Globe motor - no lubrication in gears!
One of our Globe motors was making a grinding noise after a tough match, so I dismantled it. The 2 sets of planetary gears inside were completely dry - with only dried residue of whatever grease was put in during manufacture.
It runs much smoother and quieter now after I added some lubricant (Honda Moly 60 grease). To dismantle the gearbox you push the three small roll-pins around the circumference all the way into the gearbox. You can then pull the gearbox off the motor. To reassemble, you push the roll pins back in from the outside. |
Re: Globe motor - no lubrication in gears!
JS,
This is highly unusual. Dried out lubricant in these motors is usually a sign of overheating or being stored at an elelvated temperature. The type of lubricant you use also affects the running current and free speed so be aware of those changes. |
| What type of steel are gears commonly made from? | Matt Adams | Technical Discussion | 5 | 02-01-2004 23:19 |
| Helical gears that come with new drill motor | Joe P | Technical Discussion | 4 | 12-01-2003 11:09 |
| So you want to stall a Globe Motor... | archiver | 2000 | 1 | 24-06-2002 00:09 |
| Globe Motors & other FIRST Suppliers at Design Show | archiver | 1999 | 2 | 23-06-2002 22:07 |
| Need help! What kind of gears are we allowed to use?? | Randy_Ai | Technical Discussion | 3 | 23-01-2002 22:56 |
