Go to Post ...I'm still waiting for a Chiefdelph-aholics group to form at the local YMCA. - KelliV [more]
Unread 20-03-2004, 12:08
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
When good robots go bad...
or, "When Your Ambitious Plans Don't Quite Work Out."
It seemed to me that, as I posted photographs of my team's robot, most people didn't completely grasp its design intent. I was purposefully a bit vague; both because it was fun and because we knew that the design was ambitious and just might not work.
I thought it'd be fun to share this photo that I came across in our gallery that shows the robot as it was intended to operate.
I hope that the team can make it work for the Championship, because it sure would be nice to see it deployed out on the field like that just once..
So -- does anyone else care to share their stories about what their robot was
supposed to do this year or years passed? I think it's sometimes fun to see how we find alternate functions for mechanisms or pare down our design strategies when our ambition exceeds our current abilities
--Madison--
...down at the Ozdust!
Unread 20-03-2004, 12:13
Re: When good robots go bad...
ok I give up - what was it suppose to do?
is the yellow hose part of the bot or are they taking a pneumatic chisel to your machine?
is the ball suppose be on your goal or the opponents? to score or to block?
does that bear-trap thing stay on the ball?
Unread 20-03-2004, 12:14
Tyler Olds Tyler Olds is offline
FUN Show Host
no team (First Updates Now)
Tyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond repute
How long did that take to get off the bar???? Very cool design though, multi tasking objectives is very complex.
First Updates Now Show Host.
Watch and Listen to FUN on Youtube, iTunes, and www.firstupdatesnow.com
FRC Emcee 2009-2016: Team 2826 Wave Robotics Lead Mentor 2001-2004 Team 93 NEW Apple Corps Alumni
CD Moderator
Unread 20-03-2004, 12:21
Madison's Avatar
FRC #0488 (Xbot)
The arm telescopes to ~12' long, allowing it to reach just beyond the stationary goals. It can also rotate 360*, allowing it to reach anywhere in the middle of the field, essentially.
The ball claw (I don't know if that was the final design, for what it's worth) is raised and lowered on a winch, allowing it grab balls from as high as the stationary goals and as low as the floor.
Tyler -- it took twelve people to get it down, but I'm not sure how long it took them
--Madison--
Unread 20-03-2004, 12:54
Kevin Kolodziej's Avatar
Happy Birthday! Kevin Kolodziej Kevin Kolodziej is offline
Operator in 100+ matches
AKA: Yngwie Kamen's roadie
Kevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond repute
Send a message via AIM to Kevin Kolodziej
Team 1064 had a very ambitious initial design. We were going to have the base that we have now with a pair of uprights on the large wheel side. These uprights would support an arm mechanism that could rotate from front to back of the robot and slide up and down the uprights. This arm would be able to grab large balls and cap goals. The arms would also have hooks on the end of them for the hang - part of the reason they move up and down. The other reason to move up and down was so that we could cap our robot - we had planned on having a basket on the rest of the robot that would actually hold two large balls (I told you it was ambitious!). The design worked out out so that the basket would fold out and be just large enough for the balls, yes still leave room for the arms to grab a third large ball and hold it anywhere on the robot. The basket was also going to have a roller at the bottom so that small balls that were captured during the ball dump could be fed to the human.
Looks a bit different now, doesn't it??) www.firstwildbeast.com
-Kev
Team 71: 1999, 2000 (Driver), 2001-2002 (Driver, Animator) // Team 1064: 2003 (Co-founder, Coach), 2004 (Coach) // Team 1714: 2006-2007 (Mentor, Coach)
Team 1675: 2005-2007 (Mentor, Coach), 2008 (Mentor), 2009-2017 (Mentor, Coach)
FLL: '04 (Judge), '05 (Ref), '06 (Ref), '07 (Ref), '08 (Judge, Ref), '09 (Judge), '10 (Ref), '16 (Judge Advisor) // Ref: '05 (IN, IRI), '06 (IN, IRI), '07 (IN, IRI), '08 (WMR, Curie)
WI RPC: 2006 - 2016 // FRC Inspector: '07 (WI), '08 (WI, IL), '09 (WI, IL), '10 (WI, CMP), '11 (WI, IL, CMP), '12 (WI), '13 (Northern Lights)
2007 WI Woodie Flowers Award Finalist // 2011 Wisconsin Regional Outstanding Volunteer // 2011/2013 Midwest Regional Chairman's Award
Unread 20-03-2004, 15:45
Crash852 Crash852 is offline
Member
FRC #0492
Team Role: Student
Crash852 is on a distinguished road
yep, the yellow tube part dangling down is originally supposed to be able to manipulate the 2x multiplier balls, but i don't think it worked out very well for them.
Unread 20-03-2004, 18:54
IMDWalrus's Avatar
IMDWalrus IMDWalrus is offline
This is a line...
AKA: Paul
FRC #0818 (Genesis '02)
IMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to behold
Send a message via AIM to IMDWalrus
Well...we were planning on having a robot that could herd balls (via extending plow arms from the front of our robot), grab the multiplier (gigantic claw on a forklift-esque mechanism), and hang (the top part of the claw had a hook on its end).
We didn't get the multiplier OR hang once during Detroit, and we weren't all that great at gathering balls. In short, nothing worked right. Our robot is a failure...
Unread 20-03-2004, 19:55
no it cant be that bad
are you going to any more events?
post some photos of your bot - maybe we can brainstorm some ideas on line
Hey Dude!
dont make it bad
take a sad bot
and make it better
the movement you need is on your shoulder (I dont know what that line means, and neither did Paul :^)
pic: When Good Metabolism Goes Bad. CD47-Bot Extra Discussion 24 17-05-2003 21:10
college counseling decides to help us... good or bad? AlbertW General Forum 4 16-05-2003 15:14
Radisson Inn Astrodome Mike Martus Championship Event 49 13-05-2003 21:03
good idea or bad? archiver 2001 4 23-06-2002 23:08
Another idea looking for comments archiver 1999 16 23-06-2002 22:01
