Go to Post What is this "tired" of which you speak? Did it come in the KOP? - EricH [more]
Unread 18-03-2004, 00:25
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
IFI's Serial Programs Doing Funny Stuff?
I've written my own Dashboard, and when I try to use it after using either IFI program on the same computer, without rebooting, my dashboard never works. I have no idea why or how, but apparently IFI's programs do something funny to the serial port? I never had this problem before, so it's definitely something with IFI's programs (I used a similar Dashboard last year with no problems).
Has anyone else experienced similar difficulties, or know anything about why this may be?
AIM --> Woloi
Email --> ian@woloschin.com
Unread 18-03-2004, 06:07
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: IFI's Serial Programs Doing Funny Stuff?
If another serial program is still running, it doesn't allow the second one to access the port. Did you leave the IFI one running?
Unread 18-03-2004, 06:49
College? What?
No, I closed the IFI Loader (version 1.0.7), waited a couple of seconds for the computer to end the program (old computer), and then started mine up, and it was unable to correctly read the serial port. Most data was garbage, some was correct but in the wrong spots, and so on. Not of any use to me.
AIM --> Woloi
Unread 18-03-2004, 07:08
sounds like your program and the IFI program are configuring the ports differently - using HW flow control or not using it - somehow changing the port driver, or the IFI program has not released the port completely when its closed.
Unread 18-03-2004, 21:43
College? What?
I actually talked to the IFI guy at SBPLI, and he put me on the phone with the IFI software guy, and he's sending me some stuff to work with, so hopefully I can work this out sooner than later.
AIM --> Woloi
Some FIRST Humor...This is pretty funny stuff. archiver 2000 1 23-06-2002 22:40
