Go to Post How you say something is often just as important as what you say. - Rachel Lim [more]
Unread 14-03-2004, 12:11
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: S.W.A.T. 771's Robot
Unread 14-03-2004, 12:14
Duke 13370's Avatar
Duke 13370 Duke 13370 is offline
C is for cookie...
#0862 (Team Lightning)
Team Role: Webmaster
Duke 13370 will become famous soon enough
Send a message via AIM to Duke 13370
Re: pic: S.W.A.T. 771's Robot
does the pneumatic hook thing work?!?!?
I would think it wouldn't be strong enough to hold the robot up.
---Lightning Robotics!---
Unread 14-03-2004, 12:45
trev2023's Avatar
trev2023 trev2023 is offline
None #1236 (Phoenix Rising)
trev2023 will become famous soon enough
Send a message via ICQ to trev2023 Send a message via AIM to trev2023 Send a message via MSN to trev2023 Send a message via Yahoo to trev2023
I would bet that it definitely does. The top half of the design that we used for our robot this year is almost exactly the same as this robot (with the pneumatics lifting the arm and then the 2' pneumatic extending to grab the bar), and we were able to hang pretty regularly.
Unread 14-03-2004, 14:11
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Our team's robot hangs on a 1/4" aluminum shaft which was machined from 1/2" stock. Calculate the strength and you'll find it works just fine. SWAT's hook looks more than ample for the task of hanging. I look foward to seeing them in Canada again.
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 14-03-2004, 14:15
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
The onle problem I can see is bending of the piston if pushing and shoving goes on (it did in Pittsbugh). Again I see Mildred as much improved over last year. This team has made amazing strides since year 1. Keep it up girls and I will see you at CR.
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 14-03-2004, 15:10
Vince lau's Avatar
Vince lau Vince lau is offline
Building robots since 1995
FRC #4914
Vince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond repute
Send a message via MSN to Vince lau
the robot looks good girls, your robot designs are getting better every year. see you at the Canadian regionals
Unread 21-03-2004, 23:35
Aylish771's Avatar
Aylish771 Aylish771 is offline
AC/DC
#0771 (SWAT 771)
Team Role: Driver
Aylish771 has a little shameless behaviour in the past
Send a message via ICQ to Aylish771 Send a message via MSN to Aylish771
Cool Re: pic: S.W.A.T. 771's Robot
Hey Everyone,
The piston we are using to hang has a 10 inch stroke length, and 2 inch bore. It will actually hold up to 180lbs at 60psi. When our team was trying to decide how to hang, we tried numerous methods on our robot from 2003. This piston proved most effective and surprisingly, lightest, which was a big factor for us this year.
Thanks everyone for all of the support! And yes, us girls have definately come a long way from "The Box That Rox". Can't wait to see you all at the CR!
++Aylish++
...do you know the muffin fan?
Unread 21-03-2004, 23:41
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Originally Posted by Aylish771
Hey Everyone,
it is actually less than 180 lbs because you are retracting the piston so you must subtract the area of the piston shaft. Regardless, id be afraid of bending like steve pointed out. Id be interested to know exactly how much stress that piston could take...
Team 1257
Unread 22-03-2004, 00:29
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
if i recall correctly, the retracting force of a 2-inch bore piston is about 180 lbs (as she said), while the expanding force is over 200 lbs.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 22-03-2004, 09:32
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Theoretical extension force for a 2" diameter piston at 60 psi is 188.5 pounds (force=piston surface area * pressure). The theoretical retraction force is 176.7 pounds (piston surface area during retraction is reduced by the area of the piston rod). In reality, both of these numbers are slightly reduced due to friction in the system and minute amounts of blow-by around the seals. But the total available force is still more than sufficient to lift a 130 pound robot (unless you have really whaled away at the piston rod and bent it [note to certain team members - pistons are NOT hammers!], in which case you will never lift anything ).
-dave
Unread 22-03-2004, 11:04
Aylish771's Avatar
AC/DC
#0771 (SWAT 771)
Team Role: Driver
Thanks for clearing that up guys, as long as it can lift >130lbs S.W.A.T. is happy!
++Aylish++
Unread 22-03-2004, 16:45
Ilyushin269's Avatar
Ilyushin269 Ilyushin269 is offline
MORT Driver
AKA: Blake K.
#0011 (MORT)
Team Role: Driver
Ilyushin269 is an unknown quantity at this point
Send a message via AIM to Ilyushin269 Send a message via MSN to Ilyushin269
Team 11 is using 2 cylenders with an 8 inch stroke..... Easily can lift 200-250 lbs... as we showed when lifting ourselves and Team 25 at Chesapeake.
"If you are going through hell, keep going" Winston Churchill
Unread 28-03-2004, 08:24
Berserker's Avatar
Berserker Berserker is offline
FRC #0011 (MORT)
Berserker is an unknown quantity at this point
Send a message via AIM to Berserker Send a message via MSN to Berserker Send a message via Yahoo to Berserker
and us and 237 at the jersey regional
pic: Robot? What Robot? CD47-Bot Robot Showcase 13 10-04-2004 07:08
pic: 294's First Inventor Robot (pic 1)... CD47-Bot Robot Showcase 4 10-03-2004 19:34
pic: Closeup of the robot hanging on robot CD47-Bot Extra Discussion 16 09-03-2004 18:27
team 25 robot pic nuggetsyl Robot Showcase 12 21-02-2004 00:57
XCats - robot pic on our website archiver 2001 0 24-06-2002 01:06
