Go to Post Mentors need to be sure that the team is on track to have a working robot ready. Students can do almost everything, but they need help watching the calender. Even if your ideas turn out bad, if your robot is inspectable and running when you arrive at your first event, anything can happen. - AcesPease [more]
Unread 09-03-2004, 21:39
FRC #0701 (RoboVikes)
Re: Slickest drive transmission yet...
They are all different........most of the shifting ones i've seen have 2 sets of gears and a pneumatic slides an input gear into one gear and out of the other, one that we built a while ago based on Technokats had dogs which catch on to the gears and engage them...the gears are on bearings so they don't do anything without a dog...
its kinda hard 2 explain...check out some pics and you will understand
Team 701
Unread 10-03-2004, 17:18
Paul H's Avatar
Paul H Paul H is offline
Renegade of Funk
AKA: Paul Huston
FRC #0033 (Killer Bees)
Paul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant future
Send a message via AIM to Paul H
Sam, I know that some teams shift the drill transmission with servos, and to the best of my knowledge, these cannot be shifted on the fly.
-Paul
Unread 10-03-2004, 17:23
Paul H's Avatar
Renegade of Funk
AKA: Paul Huston
Originally Posted by sanddrag
Is there a picture of the real thing? That would serve us both better than me asking a bunch of questions. Thanks.
Raul posted a picture.
-Paul
Unread 11-03-2004, 03:06
Dima Dima is offline
Dima is just really niceDima is just really niceDima is just really niceDima is just really niceDima is just really nice
Send a message via AIM to Dima
Very Nice, Very simple. The best part is definaly making it automatic. It is something new and refreshing so to speak. Very cool that you guys actually took time to calculate the power curves and shift at the right points, props to you guys!
Except for Chief Delphi this year apperantly
Unread 11-03-2004, 03:49
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
I really must say that this is an awesome system. Congrats to team 33.
I've thought of automatic transmissions for a couple seasons now, and I never thought of monitoring output RPM. In my theoretical designs for an automatic transmission, I would have monitored current to the motor, and shift based on that information. At different gear ratios, the stall current of the motor is constant, and if you set upper and lower thresholds, you can shift up or down, depending completely on whether you need less or more pushing power, respectively. I'm sure it's more complicated than I'm making it sound, but as I said, I'm stuck in the realm of theory, here.
Just my take on the theory of an automatic transmission. With all of the talk of constructive vs. destructive criticism that went on recently, I want to say that I'm very impressed by this system. Again, many congratulations to 33.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 11-03-2004, 04:57
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Originally Posted by dlavery
Thank you very much for the kind words. Working with the team to design that transmission was a lot of fun, and we learned a lot!
-dave
BTW, Dave and the rest of the crew over on Team 116, here is our version of your designed gearbox and tranny!
http://www.pbase.com/image/26818929
Unread 21-03-2004, 11:25
Mike K Mike K is offline
Battery Boy
#0033 (Killer Bees)
Team Role: Student
Mike K is on a distinguished road
Send a message via AIM to Mike K
Just Remember to Use Hard Metal!!!!
Unread 21-03-2004, 12:53
Paul H's Avatar
Renegade of Funk
AKA: Paul Huston
Hardened Steel is what he means. We ground down our high gear on one gearbox in Detroit.
-Paul
Unread 21-03-2004, 13:33
matt111 matt111 is offline
#1024 (McKenzie Kilabytes)
matt111 will become famous soon enough
well our team, 1024, design a CVT VST (continious velocity, torque, variable speed transmission). it uses bevel gears and three planetary gear systems. then we ran into the problem: it was gonna weigh around 30 lbs!!! so i was told to design a casing to replace the alumnium box it was going in (around half the weighht). well we ran out of time, but i did get a nifty looking case made from a FDM prototyping machine. Hopefully (crosses fingers) we will have it done at IRI. we had two allision transmission engineers helping us design, so hopefully we can have something to show for my 10+ straight weeks of doing CAD for this. and yes i did start in the offseason..and yes it is still not done
Unread 21-03-2004, 21:20
Ryan F.'s Avatar
Ryan F. Ryan F. is offline
Ryan F. is a jewel in the roughRyan F. is a jewel in the roughRyan F. is a jewel in the rough
Question Re: Slickest drive transmission yet...
I was wondering if I could get some peoples opinion over weather a variable speed/torque transmission is a big advantage, or a lot of work for nothing. Our team has a CIM/Drill motor combo for our drivetrain, with no special shifting gearbox, and we seem to have pleanty of speed and torque.
Unread 21-03-2004, 21:52
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
Programming the robot to shift really shouldn't be too complicated, with encoders measuring the speed of the output shaft or the axles. Especially since they calculated the power curves and everything. With the power curves, they can determine the best shift point to gain the most power. Finding the shift points is the hard part. Then you prgram it to shift when the encoders measure a certain speed determined by you to be your shift point. You can also calculate downshift points as well the same way.
See you in DC!
Unread 21-03-2004, 21:58
jimfortytwo jimfortytwo is offline
AKA: Jim Paulos
#0418 (Purple Haze)
Team Role: Student
jimfortytwo is just really nicejimfortytwo is just really nicejimfortytwo is just really nicejimfortytwo is just really nicejimfortytwo is just really nice
Send a message via ICQ to jimfortytwo Send a message via AIM to jimfortytwo Send a message via Yahoo to jimfortytwo
rforystek:
That might be a debate for a different thread. To answer your question, though this thread from last summer contained some good debate on that topic (4 motor vs. shifters). The fourth page of replies in particular is well worth a look.
http://chiefdelphi.com/forums/showth...g+motor+debate
Unread 22-03-2004, 00:11
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
team 151's drive this year was awesome as well... they designed the system with simplicity in mind, as well as sleek and compactness as well..
a far shot, but their tranny are smaller than the aluminum tubing
they made a new gearbox for the drills using the previous planetary gears, and made a new housing...it was gorgeous...they also implemented the pneumatic shifting, and ran the pneumatic shifter inside the drive shafts to save space...tthis thing was gorgeous...
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 22-03-2004, 22:30
Apparently I got bad rep point for showing Gracious Professionalism and "hijacking this thread" to thank a team for their gearbox design we used this year.
If any one wants the name of this person who is against Gracious Professionalism and against thanking other teams, PM me.
Unread 23-03-2004, 19:07
Gus Gus is offline
Gus is an unknown quantity at this point
Originally Posted by Jim Zondag
Thanks, I'm glad everyone likes our design.
We have made two speed transmissions for the past several years. Each year we try to make them simpler and smaller. I found that with the kind of high/low shift range that I like to have (3:1 or more) that the robot would tend to lurch severely if you downshifted at high speeds. I really want to make a 3 speed with an intermediate gear to help this. It turned out it was easier to build a 4 speed than a 3 speed ( its really two small two-speeds in series). We focused the design around reliablity and ease of construction, the demo unit on display was made entirely by high school students in a few evenings using no special tooling.
Once I had a design with 4 gears I was pretty much forced to automate the shifting in order to keep from overloading the driver. I talked with a few Automatic Transmission experts at DaimlerChrysler on how to do a shift scheduler and viola....a fully automatic electronic robot transmission.
It really is pretty neat, providing a nearly flat power output across a very wide RPM band with a 5:1 total shift span.
I plan on posting the design and engineering here as soon as I get a good set of drawings made up (I'm not a CAD guy, I made the ones in the robot from a napkin sketch).
Would it be possible to get a drawing or photo's of this transmission. It sounds perfect. Thanks Gus
Shifting Gears MBosompra Technical Discussion 71 23-07-2004 02:49
1 stick drive to 2 stick drive wayne 05 Programming 18 01-04-2004 16:41
White Paper Discuss: Dual-motor, dual-speed drive transmission design CD47-Bot Extra Discussion 9 03-09-2003 10:40
how does crab drive work? Soukup Technical Discussion 13 25-04-2003 11:31
Direct drive or Chain? Suneet Technical Discussion 32 27-03-2003 23:00
