| View Poll Results: You Make The Call | |||
| I disqualify Bluabot |
8 | 20.00% |
| I disqualify the Blue Alliance (Bluabot's team) |
1 | 2.50% |
| I disable Bluabot |
5 | 12.50% |
| I throw one penalty flag |
7 | 17.50% |
| I throw so many flags that I run out of flags and have to count on my fingers |
8 | 20.00% |
| No problem ... I do nothing |
6 | 15.00% |
| I jump in the arena and free Redabot from the jaws of Bluabot |
5 | 12.50% |
| Voters: 40. You may not vote on this poll | |||
Re: YMTC: Bluabot dies while pinning
but you cant push a bot up against a wall if your wheels are perpendicular to theirs, you would not be able to apply any force against the other bot to pin it?
and if there was the slightest bit of space to move the pinned bot could rock back and forth and use its momentum to push you away. but to go back to the original question, if you continue to pin a bot, whether you are powered or not, you get a 10 point penaly every 10 seconds which means you would pretty much lose the match - which is how it should be since pinning another bot for a minute or two is against the spirit of the game (thats why we HAVE the penalties - you keep doing it, you keep getting penalties and you lose!) Last edited by KenWittlief : 20-03-2004 at 15:59. |
What if the penalties cause the points to go negative? You are hurting both alliances if you continue to throw flags.
penalties always hurt the winnings teams qualifiacation points (is that the right word? for the losers score)
but the bottom line is the penalized team will lose the match. |
It's somewhat disappointing that a fully functioning RED robot cannot push a completely dead BLUE robot.
ok this ones been beaten to death
got another one? the Kangaroo court is still in session! :^) |
I correct myself.... If "Bluabot starts to let out the magic smoke from their drive motors...", then I would probably run for a fire extinguisher and stop the match. That's MY call.
#7
4 for I disqualify Bluabot 1 for I disqualify the Blue Alliance 2 for I disable Bluabot 5 for I throw one penalty flag 6 for I throw so many flags that I run out of flags and have to count on my fingers 5 for No problem ... I do nothing 4 for I jump in the arena and free Redabot from the jaws of Bluabot This is great example of why being a FIRST ref is so difficult. Also, I would urge us not to get too deep into whether a situation is likely. The first YMTC was very unlikely but it did address a certain rule. Remember, let's just have fun with this and see where it goes. With all that written, there is nothing to say that multiple YMTCs can not run simultaneously. I'll come up with another one in a few minutes. Thank you all for participating, Lucien |
#8
It seems to me tha if the motors begin to smoke, etc. the robot would be disabled to prevent damage to the machine or to prevent a fire.
Just a thought, -Pat |
| YMTC: Redabot grabs rail | Natchez | You Make The Call | 10 | 10-04-2004 12:16 |
