Go to Post Eating at Pappy's is the only St Louis activity for me. - Cory [more]
Unread 21-03-2004, 18:55
Robohawk-master's Avatar
Robohawk-master Robohawk-master is offline
AKA: Barry
#1109 (Robohawks)
Team Role: Operator
Robohawk-master is on a distinguished road
Help with automonous mode
Hello,
I have no experience in prgramming (yet I'm a programmer) and I'd like some help on how to create a simple automonous mode using the line sensors to follow the white line and hit the T (..knocking over the ball). Nothing has been changed from the code so if someone could email a whole new code that would be the best. Though I don't have a talent now in prog, I can do photoshop so i can help someone there...
18 days till we leave for competition
- Barry -
-2004 Canadian Regional Semi-Finalists
-2004 Bruce Power Safety Award
Unread 21-03-2004, 21:08
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Help with automonous mode
Originally Posted by Robohawk-master
Hello,
Sorry, I can't (and won't) write your code, but I can describe the ideas to you for you to code. I assume you know C and how to use it for this. If not, ask a neiboring team for help.
There are plenty of threads of how to follow a line. Search for "Line Following".
Unread 22-03-2004, 09:39
CrashZero's Avatar
CrashZero CrashZero is offline
Computer Nerd
#1352 (Huskie Robotics)
CrashZero will become famous soon enoughCrashZero will become famous soon enough
Exclamation Re: Help with automonous mode
I won't write your code for you either but I will give you an example of how you *could* have your bot follow a line;
if(rc_dig_in01 ==1 )//if one sensor sees it
pwm13 = 137;
pwm14=100;
else//if this sensor doesn't see it
pwm13 = pwm14 = 140;
if(rc_dig_in02 == 1)//if the other sensor sees it
pwm13 = 100;
pwm14 = 137;
else
pwm13 = pwm14 = 140;//If this sensor doesn't see it
since I just did that off the top of my head there are probebly a few errors in it but if you can;t even fix a few then you need more help then I am willing to give.
I don't know how well this will work becuase personally I think that following the beacon is a better choice.
Just one last time this **may** NOT work even after you fix the errors but it is still an example.
Hope this helps!!!
This is our world now... the world of the electron and the switch, the beauty of the baud. We make use of a service already existing without paying for what could be dirt-cheap if it wasn't run by profiteering gluttons, and you call us criminals. We explore... and you call us criminals. We seek after knowledge... and you call us criminals. We exist without skin color, without nationality, without religious bias... and you call us criminals. You build atomic bombs, you wage wars, you murder, cheat, and lie to us and try to make us believe it's for our own good, yet we're the criminals. Yes, I am a criminal. My crime is that of curiosity. My crime is that of judging people by what they say and think, not what they look like. My crime is that of outsmarting you, something that you will never forgive me for. I am a hacker, and this is my manifesto. You may stop me, but you can't stop us all...
quote from:
+++ The Mentor +++
Unread 22-03-2004, 17:51
AKA: Barry
#1109 (Robohawks)
Team Role: Operator
Thanks a lot, I really did not know where to start, that was exactly what I needed
- Barry -
Unread 23-03-2004, 15:39
CrashZero's Avatar
Computer Nerd
Thumbs up Re: Help with automonous mode
Glad that I could be of some assistence
quote from:
+++ The Mentor +++
Unread 23-03-2004, 16:18
Tom Saxton's Avatar
Tom Saxton Tom Saxton is offline
no team (Issaquah Robotics Society)
Tom Saxton has much to be proud ofTom Saxton has much to be proud ofTom Saxton has much to be proud ofTom Saxton has much to be proud ofTom Saxton has much to be proud ofTom Saxton has much to be proud ofTom Saxton has much to be proud ofTom Saxton has much to be proud ofTom Saxton has much to be proud ofTom Saxton has much to be proud of
Although line following is simple in theory, getting it to work and have the robot run at a speed that will get you to the tee in the 15 seconds is pretty challenging. We ignored the advice of experienced teams and tried doing it with custom analog sensors using a proven algorithm, and we had to eventually abandon it.
Using digital sensors, your robot will jerk back and forth as it goes down the line, greatly slowing it down. This can be solved with analog sensors and applying speed corrections proportional to the difference in sensor readings. This can work much better, yielding very smooth, fast driving. But getting that to work requires careful tuning.
However, your lines sensors need to be far enough in front of your drive wheels that the sensors tell you how much you need to turn, not how much you needed to turn 10 cycles ago.
My advice is to do dead reckoning unless you have very experienced programmers, analog line sensors and good separation between the sensor and the steering wheels.
Tom Saxton
http://www.idleloop.com/
Unread 23-03-2004, 18:11
AKA: Barry
#1109 (Robohawks)
Team Role: Operator
I realize the difficulty. This is our second year, so nothing is trusted on. We decided on line sensors because we knew how well they worked last year (good, but the bot had faulty fuses...). Heck they're even the same ones. We took into account where to place them, how close (last years sensors actually have a 5-10 ft advantage over this years banners.
- Barry -
Future of Autonomous Mode FadyS. Programming 41 24-05-2004 19:45
pwms 13 and 15 in autonomous mode Chris Bright Programming 1 24-02-2004 22:25
Initializing autonomous mode Mr. Lim Programming 7 02-02-2004 07:26
Programming Autonomous mode Jared Stofflett Programming 3 11-11-2003 09:32
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
