Go to Post Read it, Loved it, posted it on facebook! - wendymom [more]
Unread 17-03-2004, 18:11
Crazy_Ed's Avatar
Crazy_Ed Crazy_Ed is offline
Amature Progammer
AKA: Ed Orsi
#0710 (PAW)
Crazy_Ed has a little shameless behaviour in the past
Send a message via AIM to Crazy_Ed
Strange 16 bit MS-DOS subsystem error
Recently, I have tried to install 2 different compilers, both giving me this same error on startup and when I installed them. The error is not fatal but I just wanted to know what it means. FYI this is on a Win2k sp-2 gateway laptop. The error isn't specific to this program but this is the most recent:
"16 bit MS-DOS Subsystem"
C:\ldraw027.exe
SYSTEM\CurrentControlSet\Control\VirtualDeviceDriv ers. VDD. Virtual Device Driver format in the registry is invalid. Choose 'Close' to terminate the application.
I can either hit close or ignore. I hit ignore and the program runs fine.
I came, I programmed, I tore my hair out.
Unread 17-03-2004, 18:44
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Strange 16 bit MS-DOS subsystem error
C:\ldraw027.exe
Is this error come up when you install the compilers, or the new parts library (ldraw027.exe)? Partsref says you can just rename/delete the ldraw027.exe.
Unread 17-03-2004, 18:52
Crazy_Ed's Avatar
Amature Progammer
AKA: Ed Orsi
#0710 (PAW)
That doesn't quite work thought, anyone know anything about Virtual Device drivers?
Oh well time to go learn LDraw
Unread 18-03-2004, 07:25
AKA: Jamie Bliss
No. But with more info on the errors, we could help. (Like: what errors came up with the compiler installs?)
Unread 18-03-2004, 12:31
Crazy_Ed's Avatar
Amature Progammer
AKA: Ed Orsi
#0710 (PAW)
I've narrowed it down to whent it tries to open (suprise) any drivers for virtual divices. This includes emulating other OSs such as Dos to install programs. Lego Mindstorms, the NQC compiler, and LDraw are the latest.
I have Visual Studio Vb.net installed... prehaps that replaced something?
Unread 18-03-2004, 13:57
AKA: Jamie Bliss
I don't think so. I have VS 6.0 EE (VB, VC++, Visual FoxPro , and MSDN), and all the LDraw stuff works fine. Have you tried system restore to roll back your drivers? Was it just after you installed the compilers that you started getting problems? MPLAB and MCC18 work ok w/LDraw.
Is there some big windows thing you installed that would change the VXDs?
The registry refers to what you change when you run "regedit". Do you change something in there?
Can you reinstall the VXDs from the windows disk?
Anything else that we should know?
Unread 18-03-2004, 14:31
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Just as a note, I also have NCQ, LDraw, MPLAB/MCC18, and Visual Studio on my computer and it works fine. Sounds like something got accidentally removed from your Windows installation. (Windows... )
strange error Anthony Kesich Programming 2 25-02-2004 18:55
Extracting Individual bits in C Noah Programming 7 08-01-2004 15:53
Makin' a home-brewn dashboard program, and I need theory help! DanL Programming 33 05-07-2002 01:26
