Go to Post ....FIRST helped me realize how much i enjoy engineering, so that i NEED to do well in my classes if i want to reach my goals. - the_short1 [more]
Unread 20-03-2004, 12:42
Kevin Karan's Avatar
Kevin Karan Kevin Karan is offline
Linux Guy
AKA: maxdamage
None #0174 (Arctic Warriors)
Kevin Karan will become famous soon enoughKevin Karan will become famous soon enough
Send a message via AIM to Kevin Karan
size limitations D:
Is there any way to finish the link even even if your over your size limit so you can look at the map and see how much you need to shrink your code?
It isnt ALWAYS the programmers falt!
2004: Buckeye team website award
2002: Rutgers semi-finalists
2001: National semi-finalists
2001: Rutgers semi-finalists
1998: Manchester Rookie All-Star Award
Unread 20-03-2004, 12:46
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: size limitations D:
Try changing the memory model. (Go Project->Options->All Files (or something like that. I'm on a computer that doesn't have MPLAB, so I don't know.) and find the setting for the linker that deals with the memory model size.) Hope that helps.
Unread 20-03-2004, 13:05
Linux Guy
AKA: maxdamage
nope, set everything to large and still the same thing. The realy confusing thing is, im not near the limit to the point that im at in the link according to the temp MAP file. It stops at "MATH_DATA", says it doesnt fit. The realy confusing thing is mathdata is like 20bytes. Any sujestions?
Unread 20-03-2004, 13:12
Linux Guy
AKA: maxdamage
Now, according the temp file, its addressing MATH_DATA to a diff spot then usual. MATH_DATA normaly(always) is mapped to 0x3f but for some reason .temp is being mapped to 0x00 and its size is 0x44. It is normaly mapped there, but its size should be 0x28. Ideas?
Unread 20-03-2004, 14:53
Linux Guy
AKA: maxdamage
amazing, the problem turned out to be very very dumb. Aparently the linker didnt like the fact that I did my taylor expansion for atan in a single line and freaked out. It, for some reason, increased the size of .tempwhatever and didnt have room for the rest. Its amazing how crappy this compilier is!
Unread 20-03-2004, 19:02
Programming User
Yeah.
Glad you figured it out. See you at the Buckeye!
Unread 20-03-2004, 21:20
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
If you really needed to expand the memory, you can try editing the linker script (Make a back-up copy, though!). I would just add a section called "ExtraRoom" and having addresses from 0xF00400 to 0xFFFFFF. That should be big enough. But don't load any code you compile that way! And tell me how it goes, I'm mostly guessing.
What size monitor do you use? Elgin Clock IT / Communications 30 10-03-2004 16:53
My file size is too big..... JamesWu 3D Animation and Competition 20 20-02-2004 22:31
Size limitations of 2X Yellow Ball John Larock Kit & Additional Hardware 9 15-01-2004 12:55
Is there a size regulation for the pit area if we wanted to put up a banner Ragin_Kage General Forum 6 14-03-2002 15:33
wheel limitations Greg Needel Technical Discussion 1 15-01-2002 16:37
