Go to Post Congrats! You are an inspiration to us all! - preussrobotics [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > You Make The Call
View Poll Results: You Make The Call
I disqualify Bluabot 8 20.00%
I disqualify the Blue Alliance (Bluabot's team) 1 2.50%
I disable Bluabot 5 12.50%
I throw one penalty flag 7 17.50%
I throw so many flags that I run out of flags and have to count on my fingers 8 20.00%
No problem ... I do nothing 6 15.00%
I jump in the arena and free Redabot from the jaws of Bluabot 5 12.50%
Voters: 40. You may not vote on this poll
Unread 20-03-2004, 07:09
Re: YMTC: Bluabot dies while pinning
the reason I asked is I dont think this could happen in real life, unless the bot that was pinned had globe motors for a drivetrain
and if a bot was that weak you wouldnt waste your time pinning it - and you certainly wouldnt hit the Estop button to 'pin' a weak bot
and I cant imagine a team hitting the Estop as part of their strategy for any reason - you just dont know what the other team will do, but your bot will be dead for certain till the match is over.
Unread 20-03-2004, 15:32
Andy A. Andy A. is offline
Getting old
FRC #0095
Acutally Ken, I belive that it would be very easy to pin a bot in such a manner that it could never get out.
Even a bot with only a two drill motor drive train that was shut down could pretty easily do it. All you have to do is get your wheels perpendicular to thiers (imagine a 'T'). That way, the motors free wheeling have no effect on it, the pinned bot has to have the power to either slip the pinning wheels sidways (which depends on the wheel type and number of them) or otherwise tip the bot. The pinned bot would have no room to turn sideways, so unless it can crab, it's only choice is to try to push the pinning 'bot out of the way.
I've tried pushing my teams bot from the side. It only has two wheels powered by drill motors. Unless I pushed at the corners or fairly high up, she didnt budge an inch. A four wheel drive would be just about impossible for me to have moved, and I have the benifet of arms and and extra 30 pounds of weight on a FIRST bot.
I think this situation could happen.
-Andy A
Unread 20-03-2004, 15:57
but you cant push a bot up against a wall if your wheels are perpendicular to theirs, you would not be able to apply any force against the other bot to pin it?
and if there was the slightest bit of space to move the pinned bot could rock back and forth and use its momentum to push you away.
but to go back to the original question, if you continue to pin a bot, whether you are powered or not, you get a 10 point penaly every 10 seconds
which means you would pretty much lose the match - which is how it should be since pinning another bot for a minute or two is against the spirit of the game (thats why we HAVE the penalties - you keep doing it, you keep getting penalties and you lose!)
Unread 20-03-2004, 17:21
Jeff_Rice's Avatar
Jeff_Rice Jeff_Rice is offline
ElementisRegamusProelium
#1359
Jeff_Rice will become famous soon enoughJeff_Rice will become famous soon enough
What if the penalties cause the points to go negative? You are hurting both alliances if you continue to throw flags.
"He said my name is Private Andrew Malone
If you're reading this then I didn't make it home
But for every dream that's shattered another one comes true
This car was once a dream of mine now it belongs to you
And though you may take her and make her your own
You'll always be riding with Private Malone" David Ball, "Private Malone"
Unread 20-03-2004, 17:36
penalties always hurt the winnings teams qualifiacation points (is that the right word? for the losers score)
but the bottom line is the penalized team will lose the match.
Unread 20-03-2004, 17:57
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
It's somewhat disappointing that a fully functioning RED robot cannot push a completely dead BLUE robot.
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 20-03-2004, 18:34
ok this ones been beaten to death
got another one? the Kangaroo court is still in session! :^)
Unread 20-03-2004, 18:43
Yan Wang's Avatar
Ithaca is Gorges
AKA: John Wayne
I correct myself.... If "Bluabot starts to let out the magic smoke from their drive motors...", then I would probably run for a fire extinguisher and stop the match. That's MY call.
Unread 20-03-2004, 21:12
Natchez Natchez is offline
#0118 (Robonauts)
Natchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond repute
Posted by Ken
ok this ones been beaten to death ... got another one?
Let's let this one ride for a while. The CD community is very knowledgeable about the rules and the votes on this one are all over the place. Here is how they stack up so far.
4 for I disqualify Bluabot
1 for I disqualify the Blue Alliance
2 for I disable Bluabot
5 for I throw one penalty flag
6 for I throw so many flags that I run out of flags and have to count on my fingers
5 for No problem ... I do nothing
4 for I jump in the arena and free Redabot from the jaws of Bluabot
This is great example of why being a FIRST ref is so difficult.
Also, I would urge us not to get too deep into whether a situation is likely. The first YMTC was very unlikely but it did address a certain rule. Remember, let's just have fun with this and see where it goes.
With all that written, there is nothing to say that multiple YMTCs can not run simultaneously. I'll come up with another one in a few minutes.
Thank you all for participating,
Lucien
Unread 21-03-2004, 11:33
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
It seems to me tha if the motors begin to smoke, etc. the robot would be disabled to prevent damage to the machine or to prevent a fire.
Just a thought,
-Pat
Team Discovery #134 Alumni 1999-2004
Division by Zero #229 Alumni 2004-2009
Team Discovery again?
2010 and Beyond
Where have the last 11 years have gone?
YMTC: Redabot grabs rail Natchez You Make The Call 10 10-04-2004 12:16
