Go to Post Roses are red Cyber is Blue With those sweet treads They simply cannot lose Team 234 - Andy Baker [more]
Unread 17-03-2004, 19:59
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
stdlib.h for Dashboard Program
So yeah, SBPLI is tomorrow, still ironing the bugs out of that Dashboard I have .
I think it's working perfectly, except for one tiny error. After a seemingly random (although rather precise) number of loops, fopen just doesn't work.
I have a line like this...
data = fopen("data.txt","w");
It's supposed to open a string to a file, works great, most of the time. After a certain number of loops though, it stops working, until I restart my program. This takes no more than 30 seconds to pop up, unacceptable for a Dashboard (5 minutes would be, but less than two minutes, no).
So, my question is, what other way (besides fstream) is there to output to a file? I need something that's rather generic and easy to implement, but at the moment, I'm open to any suggestions just so this thing will work. I'll even try using fstream again, but that took so long to convert everything from fstream to stdlib.h...
Speedy answers make me happy, cause I don't want to be up all night working on this :-p.
AIM --> Woloi
Email --> ian@woloschin.com
Unread 17-03-2004, 20:55
JimWright949's Avatar
JimWright949 JimWright949 is offline
The Owen Day of Seattle
AKA: Jim Wright
FRC #4542 (Titanium Talons)
JimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to behold
Re: stdlib.h for Dashboard Program
fopen opens a file for writing (in your case). You will only need to perform this once. To write a string into a file I would use fprintf(data,"Hello world");.
At the end of your program use a fclose(data); to close the file and flush the buffers out.
In other words you need a fclose(data); command for every fopen command you have. An nether fopen nor fclose is writting any data to a file.
-Jim
Unread 17-03-2004, 21:26
Is this what you are trying to do (in psuedo code)?
Read data from dashboard port (once every 1/38 second)
open file
write data to file
close file
repeat
It's possible after a thousand or so times of this, you are overflowing the buffer.
it may work better if you
open file
read data from dashboard port (once every 1/38 second)
write data to file
flush data (fflush)
repeat
close file
Unread 17-03-2004, 21:29
College? What?
Yeah, that's probably the answer.
I just converted it all over to fstream (and learned a bit about vs.NET), so I think it'll work like this for now. If I have any errors, I'll come back and try that fflush thing, cause I was running out of memory, so I'd bet that's the reason.
AIM --> Woloi
Unread 17-03-2004, 22:40
Neal Turett Neal Turett is offline
Neal Turett is on a distinguished road
Assuming you're using Windows, you could use API calls as an alternate to fstream. Fstream is probably simpler, this is just in case you can't use fstream for some strange reason.
The relevant functions are CreateFile, SetFilePointerEx, WriteFile, and CloseFile. All of these are in kernel32.lib and defined in winbase.h. To access them, simply include windows.h.
Unread 17-03-2004, 23:44
College? What?
I can use fstream, I had just redone my program to get rid of it cause it was acting funny, but by rewriting all of that code it fixed whatever problems I was having. Plus, I have about 9 or 10 hours till I have to use the program, so simpler is better :-).
AIM --> Woloi
2-week FIRST summer program @ WPI ColleenShaver General Forum 20 31-05-2009 03:02
how to add steps in the provided encoder program for the edu Zaramel2002 Programming 3 11-02-2004 08:35
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
Ahh! Program trick confusing! archiver 2001 9 24-06-2002 02:26
Credits for FIRST program. archiver 2000 6 24-06-2002 00:16
