Go to Post It doesn't matter if you write a thousand lines of code for a robot, if you didn't teach and/or inspire the HS students as you did it then you are not a mentor. - JamesBrown [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > You Make The Call
View Poll Results: You Make The Call
I disqualify Bluabot 8 20.00%
I disqualify the Blue Alliance (Bluabot's team) 1 2.50%
I disable Bluabot 5 12.50%
I throw one penalty flag 7 17.50%
I throw so many flags that I run out of flags and have to count on my fingers 8 20.00%
No problem ... I do nothing 6 15.00%
I jump in the arena and free Redabot from the jaws of Bluabot 5 12.50%
Voters: 40. You may not vote on this poll
Unread 19-03-2004, 22:58
Natchez Natchez is offline
#0118 (Robonauts)
Natchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond repute
YMTC: Bluabot dies while pinning
You Make The Call (YMTC) is a series of situations where you can play ref and make a call. YMTC situations are not meant to represent situations that have occurred at competitions.
With 1:30 remaining in the finals, Redabot is pushing balls into the their chute. Bluabot (Redabot's opponent) pins Redabot in the corner. Bluabot starts to let out the magic smoke from their drive motors and dies. At 1:20, the referee warns the Bluabots to back off of the Redabots. Since Bluabot has died, the drivers can't move Bluabot and Redabot can't get out of the corner. The game ends with Bluabot pinning Redabot.
YOU MAKE THE CALL! Do you ...
Please base your ruling on the 2004 rules. If you find a specific rule that addresses this situation, please share it with everyone.
Unread 19-03-2004, 23:15
Mike M. Mike M. is offline
insert custom title here
Mike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant futureMike M. has a brilliant future
Re: YMTC: Bluabot dies while pinning
I throw so many flags i run out and have to count on my fingers.
<G27> A robot cannot pin (inhibit the movement of another robot while on the carpet) for more than 10
seconds. If a robot has been pinned for 10 seconds, the team with the pinning robot will be told by
the referee to release the robot and back away approximately 3 feet. Once the pinning robot has
backed off by 3 feet, it may again attempt to pin its opponent and, if successful, the 10 second count
starts over.If a referee determines this rule to be violated, a 10-point penalty flag will be thrown for
each violation.
Gael Force 126 2003-2004 Mechanical, Pit Crew, Grady's #2
T-Hawks 1100 2005-2007 Mechanical, Driver, Coach
Rhodewarriors 121 2007 IRI Operator
PiraTech 2023 2008 Mechanical, Coach
Gael Force 126 2009-2010 Mechanical, Photographer
Current [RIDE] Volunteer Coordinator
Unread 19-03-2004, 23:46
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer &amp; Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
each violation.
While this rule does have some point to it. It states nothing about that if the pinning robot is unable to move itself under its own power. This usually isn't a tough call. The pinning side gets warned if it doesn't adhere to the warnings then it gets disabled. That's perfectly made clear. However If Blue pins Red and somehow Blue loses power on its own or the motivation of it (Drill motors / sprockets etc....) breaks then the rule should have some penalty just not that extensive as a perfectly fine working blue robot will get full penalty.
If the robot cannot move its not the teams fault for it not moving. It stopped on its own. however he shouldn't have been there in the first place and backed off sooner.
I would probably call that match and do a match replay at the end of the day or b4 lunch. Just to be fair. or giving the pinning aliance a slight penalty cause they did try to back off and there robot stopped working as it was doing so.
Call the match and have it replayed at a more convient time should be another option for a similar situation like this in the YMTC series
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 19-03-2004, 23:52
Will Hanashiro Will Hanashiro is offline
GM/Kettering Mentor
FRC #0322 (F.I.R.E)
Will Hanashiro is just really niceWill Hanashiro is just really niceWill Hanashiro is just really niceWill Hanashiro is just really niceWill Hanashiro is just really nice
Send a message via AIM to Will Hanashiro
hmmmm... this is a tuffy! i say that its one penalty flag, and only one. the penalty flag is for the original pin, but no other flags should be thrown because they had no possible way to back away.
West Michigan Regional #1 Seed
2006 GLR Motorola Quality Award
2006 WMR GM Industrial Design Award
Kettering University ME Class of 2009
Unread 20-03-2004, 00:12
did this actaully happen in a match? it would seem unlikely that a dead robot could continue to pin a live one - once a bot goes dead its motors freewheel fairly easy and the other bot should have no problem wiggling free
Unread 20-03-2004, 00:23
Andy A. Andy A. is offline
Getting old
FRC #0095
Not once in the rule book does it say that you can have a rematch because you're drive train died. I wouldn't expect one for my team, and I wouldn't ask for one. The only reason to restart a match is because of a problem with the field.
Obviously, bluabot is inviolation of the rules.
The tricky part is just when to throw flags. As far as the rules are concerned, the ref has discrection here. Since as soon as the ref tells the team to back off, and they don't, they are violating the rule. But do they only violate it once? Or do they violate the rule every time the ref decides to tell them to back off? Trickey question.
If I were reffing, I would throw flags at ten second intervals untill the time ran out or the red bot was able to free it's self.
Again, it is up to each team to build a robust 'bot (getting sick of hearing that yet? I am). If your bot breaks down while trying to do something that could potentialy cause a penalty, then tough luck. That is part of the risk you take when pinning.
Just hope that all those penaltys don't make you lose the match!
-Andy A.
Unread 20-03-2004, 01:16
TF8 TF8 is offline
AKA: Tyler Forbes
#0190 (Gompei and the Herd)
TF8 is on a distinguished road
Send a message via AIM to TF8
How would everyone feel if the bluadarobot disabled their robot with the e-stop as they were pinning the red robot? As far as the rules state it seems the one 10pt penalty is worth taking out the number one seed as cheap as it would be.
This is solely the opinion of me and only me, my posts represent my personal views only, and do not represent the views of either my team, nor its sponsors.
Tyler Forbes
Unread 20-03-2004, 01:17
#0118 (Robonauts)
Posted by Ken
Original YMTC Post
Ken, I have intentionally tried to stay away from situations that have happened to teams. YMTC is just a way for CDers to "play ref" for a moment. I started this so people could talk about the rules without a specific team being caught in the middle. Some YMTCs will be, as Yan put it, not ambiguous at all and some will create for a lively discussion.
Lucien
Unread 20-03-2004, 07:09
the reason I asked is I dont think this could happen in real life, unless the bot that was pinned had globe motors for a drivetrain
and if a bot was that weak you wouldnt waste your time pinning it - and you certainly wouldnt hit the Estop button to 'pin' a weak bot
and I cant imagine a team hitting the Estop as part of their strategy for any reason - you just dont know what the other team will do, but your bot will be dead for certain till the match is over.
Unread 20-03-2004, 15:32
Getting old
FRC #0095
Acutally Ken, I belive that it would be very easy to pin a bot in such a manner that it could never get out.
Even a bot with only a two drill motor drive train that was shut down could pretty easily do it. All you have to do is get your wheels perpendicular to thiers (imagine a 'T'). That way, the motors free wheeling have no effect on it, the pinned bot has to have the power to either slip the pinning wheels sidways (which depends on the wheel type and number of them) or otherwise tip the bot. The pinned bot would have no room to turn sideways, so unless it can crab, it's only choice is to try to push the pinning 'bot out of the way.
I've tried pushing my teams bot from the side. It only has two wheels powered by drill motors. Unless I pushed at the corners or fairly high up, she didnt budge an inch. A four wheel drive would be just about impossible for me to have moved, and I have the benifet of arms and and extra 30 pounds of weight on a FIRST bot.
I think this situation could happen.
-Andy A
Unread 20-03-2004, 15:57
but you cant push a bot up against a wall if your wheels are perpendicular to theirs, you would not be able to apply any force against the other bot to pin it?
and if there was the slightest bit of space to move the pinned bot could rock back and forth and use its momentum to push you away.
but to go back to the original question, if you continue to pin a bot, whether you are powered or not, you get a 10 point penaly every 10 seconds
which means you would pretty much lose the match - which is how it should be since pinning another bot for a minute or two is against the spirit of the game (thats why we HAVE the penalties - you keep doing it, you keep getting penalties and you lose!)
Unread 20-03-2004, 17:21
Jeff_Rice's Avatar
Jeff_Rice Jeff_Rice is offline
ElementisRegamusProelium
#1359
Jeff_Rice will become famous soon enoughJeff_Rice will become famous soon enough
What if the penalties cause the points to go negative? You are hurting both alliances if you continue to throw flags.
"He said my name is Private Andrew Malone
If you're reading this then I didn't make it home
But for every dream that's shattered another one comes true
This car was once a dream of mine now it belongs to you
And though you may take her and make her your own
You'll always be riding with Private Malone" David Ball, "Private Malone"
Unread 20-03-2004, 17:36
penalties always hurt the winnings teams qualifiacation points (is that the right word? for the losers score)
but the bottom line is the penalized team will lose the match.
Unread 20-03-2004, 17:57
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
It's somewhat disappointing that a fully functioning RED robot cannot push a completely dead BLUE robot.
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 20-03-2004, 18:34
ok this ones been beaten to death
got another one? the Kangaroo court is still in session! :^)
YMTC: Redabot grabs rail Natchez You Make The Call 10 10-04-2004 12:16
