Go to Post There can never be enough recognition of a job well done. We can never say enough Thank You's. We can never measure the impact that an inspirational teacher or mentor can make on a student because it's priceless. - KathieK [more]
Unread 20-03-2004, 23:06
dddriveman's Avatar
dddriveman dddriveman is offline
Former Driver 1038, 979
AKA: Driveman
FRC #1038 (Thunderhawks)
dddriveman has a spectacular aura aboutdddriveman has a spectacular aura about
Send a message via AIM to dddriveman
One last question about our code
WE got our code from kevin.org this year. When we run our final copy of the autonomous code the recievers move back and forth on our servos to find the beacons since i do not have the beacons i am not sure if it then switchs back to the navigate part of the program or just stops and says sensor 1 found . The thing that i want to know the most is why doe our sensors move back and forth when we are in normal mode but when we are in autonomous they stop and no other functions seem to happen like our navigate code. Also the default is included in the assembly file but it does not seem to work in our normal mode. Any help will be gladly accepted
"I'm sorry, after all he is just a wookie!"
Unread 20-03-2004, 23:20
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: One last question about our code
You could e-mail or PM Kevin himself and I bet he'd get you a good answer real fast.
Unread 20-03-2004, 23:54
Kevin Karan's Avatar
Kevin Karan Kevin Karan is offline
Linux Guy
AKA: maxdamage
None #0174 (Arctic Warriors)
Kevin Karan will become famous soon enoughKevin Karan will become famous soon enough
Send a message via AIM to Kevin Karan
make sure whatevers in process_data_from_local_IO is being called durring autonomous mode
It isnt ALWAYS the programmers falt!
2004: Buckeye team website award
2002: Rutgers semi-finalists
2001: National semi-finalists
2001: Rutgers semi-finalists
1998: Manchester Rookie All-Star Award
Unread 21-03-2004, 12:34
dddriveman's Avatar
AKA: Driveman
i don't know how to do that
Unread 21-03-2004, 14:38
warpspeed warpspeed is offline
#0038 (Nonnebots)
warpspeed is on a distinguished road
underneath the "//add autonomus code here"
put
"Process_Data_From_Local_IO();"
then move your tracker code to the process_data_from_local_IO function at the end of the file.
Or you can call the tracker function from where ever it is. Like if the tracker code is named Track_Beacon(void). Then under process_data_from_local_IO put "Track_Beacon();"
that shuold take care of it.
void User_Autonomus_Code();
//add code here
pwm01 = pwm02 = 254;
(Broke_Bot == 1) ? (Turn_And_Run = 1) : (Smile_And_Nod = 1);
Unread 22-03-2004, 09:49
dddriveman's Avatar
AKA: Driveman
Thanx i'll try that.
Interrupt timer, executing code asap? SeanCassidy Programming 10 07-03-2004 01:47
Need interupts help, and another question... Kevin Karan Programming 7 22-02-2004 11:20
navigate and default code newbie question alan koch Programming 2 17-02-2004 22:25
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
