Go to Post I'd like to thank FIRST for giving me this wonderful opportunity. I've learned so much! - Leav [more]
Unread 03-03-2004, 09:23
ranma_saotome20's Avatar
ranma_saotome20 ranma_saotome20 is offline
AKA: Richard
#0842
Team Role: Animator
ranma_saotome20 has a little shameless behaviour in the past
Send a message via ICQ to ranma_saotome20 Send a message via AIM to ranma_saotome20 Send a message via Yahoo to ranma_saotome20
finalizing
I hope this isn't a repeat thread. And if it is feel free to hit me over the head. I need to know how to do final rendering and how to stitch the segments together. I haven't the foggiest idea how to do it.
Unread 03-03-2004, 10:27
ThetaDot's Avatar
ThetaDot ThetaDot is offline
here come the warm jets
#1481
Team Role: Animator
ThetaDot can only hope to improve
Re: finalizing
I don't know exactly what the situation is. Do you have different scene files and just need to render them and connect them together?
Anyway to start rendering (and i'm assuming you're using max) You have to to just go into the render scene dialogue and select the bubble to render the entire time segment, and then down below that you have to click "FILE" (or something like that - you can find it) to specify how you will save it. You need to choose a movie file... you can either choose AVI or MOV, depending on what your editing software can handle.
If you have several different scenes, you need to render each out seperately and then import them all into an editing program (Windows Movie Maker, for example) and stitch them together. If you need a program I think you can download Windows Movie Maker from the microsoft website - you have to find it.
I have no idea if I just helped at all. I get home at 4:00pm EST (noon your time I think) and if nobody else has helped or you are still having trouble than post here or message me (aim = clcThetaDot)
word
Unread 03-03-2004, 18:15
rowe rowe is offline
Eric Rowe
FRC #1097 (Site 3 Engineering)
rowe has a spectacular aura aboutrowe has a spectacular aura about
Send a message via AIM to rowe Send a message via MSN to rowe Send a message via Yahoo to rowe
Re: finalizing
ive found that rendering a targa sequence where each frame is saved as a picture, as part of a movie (test0000.tga, test0001.tga, etc) works well because you can easily edit a single frame if need be, and it is lossless in terms of quality. u will still need to peice the scenes together in another program.
Eric Rowe | Alumn
Team 1097 | Site 3 Engineering
2005 Silicon Valley Regional Finalists
2005 Silicon Valley Regional Sportsmanship Award
2005 Sacramento Regional Finalists
2005 Sacramento Regional Sportsmanship Award
2004 Silicon Valley Regional Sportsmanship Award
2004 Sacramento Regional Visualization Award
2004 Sacramento Regional Engineering Inspiration Award
Unread 03-03-2004, 20:47
ThetaDot's Avatar
#1481
Team Role: Animator
Re: finalizing
I couldn't imagine importing hundreds and hundreds of individual picture files into a program. I sure don't have the program to do something like that.
Unread 03-03-2004, 21:56
Eric Rowe
Re: finalizing
i know for a fact that both adobe after effects and premier can import them because thats how we did this years video. ive also read that you can render a targa sequence and then using 3ds max, assemble a movie from that without actually rendering. this is useful if you want to put together a movie in different formats, but dont have an ouside program. it does take a fair amount of harddrive space (2-3 gigs for 30 secs) but so does rendering a movie uncompressed.
Eric Rowe | Alumn
Unread 03-03-2004, 23:17
Matt Hallock Matt Hallock is offline
#1188 (Oaktown Crewz)
Matt Hallock is on a distinguished road
Send a message via ICQ to Matt Hallock Send a message via AIM to Matt Hallock Send a message via Yahoo to Matt Hallock
Re: finalizing
Why would you abuse size and render to targa? JPG would do just fine, and you don't need .PNG unless you feel like editing 200 frames of alpha channels.
Lead Animator for Donder-Kimball High School, team #1188.
Unread 03-03-2004, 23:37
rrockafellow rrockafellow is offline
rrockafellow is an unknown quantity at this point
Re: finalizing
If your going to do any network rendering you have to render as hundreds of sequential images. It certainly is the preferred method of rendering out animations. You can start and stop your renderings and not have to rerender all of the frames over again. Also Really useful when you start to create layered composites.
Importing sequential images is easy and not the loborious process that it sounds. Programs like Adobe Premiere and After effects are able to import a whole image sequence at once.
3ds max's video Post would be another way of putting clips, multiple camera sequences or seqential images together if you were real desperate. Its not a user interface friendly editing environment and not really able to mix in audio.
Unread 05-03-2004, 09:54
AKA: Richard
#0842
Team Role: Animator
Re: finalizing
Thanks guys (or girls as the case might be). I'll try that next week. I won't have a chance this week. I'll get back letting you know if it works. <crossses fingers>
Unread 05-03-2004, 11:43
AKA: Richard
#0842
Team Role: Animator
Re: finalizing
Ok, I was able to work on it today. But now I'm having troubles with something about an output device. Do you know what the h*ll it's talking about? Reply when you can. Thanks.
Unread 06-03-2004, 00:55
Eric Rowe
Re: finalizing
yeah, i tried using video post the other day (im assuming thats what ur talkin bout) and you need to add an output device to ur queue (its a box wit the arrow pointing out of it and down) name the file, set up the parameters (codec, etc) an then hit the execute sequece button to finish it. im pretty sure thats how its done, but ive only done it once, so i might b wrong or forgetting a step.
Eric Rowe | Alumn
Unread 07-03-2004, 19:21
AKA: Richard
#0842
Team Role: Animator
Re: finalizing
I tried that. It said there were no output devices. I have no idea what is going on.
Unread 23-03-2004, 09:10
AKA: Richard
#0842
Team Role: Animator
Re: finalizing
Ok, this is just an update. I figured it out. Thank you to all that helped.
Unread 23-03-2004, 22:32
Brian(1) Brian(1) is offline
Brian(1) is an unknown quantity at this point
Send a message via ICQ to Brian(1)
Re: finalizing
Its pretty easy to use a series of tga files, even in max..
Theres a Utility called IFI Manager.. or something similar in the utilites area of 3ds max.. What it does is create a textfile with the names of all the tga files in that sequence.. Meaning you can do some cool effects by editing the file.
But you make that list, and you can use that as an input file in Video Post, which you can then choose to output to whatever format you want.
