Go to Post You only get one first post. ;) - gvarndell [more]
Unread 23-03-2004, 23:18
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: not quite sure...speed controller...spike.
This may or may not be related, but i have found that lots of joystick buttons seem to flicker IE not giving a constant stream of 1's when they are being pressed. Our code now checks the button over the period of 3 or 4 frames to make sure its really pressed. This is probably a good idea for a winch button anyway, you wouldnt want it accidentally pressed.
Team 1257
Unread 23-03-2004, 23:23
255 is not a valid output for pwms (victors) - it can make the communcation between your code and the layer above it lose synch
254 is the max you should ever output
that might be why your victor wacked out
or it could be it wasnt calibrated correctly - if you are certain you are sending it 127 and the motor is still trying to move, then it either needs to be recalibrated, or its not working correctly.
to answer your original question, it says in the robot section of the manual which motors you can use with spikes - Im almost certain a window motor would be ok.
Unread 23-03-2004, 23:52
wow! im impressed that you discovered that by yourself!
Its called 'switch bounce' - when you close a switch or pushbutton it takes about a 1/10th of a second for it to make solid contact - the surfaces actually do bounce a tiny bit - so if a fast microprocessor is polling the switch it will see it go 00001101010011110111111011111111111
and your timing is right - 3 frames is about a 100 mS
nice catch!
Unread 24-03-2004, 05:37
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
I will add that, in our code we had values of 255 being output and weird things were happening. I chnaged it after I saw something on here and the problem went away. At the same time I also changed something else, so it may be a coincidence though.
Speed Controller brake/coast setting steven114 Electrical 21 03-03-2004 13:05
How do you connect the speed controller fans? Iain Electrical 7 31-01-2003 07:05
Speed controller fan replacement Rickertsen2 Electrical 11 16-01-2003 08:46
Speed Controller Limits yaman Technical Discussion 11 15-01-2003 18:40
making speed controller digital CharlieWilken Electrical 4 01-03-2002 20:15
