| View Poll Results: You Make The Call | |||
| I award Bluabot 50 points for hanging |
19 | 79.17% |
| I award Redabot 50 points for hanging |
9 | 37.50% |
| I do not award Bluabot any points for hanging |
4 | 16.67% |
| I do not award Redabot any points for hanging |
12 | 50.00% |
| I disable Redabot while Redabot is tugging on Bluabot |
1 | 4.17% |
| I do something else ... please explain |
3 | 12.50% |
| Multiple Choice Poll. Voters: 24. You may not vote on this poll | |||
Re: YMTC: Bluabot and Redabot hanging?
I really need to know this. |
I would check the updates, cause I knew an issue came up like this while I was reffing. I am definate about touching the connector though, that doesnt count (if that is the way it has been called during the matches).
Basically, when you get down to it, as long as it is called consistantly throughout all the matches, it is an even playing field, and therefore fair. But also, this assumes that no rules are broken in the rulebook by doing this. -Gabe |
I have attended two events thus far, and I have found that the way the head refs call things are very similar to each other. This is due partly to a conference call that ALL head refs participated in, making sure all were set on the rules.
I am sure that at the Championships, all the refs will be on the same level (I hope) therefore ensuring a level field on all the fields. The thing you have to remember is that the refs are not professionals, and most of them did not go through a 6 week build period memorizing all the rules. As long as they are as fair as they can be to all the teams at thier event, i'd say it passes in my book. But then again...rules are rules... aggh...it is a tough topic -Gabe |
ok did some checking and i know d.lavery is lirking near by so maybe he can lend a helping hand.
I know hes around I can smell KK from where i'm sitting. the only thing I found was the Definition of hanging. There is a rule for constituting how the robot is counted by hanging. I checked Section 4 which hosts the game rules and Section 7 which is the tournament rules and neither sections have a set rule unless I'm missing something Maybe a person like Dave knows where this can be found. ![]() Last edited by mtaman02 : 03-23-2004 at 02:19 AM. |
| YMTC: Bluabot dies while pinning | Natchez | You Make The Call | 17 | 03-21-2004 11:33 AM |
