Go to Post Over Weight. What else is to be expected? There is still time for the diet team to perform miracles. Meanwhile I still keep adding parts. - Steve W [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 20-03-2004, 00:00
jhnphm jhnphm is offline
jhnphm is an unknown quantity at this point
Re: CSS Based Design
This guide assumes knowledge of regular expressions.
IThe mod_rewrites on my local copy of the site (out of date by two months, and I stripped out redundant statements that weren't needed because of the usage of the <base> element) and commented are:
 #Syntax is "RewriteRule [URL RegExp] [Replacement with optional back references [[Flags]]"
 RewriteRule ^/$ /robotics/ [R,L]
 #Redirects http://localhost/ to http://localhost/robotics
 #R flag redirects, L prevents fall through to statements below
 RewriteRule ^/robotics/pages/(.+)$ /robotics/index.php?file=pages/$1.inc [L]
#Using W3 recommended URIs, which makes it more difficult to rewrite URIs, since there is the problem of what to rewrite to. This has been solved by dumping all pages under the /robotics/pages directory, and use the <base> element to shift the initial path for relative URIs to just /robotics/ . All the "pages" are files with the .inc extension which are included into PHP. The scripts filter for the .inc extension for security purposes.
Unread 25-03-2004, 22:03
HFWang's Avatar
HFWang HFWang is offline
AKA: DarkWulf
#0115
Team Role: Webmaster
HFWang will become famous soon enough
Send a message via ICQ to HFWang Send a message via AIM to HFWang
My rewrite file looks like the following...
RewriteEngine On
RewriteRule ^images(.*)$ images$1 [S=1]
RewriteRule ^(.*)/$      ?path=$1 [L,NS,QSA]
Just so you know, this rewrites EVERYTHING. The rewrite rule for images marks the image folder as being directed to that folder (and then skipping the following rule, so it doesn't run into the other rewrite). This way everything is passed into your CMS and it can handle everything for you.
I then wrote a custom CMS solution for the site that could then parse $_GET['path'] and return the appropriate page...
rawr
Unread 29-03-2004, 01:20
Just added a style switcher at the bottom of our page. 188 has a nice website. In retrospect our website's navigation is rather bad.
Unread 08-04-2004, 22:03
RyanIdium RyanIdium is offline
RyanIdium is an unknown quantity at this point
try http://www.w3schools.com/css/default.asp .
Unread 07-05-2004, 19:46
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
Brandon,
That's a great list. Lots of good info there. If I may, I have two to add...
#1 The Zen Garden . This really awakened me to to POWER of CSS. Click on the designs on the right side of the page, They will load up different CSS files using the same html file. Really cool.
#2 Webmaster World . This is a News and Discussion for the Independent Web Professional site. It is a great community forum like Chiefdelphi dedicated to web issues. It's free to register for the public side. There are forums dedicated to all web subjects including a terrific CSS forum. Post a question and someone will toss out an answer. There is a non-public side, that deals with the business side of the web that makes really interesting reading. It's good community, very much like we have here.
jb
Design Sharing Rod General Forum 32 14-01-2004 22:00
Roller Chain Based Three Speed Transmission Madison Technical Discussion 11 09-01-2004 16:40
How do you design your robot? Gui Cavalcanti General Forum 23 16-11-2003 18:33
gearing design calculation question caffel Motors 4 24-03-2003 17:34
Ok, so YOU design the 2003 game... dlavery General Forum 157 07-01-2003 23:55
