Go to Post Where's the "drill enough weight holes so we're barely under 120lbs" option? ;-) - AlecMataloni [more]
Unread 22-03-2004, 20:04
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Routine declaration syntax error (Or: Where's wlado?)
Here's a stumper:
char Autonomous_1 (char State) // <---Right Here!
The error is a syntax error. It is the only error in the listing, and it is at that line. I have removed 1 or 2 routines, and still get it.
Unread 22-03-2004, 20:10
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Re: Routine declaration syntax error (Or: Where's wlado?)
That looks OK on cursory examination. What comes right before that line? Is it possible you have unmatched braces?
Unread 22-03-2004, 20:12
fred's Avatar
fred fred is offline
More Grizzle
None #0341 (Daisy)
fred is on a distinguished road
a lot of times, it will give you a syntax error and the real error will be 10 lines up from the little green arrow.
"The distance between genius and insanity is measured only by success."
-Anonymous
AKA: Jamie Bliss
#include "printf_lib.h"
* FUNCTION NAME: PrintRamString
* PURPOSE:       Run 1 loop for autonomous mode 1
* CALLED FROM:   anywhere
* ARGUMENTS:
*     Input: char State - What is the state of atuonomous
* RETURNS:       char - is it finished?
Unread 22-03-2004, 20:14
AKA: Jamie Bliss
The only thing above it is comments and #includes
Unread 22-03-2004, 20:25
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
Have you modified printf_lib.h?
Unread 22-03-2004, 20:33
AKA: Jamie Bliss
Some. Mostly just a #endif at the end.
Unread 22-03-2004, 20:43
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
I added
* ARGUMENTS:
right after a #include of our stock printf_lib.h. No error. How about if you post your printf_lib.h?
Unread 22-03-2004, 20:46
AKA: Jamie Bliss
* FILE NAME: printf_lib.h
* DESCRIPTION:
*  This is the include file which corresponds to printf_lib.c
* USAGE:
*  If you add your own routines to that file, this is a good place
*  to add function prototypes.
#ifndef __printf_lib_h_
#define __printf_lib_h_
int printf(rom const char *format, ...);
void printid(int data,int crtOn);
void printb(unsigned char data,int crtOn);
void printd(unsigned char data,int crtOn);
void printix(int data,int crtOn);
void printx(unsigned char data,int crtOn);
void debug_print(char *bufr,int data);
void debug_printb(char *bufr,unsigned int data);
void debug_println(char *bufr);
#endif
Commenting out the last few declares don't help.
Unread 22-03-2004, 21:07
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
Well, you might be right. I'm still stumped. You didn't do something weird like #defining char, Autonomous_1 or State, did you? (Or parentheses or underscores, taking a lesson from those obfuscated C samples posted elsewhere?)
Unread 23-03-2004, 06:00
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
I'm stumped too...
Unread 23-03-2004, 11:30
Since you have an #ifdef/#endif protecting your printf_lib.h from being included multiple times, I suspect the problem is being caused by the line(s) before that #include. Post a bit more context, and look at the other included files for unmatched parentheses or braces or even missing semicolons.
Unread 23-03-2004, 11:46
AKA: Jamie Bliss
Re: Routine declaration syntax error (Or: Where's waldo?)
After 3 of us working on 4 computers last night to get it to compile, we got it to compile. There were various similar problems throughout the new stuff. I have to ask: Is there a limit on the number af function prototypes in a file?
Unread 23-03-2004, 12:27
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
Possible. How many did you have?
Unread 23-03-2004, 22:04
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Is there some reason why you can't use the stock printf lib if it works? If you can't, try remodifying it one change at a time to see what it is.
