Go to Post I was proud that there was no whining, no finger pointing and no complaining. - Vikesrock [more]
Go Back   Chief Delphi > Technical > IT / Communications > Computer Graphics
Unread 17-03-2004, 01:31
Avarik Avarik is offline
Avarik is an unknown quantity at this point
How do you upload an analog video onto a computer?
Hello, I am making a video for a school project, and I was wondering how to upload the analog video from my camera (Sony Handycam CCD-TRV308 NTSC) to my computer? I have adobe premiere to edit it there, just need to get it there
Any help would be much appreciated.
Unread 17-03-2004, 07:45
Re: How do you upload an analog video onto a computer?
That's a Hi8 camcorder, so you're right about needing to capture analog video. The way to do it is with analog video capture hardware. You'll need either an external box or an internal card with analog video inputs. Such things come with software and instructions, and can cost between 50 and 500 dollars depending on quality and features.
It would be easiest for you to find a friend who has a computer with video capture capability. If you can't do that, visit a local computer store and see if you can find someone who understands what you want to do, and can recommend an appropriate solution.
Unread 18-03-2004, 00:19
Thank you very much!
Unread 18-03-2004, 01:15
evulish's Avatar
evulish evulish is offline
1010100
AKA: Grant Harding
#0084 (WATTNESS (bot: Chuck))
evulish is just really niceevulish is just really niceevulish is just really niceevulish is just really nice
Send a message via AIM to evulish
To list some products, an ATI All-in-Wonder card would do it, or a Hauppage WinTV (which won't be too great.. not really what they're made for), any of the products made by Pinnacle should be good. I'd recommend something like http://www.newegg.com/app/ViewProduc...144-019&depa=0 . That's probably the best bang for the buck. You can spend alot more, but those are pretty decent.
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
Unread 23-03-2004, 21:28
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
If you are getting an All-in-Wonder for a PC, stay away from the pre-Radeon models. They tend to have very little driver support, and are quite a pain to work with under both Windows and Linux.
At one time, I needed to transfer video from a camcorder to a PC and an adapter was not available. I used someone's digital camcorder and focused its lens on the viewfinder of the analog camcorder. The video quality was poor, but usable, so if you need to do this very cheaply....
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
Unread 23-03-2004, 21:30
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
my brain is all fuzzy right now and I can't think clearly, but if your camera has an ieee port (firewire) then you could always buy a firewire card at a local store. That is what i did for a school report a while back, just plug in the firewire and go to file: capture : movie capture in premiere then select ieee cable.
[edit] Now that i actually think about it, thats for digital video. bleh. I have an All-in-Wonder for that [/edit]
Unread 23-03-2004, 21:36
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Another thing that hasn't been mentioned yet are Dazzle products.
My brother has the exact same camcorder and uses a Dazzle 80 with it. It's basically just an input for your video out cables from your camcorder. It connects via USB. It works with both Composite and S-Video outputs as well as stereo sound. Overall it works pretty well, and the quality is decent for importing analog video. It also works great for importing video from VCRs and other video devices. I've even used it to capture video from my Playstation 2 (worked great). Plug it in and play/record at the same time.
Purdue Alumni
Cummins, Inc.
Unread 23-03-2004, 21:48
D.J. Fluck
Posts: n/a
I purchased a TV tuner card for 50 bucks and hooked a VCR up to it. I now can digitize tapes, plug a camcorder into it and digitize, or whatever....that works too especially if you have VHS tapes you want to digitize...oh yeah and i can watch cable TV on my computer
Unread 24-03-2004, 11:57
Collin Fultz's Avatar
Collin Fultz Collin Fultz is offline
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
a Matrox analog converter works very well...especially with Adobe Premier. I've been using them together through high school and while I've had some problems (mainly slow computer stuff though) it works very well.
Collin Fultz
Unread 06-04-2004, 23:42
iamnafets iamnafets is offline
Meh?
AKA: Stefan Mai
None #0624 (CRyptonite Robotics)
iamnafets is on a distinguished road
You get what you pay for, I originally had a TV Wonder from ATI but wasn't satisfied with the subpar quality. A USB solution may be an option, but I would avoid it because of the poor quality due to lack of bandwidth. 11megabits per second sounds like a lot but really isnt. I eventually went with an all in wonder radeon 8500 which works like a charm, the video out is really nice to to record onto VHS. I can make some pretty sexy stuff just gotta tweak the capture settings to get it just right between compression strain on the processor and the max load your hdd can take down. If at all possible, I highly recommend the ati all in wonder series especially since the cards that accompany the vivo capability are sexy for gaming.
Cryptonite Robotics Team 624
http://www.cryptoniterobotics.com
If it's down, someone needs to buy me a UPS and tell the thunderstorms to stop crashing my server.
Unread 07-04-2004, 08:41
FizMan's Avatar
FizMan FizMan is offline
aboot, eh?
AKA: Chris Sinclair
#0783 (Mobotics)
FizMan will become famous soon enough
Send a message via AIM to FizMan Send a message via MSN to FizMan
What kind of quality loss do you get on a USB capture device? I'm going to be picking up one soon...
I'm using a DV Camera, so would the quality loss be comparable to going down to hi8? Do you get a lot of dropped frames using the USB?
Unread 30-12-2004, 21:04
stevek's Avatar
stevek stevek is offline
AKA: Master of the Sweatshop
FRC #0230 (GaelHawks)
stevek has a spectacular aura aboutstevek has a spectacular aura aboutstevek has a spectacular aura about
Another solution that may not cost you a dime. I assume if you have edit software you have a capture card, so if your asking this question, you're card is DV. If you have that you may have or can barrow a Digital Camera (Digital-8, Mini-DV or what ever has DV I/O on it) YOu can typically connect the output from one camera to the input of the other (assuming you have the cables for both Cameras, you can use barrels (Female-Female coupler adapter or patch it through a VCR) This is taking Analog out of Cam 1 to Analog In on DV Camera. Then you will have a Tape that you can feed into your computer via Firewire. NOTE: Some DV Cameras don't allow Analog In for Recording, so you have to try it and see. If it doesn't work borrow another!
If this works for you, great. I've used this to tranfer from VHS Tapes to get into an edit- prior to buying an Analog-DV Convertor. Now I use a AVID Mojo that has both Analog and DV I/O. But both of these methods cost money, while the above method is Free of Charge if you can get your hands on the Equipment.
Unread 30-12-2004, 21:42
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Pinnacle
I prefer Pinnacle because the editing software is really easy to work with and also I got the Studio AV/DV http://www.pinnaclesys.com/ProductPa...50&Langue_ID=7
It's really easy to install the card into your computer and if I'm correct, also has a 4-6 pin firewire cable - 30 bucks, the software - 80 bucks, and the card is also analog video imput, the yellow one, and firewire, has 2 ports of each -30 bucks, and I got that at Costco for only 80 bucks, I think good deal, but you still need to find a way to import the sound, but it also includes the RCA adapter - Dont know how much, to change the red and white wire into the stereo plug ins for connecting it into a microphone port in your computer. I see it as a good deal because getting everything seperate can run you up to about...150 bucks including tax or somewhere around there.
And good luck with your project
GizMOE Revealed - NEW VIDEO from team 365!! SuperJake Robot Showcase 14 25-03-2004 22:35
Projection TV's and Video Inputs (Xbox, Computer) MattK Chit-Chat 9 31-01-2003 00:53
List of UTC Hartford Teams archiver 2001 3 24-06-2002 01:09
Good video footage miketwalker General Forum 0 28-03-2002 17:14
A&E Special Amadkow Chit-Chat 4 11-08-2001 00:40
