how are we going to do this
This is what we have for our automous code but we want to go from the Navigate(); to what is beneath it when both of the sensors see nothing becuase we don't want to risk loseing all of that time.
void User_Autonomous_Code(void) { while (autonomous_mode) /* DO NOT CHANGE! */ { if (statusflag.NEW_SPI_DATA) /* 26.2ms loop area */ { Getdata(&rxdata); /* DO NOT DELETE, or you will be stuck here forever! */ /* Add your own autonomous code here. */ Navigate(); if(rc_dig_in01 ==1 ) { pwm13 = 137; pwm14=100; } else { pwm13 = pwm14 = 140; } if(rc_dig_in02 == 1) { pwm13 = 100; pwm14 = 137; } else { pwm13 = pwm14 = 140; } Generate_Pwms(pwm13,pwm14,pwm15,pwm16); Putdata(&txdata); /* DO NOT DELETE, or you will get no PWM outputs! */ } } } |
Re: how are we going to do this
Navigate();
if ( NEITHER_SENSOR_SEES )
pwm13 = 137;
pwm14=100;
else
pwm13 = 100;
pwm14 = 137;
else
You should move navigate() to before the spidata thing if you are using the old navigate routine
