Go to Post After each match the pit crew gathers up the parts from the field and finds a new and interesting way to assemble them. - tsaksa [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > You Make The Call
View Poll Results: You Make The Call
I award Bluabot 50 points for hanging 19 79.17%
I award Redabot 50 points for hanging 9 37.50%
I do not award Bluabot any points for hanging 4 16.67%
I do not award Redabot any points for hanging 12 50.00%
I disable Redabot while Redabot is tugging on Bluabot 1 4.17%
I do something else ... please explain 3 12.50%
Multiple Choice Poll. Voters: 24. You may not vote on this poll
Unread 22-03-2004, 23:44
Natchez Natchez is offline
#0118 (Robonauts)
Natchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond reputeNatchez has a reputation beyond repute
YMTC: Bluabot and Redabot hanging?
You Make The Call (YMTC) is a series of situations where you can play ref and make a call. YMTC situations are not meant to represent situations that have occurred at competitions.
During a qualifying match, Bluabot amazes the crowd by hanging on the bar during the first 5 seconds of the match. With 15 seconds remaining, Redabot reaches for the bar and Redabot's hook lands directly on top of the Bluabot hook. While hoisting itself up, Redabot pulls Bluabot all the way to the end of the bar where the Bluabot hook is touching the fitting connecting the vertical support and horizontal bar. At the end of the match, both Bluabot and Redabot are both off of the ground and both inside the vertical supports BUT Redabot's hook is not touching the bar. If you were to dissolve Bluabot with the, now-patented, Magical Bot-Disappearing Potion (MBDP), Redabot's hook would drop about 1 inch and rest nicely on the bar and Redabot would remain hanging.
YOU MAKE THE CALL! Do you ...
(please note that you can choose multiple options with this YMTC)
Please base your ruling on the 2004 rules. If you find a specific rule that addresses this situation, please share it with everyone.
Unread 23-03-2004, 00:19
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: YMTC: Bluabot and Redabot hanging?
I love this thread.. It's my new favorite thread.
HANGING is defined as DIRECTLY SUPPORTED by the bar.
I give Bluabot the 50 points, but deny Redabot the 50 pts, because Redabot is INDIRECTLY SUPPORTED by the bar by hanging on Blueabot.
Sounds familiar, in UTC this past weekend we were Blueabot and we lost cause of a mysterious new rule that I believe the refs. made up that says if Blueabot is removed and Redabot would fall straight down on the bar, then they are hanging. If anyone saw this as an official rule, I would really like to know where it is.
I would really like to see this scenario adressed in the FIRST Q&A Forums.
Unread 23-03-2004, 00:20
10intheCrunch's Avatar
10intheCrunch 10intheCrunch is offline
Who's John V-Neun?
AKA: Alex Baxter
None #0254 (Cheesy Poofs)
10intheCrunch is a jewel in the rough10intheCrunch is a jewel in the rough10intheCrunch is a jewel in the rough10intheCrunch is a jewel in the rough
Send a message via AIM to 10intheCrunch
The definition of SUPPORTED: if the "supporting" object were removed...the robot would not remaing HANGING.
and HANGING: A robot is considered hanging if it is directly supported by the horizontal bar and not touching the carpet, platform or goals.
This seems pretty cut and dry to me...Red is not supported by Blue, as the removal of Blue would mean that Red was still hanging. I don't buy the argument that touching the vertical bar means you aren't hanging--the vertical bar doesn't "support" the robot in any way (the horiz bar has to move inside the vertical to at least some degree, so lets say that the vertical par is just a force field...Blue is hanging).
So I voted "something else" because I award both teams 50 points for hanging.
edit: in response to "directly hanging" disqualifying Red, I believe that the definition of supported takes precedence over directly...I don't understand why FIRST would put that word in other than to give lawyers something to feast on, but if the presence of Blue's hook did not assist in Red's ascent, it in no way disqualifies Red.
~Alex Baxter
Programming, Arms operation, Team 254
Unread 23-03-2004, 00:30
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
This is fairly simple:
Blue Robot gets 50pts. for Hanging.
Red Robot gets 0pts. for hanging. Red Robot must be supported by the chin up bar itself and must not have any contact that would LOOK like the red robot is being supported by another robot.
As for a specific rule I'm trying to locate
Definition of Hanging: A Robot Is Considered Hanging from the pull up bar if it is directly supported by the horizontal bar and its not touching the carpet, platforms or goals
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 23-03-2004, 00:32
Thank you Thank You Thank You!!!!!!!!!!!!
Definition of hanging is DIRECTLY, not INDIRECTLY SUPPORTED by the bar.
Those words are good enough for me.
Unread 23-03-2004, 00:33
ggoldman's Avatar
ggoldman ggoldman is offline
FRC #0401
ggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud of
Send a message via AIM to ggoldman
According to a very reliable source:
The robot touching the fitting would not count. If the lower robot was removed and the upper robot would be hanging, it would count.
Therefore, I would not award the lower bot points. I would give 50 to the upper one.
Gabe Goldman
Unread 23-03-2004, 00:36
Who's John V-Neun?
AKA: Alex Baxter
This seems to have been discretionary at regionals. Referees at Arizona called robots touching the fitting not-hanging, but I haven't heard of this happening at other regionals. But as this is a You Make the Call thread, please post what you think should be the call, based on the rules and your judgment...I really would like to hear people's reasons for not calling Blue hanging .
~Alex Baxter
Unread 23-03-2004, 00:38
mtaman02's Avatar
Gabe Goldman
if the lower robot is touching a part of the chin up bar that classifies itself not hanging 0 points for the lower robot and the robot which is hanging on the already illegal robot well he gets 0 b/c he's not touching the bar.
I was not going to lean towards this but this should have been an issue at some of the already now past regionals
At the J&J Mid-Atlantic Regionals towards the end of the match 3 robots hung 2 of which had enough of clearence between any parts of the chin up bar that could be considered illegal. As for the 3rd robot well he was hanging on his opposing alliances robot and the points he tried to obtain were now void all b/c he was touching the bar.
The question I have now is same situation except if the robot is hanging on another robot can he deploy a "second Hook" to either side of where he is already at (we'll say about 2" to either side) and is cleared from touchin any illegal parts. And the way the second hook grabs the bar makes it look like the robot is being supported by the second hook and not the first. Question is would this be illegal or legal You be the judge another twist to this partiuclar YMTC.
I just want to say Kuddos to Natchez for coming up with this this would be an excellent test for those wanting to referee next year Thanks again!
Volunteer Resume:
Unread 23-03-2004, 00:57
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
maybe im not grasping it all the way...
but at BAE, 319(highway bob) hung in all their matches...although to hang they got the corner of the bar, touching the pole, and the fittings...although they were not supported by the bar or fittings, would this still be annulled?
i voted for not giving the 50 pts to the redabot... at the end of the match, is the end of the match...if the robot is ontop of another robot/s appendage, and the match is called...thats it...no more second tries...
its like playing hockey...say you have the puck... once the buzzer rings, thats THE END...you dont finish your drive to see if you score or not...
think logically folks
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 23-03-2004, 01:03
ggoldman's Avatar
FRC #0401
It does not have to touch the bar. If you were to remove the lower robot with a vaporation gun or what not, the top robot would have been touching the bar and hanging. I would have called it fair.
Unless they were both on the same team...
-Gabe
Unread 23-03-2004, 01:07
-Gabe
But, if this is true. Can anyone at all please point out in the rule book where it says this specifically?? Can you do that??? Anyone? Anyone at all??
I really need to know this.
Unread 23-03-2004, 01:15
George1902's Avatar
George1902 George1902 is offline
It's a SPAM thing...
AKA: George1083; George180
FRC #0180 (SPAM)
George1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond reputeGeorge1902 has a reputation beyond repute
I say neither bot gets the points.
If the vertical bar and its fitting are keeping Bluabot's hook on the bar as you imply here,
Originally Posted by Natchez
Redabot pulls Bluabot all the way to the end of the bar where the Bluabot hook is touching the fitting between the vertical and horizontal bars.
then Bluabot's hook would have slid off the horizontal bar if the vertical wasn't there. This would have to be disallowed.
Redabot is directly supported by Bluabot, not the horizontal bar; therefore, I would also disallow these points.
I hope their alliance partners were ball bots of some kind! This looks to be a low scoring match otherwise. ;-]
George
"Darkness cannot drive out darkness; only light can do that. Hate cannot drive out hate; only love can do that."
-- Martin Luther King, Jr.
Unread 23-03-2004, 01:16
ggoldman's Avatar
FRC #0401
I would check the updates, cause I knew an issue came up like this while I was reffing. I am definate about touching the connector though, that doesnt count (if that is the way it has been called during the matches).
Basically, when you get down to it, as long as it is called consistantly throughout all the matches, it is an even playing field, and therefore fair. But also, this assumes that no rules are broken in the rulebook by doing this.
-Gabe
Unread 23-03-2004, 01:28
-Gabe
Although I would tend to agree with this if you were only at 1 event, this leaves you disillusioned as far as the rules are concerened if you attend multiple events where the refs will more than likely be different people, and the rule here - fragile as it is - will be called two different ways. Therefore, NOT GOOD!!
Unread 23-03-2004, 01:32
ggoldman's Avatar
FRC #0401
I have attended two events thus far, and I have found that the way the head refs call things are very similar to each other. This is due partly to a conference call that ALL head refs participated in, making sure all were set on the rules.
I am sure that at the Championships, all the refs will be on the same level (I hope) therefore ensuring a level field on all the fields.
The thing you have to remember is that the refs are not professionals, and most of them did not go through a 6 week build period memorizing all the rules. As long as they are as fair as they can be to all the teams at thier event, i'd say it passes in my book.
But then again...rules are rules...
aggh...it is a tough topic
-Gabe
YMTC: Bluabot dies while pinning Natchez You Make The Call 17 21-03-2004 11:33
