the trigger forward and the motors continuely move even if i let go. Ive tried IF loops as well as FOR loops. Any suggestions? (as quickly as possible )
WEST ISLIP ROBOTECHS - Team 871
-2004 SBPLI REGIONAL CHAIRMANS AWARD WINNERS!
-2003 SBPLI Regional Finalists with 545 and 566
-2002 SBPLI Rookie All-Star
-Former Student Team Leader and Programming Head
Unread 17-03-2004, 18:21
bstempi bstempi is offline
Captain
#0708 (Hardwired Hatters)
Team Role: Student
bstempi is an unknown quantity at this point
Send a message via AIM to bstempi
Re: Help! Programming question with triggers
how do you have it wired up? From what you posted, it sounds like some sort of toggle switch you're using. Do you know what variables that coresponds to in the code?
Unread 17-03-2004, 18:27
JoshJ JoshJ is offline
#0316 (LuNaTeCs)
JoshJ is on a distinguished road
Send a message via AIM to JoshJ
See if u can post a copy of your code. I would stay away from FOR loops, all u should need to do is set the motors to something when ur trigger is forward, and set them to 127 when it is not. Also, see if you have any other code that assigns values to these motors.
you dont need an if statement
just something like
relay_fwd01 = p1_trig01; in your code
when the switch is on the relay is on, when its off, the relay goes off
Unread 17-03-2004, 18:47
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
just something like
If you have a victor, try this:
pwm01=p1_sw_trig*127+127;
Unread 17-03-2004, 18:48
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
If they are on PWMs, do something like:
if(switch == 1){
    pwm01 = pwm02 = 254;
else{
    pwm01 = pwm02 = 127;
Where pwm is the motor(s) and switch is the switch.
Unread 17-03-2004, 19:26
Xufer's Avatar
Xufer Xufer is offline
8 Seasons and as stable as ever
AKA: Working, 2/4 degrees complete still schooling...
FRC #1740 (The Cyber Colonels)
Xufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to beholdXufer is a splendid one to behold
Send a message via AIM to Xufer Send a message via MSN to Xufer Send a message via Yahoo to Xufer
i did mine like this
pwm03 = 127;  /*goal claw up and down*/
if (p2_sw_top)
{pwm03 = 195;}  /*half speed down*/
else if (p2_sw_trig)
{pwm03 = 59;} /*half speed up*/
If saftey is first and i put FIRST ahead of everything, then i must be the safest guy in the world.
Team 521 Alumni -- Team 1740 Mentor-- Go Go 1740!
Sometimes I think I've been doing this too long and other times I think I haven't done this enough... but all the times I'm sure I'm crazy
Photonics, It's Your Future
Unread 17-03-2004, 20:21
hmm this is how i originally did it...but it doesnt work. What happens is when i click the trigger, its constantly going forward even when i let go.
if (p3_sw_trig==1)
   pwm07=175;
   pwm08=175;
if (p3_sw_top==1)
   pwm07=90;
   pwm08=90;
Unread 17-03-2004, 20:26
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
if (p3_sw_trig==1)
   pwm07=175;
   pwm08=175;
else if (p3_sw_top==1)
   pwm07=90;
   pwm08=90;
else
   pwm07=127;
   pwm08=127;
try this... just beware if you push both the trigger and top button at the same time, it'll still go forward.
Unread 17-03-2004, 20:35
i forgot to say...it is a self centering toggle switch. Toggle forward is wired up to "trigger", and toggle back is wired up to "top" in code.
Anyways... Slimbojones when i was debugging my code, i tried something like that... and it didnt work. What happens is the 1 from p3_sw_trig is held in the code, so it never goes back to 0 and that means itll never go to neutral.
Unread 17-03-2004, 20:44
WebWader125
Posts: n/a
Did you try something like that, or did you try exactly what Slimbo posted? If you had two IF's but only one ELSE, it would probably behave how you've described.
One question I have: What happens when you push the toggle switch down? Do your motors actually run in reverse then? Or is forward the only direction that's working at all for you?
doy's Avatar
doy doy is offline
#1208 Ex-Lead Programmer
AKA: Jesse Luehrs
#1208 (The Super Critical Axe Men)
doy is on a distinguished road
Send a message via AIM to doy
if at the rest state of the switch, both outputs are 0, then his code should work... if not, then i dont think the switch will work for what you want it to do, as there would be no way to tell whether or not the switch was being pushed in a direction or at rest.
Unread 17-03-2004, 20:50
when i pull the toggle switch back...the motors do run in reverse...but again they do not stop even when i let go.
Unread 17-03-2004, 21:09
The Lucas's Avatar
CaMOElot, it is a silly place
Do your motors run at startup?
Robot Inspector
Unread 17-03-2004, 21:17
Greg's Avatar
Greg Greg is offline
FRC #1075 (Sinclair Sprockets)
Greg is on a distinguished road
Send a message via ICQ to Greg Send a message via MSN to Greg
Then its your switch. Just because it returns to center does not mean the switch is opened
Digital In Question Tom Bottiglieri Control System 5 02-03-2004 17:09
Urgent!! (programming question) anupalsingh Programming 6 25-02-2004 10:53
MIM's question of the day on programming. Gene F Programming 3 24-02-2004 16:32
C Programming Question tophq Programming 7 16-02-2004 12:56
Programming question archiver 2001 6 23-06-2002 22:57
