Go to Post The biggest fallacy in FIRST is the belief we are just a bunch of different teams. We are ONE BIG TEAM with a lot of sub teams for the purpose of competition. - Al Skierkiewicz [more]
Go Back   Chief Delphi > Technical > IT / Communications > Computer Graphics
Unread 23-03-2004, 21:36
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Re: How do you upload an analog video onto a computer?
Another thing that hasn't been mentioned yet are Dazzle products.
My brother has the exact same camcorder and uses a Dazzle 80 with it. It's basically just an input for your video out cables from your camcorder. It connects via USB. It works with both Composite and S-Video outputs as well as stereo sound. Overall it works pretty well, and the quality is decent for importing analog video. It also works great for importing video from VCRs and other video devices. I've even used it to capture video from my Playstation 2 (worked great). Plug it in and play/record at the same time.
Purdue Alumni
Cummins, Inc.
Unread 23-03-2004, 21:48
D.J. Fluck
Posts: n/a
I purchased a TV tuner card for 50 bucks and hooked a VCR up to it. I now can digitize tapes, plug a camcorder into it and digitize, or whatever....that works too especially if you have VHS tapes you want to digitize...oh yeah and i can watch cable TV on my computer
Unread 24-03-2004, 11:57
Collin Fultz's Avatar
Collin Fultz Collin Fultz is offline
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
a Matrox analog converter works very well...especially with Adobe Premier. I've been using them together through high school and while I've had some problems (mainly slow computer stuff though) it works very well.
Collin Fultz
Unread 06-04-2004, 23:42
iamnafets iamnafets is offline
Meh?
AKA: Stefan Mai
None #0624 (CRyptonite Robotics)
iamnafets is on a distinguished road
You get what you pay for, I originally had a TV Wonder from ATI but wasn't satisfied with the subpar quality. A USB solution may be an option, but I would avoid it because of the poor quality due to lack of bandwidth. 11megabits per second sounds like a lot but really isnt. I eventually went with an all in wonder radeon 8500 which works like a charm, the video out is really nice to to record onto VHS. I can make some pretty sexy stuff just gotta tweak the capture settings to get it just right between compression strain on the processor and the max load your hdd can take down. If at all possible, I highly recommend the ati all in wonder series especially since the cards that accompany the vivo capability are sexy for gaming.
Cryptonite Robotics Team 624
http://www.cryptoniterobotics.com
If it's down, someone needs to buy me a UPS and tell the thunderstorms to stop crashing my server.
Unread 07-04-2004, 08:41
FizMan's Avatar
FizMan FizMan is offline
aboot, eh?
AKA: Chris Sinclair
#0783 (Mobotics)
FizMan will become famous soon enough
Send a message via AIM to FizMan Send a message via MSN to FizMan
What kind of quality loss do you get on a USB capture device? I'm going to be picking up one soon...
I'm using a DV Camera, so would the quality loss be comparable to going down to hi8? Do you get a lot of dropped frames using the USB?
Unread 30-12-2004, 21:04
stevek's Avatar
stevek stevek is offline
AKA: Master of the Sweatshop
FRC #0230 (GaelHawks)
stevek has a spectacular aura aboutstevek has a spectacular aura aboutstevek has a spectacular aura about
Another solution that may not cost you a dime. I assume if you have edit software you have a capture card, so if your asking this question, you're card is DV. If you have that you may have or can barrow a Digital Camera (Digital-8, Mini-DV or what ever has DV I/O on it) YOu can typically connect the output from one camera to the input of the other (assuming you have the cables for both Cameras, you can use barrels (Female-Female coupler adapter or patch it through a VCR) This is taking Analog out of Cam 1 to Analog In on DV Camera. Then you will have a Tape that you can feed into your computer via Firewire. NOTE: Some DV Cameras don't allow Analog In for Recording, so you have to try it and see. If it doesn't work borrow another!
If this works for you, great. I've used this to tranfer from VHS Tapes to get into an edit- prior to buying an Analog-DV Convertor. Now I use a AVID Mojo that has both Analog and DV I/O. But both of these methods cost money, while the above method is Free of Charge if you can get your hands on the Equipment.
Unread 30-12-2004, 21:42
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Pinnacle
I prefer Pinnacle because the editing software is really easy to work with and also I got the Studio AV/DV http://www.pinnaclesys.com/ProductPa...50&Langue_ID=7
It's really easy to install the card into your computer and if I'm correct, also has a 4-6 pin firewire cable - 30 bucks, the software - 80 bucks, and the card is also analog video imput, the yellow one, and firewire, has 2 ports of each -30 bucks, and I got that at Costco for only 80 bucks, I think good deal, but you still need to find a way to import the sound, but it also includes the RCA adapter - Dont know how much, to change the red and white wire into the stereo plug ins for connecting it into a microphone port in your computer. I see it as a good deal because getting everything seperate can run you up to about...150 bucks including tax or somewhere around there.
And good luck with your project
GizMOE Revealed - NEW VIDEO from team 365!! SuperJake Robot Showcase 14 25-03-2004 22:35
Projection TV's and Video Inputs (Xbox, Computer) MattK Chit-Chat 9 31-01-2003 00:53
List of UTC Hartford Teams archiver 2001 3 24-06-2002 01:09
Good video footage miketwalker General Forum 0 28-03-2002 17:14
A&E Special Amadkow Chit-Chat 4 11-08-2001 00:40
