Go to Post It wasn't about the ROBOT, or about whether I was male or female, it was about getting to compete in something that was just SO cool. - BandChick [more]
Unread 17-03-2004, 17:33
dddriveman's Avatar
dddriveman dddriveman is offline
Former Driver 1038, 979
AKA: Driveman
FRC #1038 (Thunderhawks)
dddriveman has a spectacular aura aboutdddriveman has a spectacular aura about
Send a message via AIM to dddriveman
Error message in MPLAB IDE
When i was trying to compile our final code i got this error message please help me.
Please help me!
leting intermediary files... done.
Executing: "C:\Program Files\MPLAB IDE\MCHIP_Tools\mplink.exe" -p=18F452 "ifi_startup.c" -fo="ifi_startup.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
MPLINK 3.50, Linker
Copyright (c) 2003 Microchip Technology Inc.
Error - unknown switch: -p=18F452
Errors : 1
Halting build on first failure as requested.
BUILD FAILED: Wed Mar 17 17:21:03 2004
"I'm sorry, after all he is just a wookie!"
Unread 17-03-2004, 17:41
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: Error message in MPLAB IDE
MPLINK 3.50, Linker
Errors : 1
It may be that either (a) your arguments for the linker got changed or (b) something happened to 18f8520user.lkr. (B was because the name is similar to the error. ) I looked at my settings for the linker and I have no idea what could have changed.
Sorry I can't help anymore.
Unread 17-03-2004, 17:43
Crazy_Ed's Avatar
Crazy_Ed Crazy_Ed is offline
Amature Progammer
AKA: Ed Orsi
#0710 (PAW)
Crazy_Ed has a little shameless behaviour in the past
Send a message via AIM to Crazy_Ed
I don't have much experience with the compiler/linker that you are talking about, but it seems that either of a few things happened:
1. You somehow entered a command line parameter to the linker
2. Something has been changed in the config file of the compiler
3. You entered some strange accidental command in "ifi_startup.c"
Thats all I can think of.
I came, I programmed, I tore my hair out.
Unread 17-03-2004, 17:47
dddriveman's Avatar
AKA: Driveman
I have not changed anything i am just trying to combine the files that i have.
Unread 17-03-2004, 17:56
it looks like somewhere you changed the target processor to the p=18F452
we are using the PIC 18F8520
maybe somewhere in the project setup / options/ custom - one of those pulldown menus?
was someone playing around with the MPLAB settings on you?
also ifi_startup.c has an include to another file, the ifi_default.h file which has an include for the picdef... file for the 18F8520 - maybe you opened one of these and entered a stay character somewhere?
are you sure your code is in the right directory?
if all esle fails, start a new directory with all the default code, and move only the files you intentionally edited into that directory - then the files you are not suppose to edit will be untouched.
Unread 17-03-2004, 19:04
dddriveman's Avatar
AKA: Driveman
I just found the problem we are missing the clib.lib file and the pic18f8520.lib files were can we find them?
Unread 17-03-2004, 23:04
dddriveman's Avatar
AKA: Driveman
Sorry guys still having trouble with all of this. I have no idea what i am doing. I'm trying to reinstall the program in an hopes to fix my error message. In case that doesn't work could someone please help me clean up the mess i created. P.M. me if you can help than i will give you the code.
Thanx
Thanx
Thanx
Unread 17-03-2004, 23:15
first thing, remember when you install the MPLAB SW you have to follow the directions on the innovationfirst website - DONT follow the directions that came with the CD or the tools wont run right
Unread 17-03-2004, 23:42
dddriveman's Avatar
AKA: Driveman
I don't have the CD i got it off of microchips website. Our instructor has the CD and he was not available today
Unread 18-03-2004, 00:02
dddriveman's Avatar
AKA: Driveman
ok i got MPLAB to compile almost but this is what i got.
Deleting intermediary files... done.
Executing: "C:\mcc18\bin\c18demo.exe" -p=18F8520 "ifi_startup.c" -fo="ifi_startup.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
A:\FrcCode\ifi_startup.c:1: Unable to open 'ifi_startup.i'
error -1 spawning C:\mcc18\bin\cpp18
Executing: "C:\mcc18\bin\c18demo.exe" -p=18F8520 "user_routines_fast.c" -fo="user_routines_fast.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
A:\FrcCode\ifi_aliases.h:18: unable to locate 'adc.h'
error 1 spawning C:\mcc18\bin\cpp18
Executing: "C:\mcc18\bin\c18demo.exe" -p=18F8520 "ifi_utilities.c" -fo="ifi_utilities.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
A:\FrcCode\ifi_utilities.c:1: Unable to open 'A:\FrcCode\ifi_utilities.err'
Executing: "C:\mcc18\bin\c18demo.exe" -p=18F8520 "main.c" -fo="main.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\c18demo.exe" -p=18F8520 "printf_lib.c" -fo="printf_lib.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
A:\FrcCode\printf_lib.c:1: Unable to open 'A:\FrcCode\printf_lib.err'
Executing: "C:\mcc18\bin\c18demo.exe" -p=18F8520 "user_routines.c" -fo="user_routines.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
A:\FrcCode\user_routines.c:1: Unable to open 'user_routines.i'
Executing: "C:\mcc18\bin\c18demo.exe" -p=18F8520 "uread.c" -fo="uread.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
C:\mcc18\src\pmc\USART\18Cxx\uread.c:2: unable to locate 'p18cxxx.h'
C:\mcc18\src\pmc\USART\18Cxx\uread.c:3: unable to locate 'usart.h'
Skipping link step. Not all sources built successfully.
BUILD FAILED: Thu Mar 18 00:01:12 2004
Unread 18-03-2004, 00:10
doy's Avatar
doy doy is offline
#1208 Ex-Lead Programmer
AKA: Jesse Luehrs
#1208 (The Super Critical Axe Men)
doy is on a distinguished road
Send a message via AIM to doy
make sure the disk isnt write protected... i would suggest not trying to compile something directly on a floppy in the first place, from a speed standpoint alone. also, make sure the include, library, and linker directories are specified correctly in project options.
Unread 18-03-2004, 06:34
Programming User
First, if you have another computer, try reinstalling on that, as the installer messes up (at least in my experience) if there was a previous installation. If there isn't, uninstal the program and remove any reference to anything to do wit h MCC18 in the PATH environment variable. (To see that, open a run box and type "msconfig".)
Another thing, make sure to check all the boxes that apear during the compiler installation, especially the one that says "Configure MPLAB to work with this version of MCC18" or something like that.
Development enviroments orther than MPLAB wun Programming 36 29-04-2004 21:20
MPLAB Variable Simulator? Chris_Elston Programming 3 18-02-2004 12:08
If you're having MPLAB problems, LOOK HERE. Jeremy_Mc Programming 0 20-01-2004 18:06
MPLAB IDE Project Specs Raven_Writer Programming 18 19-01-2004 15:53
using the MPLAB IDE MPLAB SIM simulator WizardOfAz Programming 1 03-11-2003 01:24
