Go to Post FRC is a game of mentors. The best teams are guided by mentors who know how to balance on the knife edge of pushing the envelope and achieving success. - Mr. Van [more]
Unread 13-03-2004, 22:41
Joe P Joe P is offline
Joe P will become famous soon enoughJoe P will become famous soon enough
Drawing #35 Chain
Does anyone know how to draw a chain around sprockets in Autodesk Inventor?
Unread 16-03-2004, 12:15
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
Re: Drawing #35 Chain
You'll probably need to draw the chain as an assembly then constrain the rollers to the sproket. If you look around you may be able to find a model you can download. If it were me, I would look up the chain pitch and roller diameter and fudge it.
Greg
Unread 23-03-2004, 23:19
tophq's Avatar
tophq tophq is offline
mastr of autodsk (or not)
AKA: Chris Payk
#0703 (Inferno)
tophq is an unknown quantity at this point
i did just the same only with treads. it's a real slow file to work with on the school computers but it's the only way i can see doing it.
Unread 23-03-2004, 23:27
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
You have the model that precise? Can you rotate your sprockets, too?
Team 1257
Unread 24-03-2004, 11:45
Is there a program out there I can download and make a chain ??
Unread 24-03-2004, 17:48
Daniel Brim's Avatar
Daniel Brim Daniel Brim is offline
It's hard hat time here in Boston
AKA: DFB
FRC #0125 (NUTRONS)
Daniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond repute
Send a message via AIM to Daniel Brim
http://www.cbliss.com/inventor/Parts/PowerTransmission/
The chain is a set of I-parts and is labeled:
3 Different styles of ANSI chain links. Includes multi row links #25 to #240
28 Links, 28 Connector Links and 28 offset links
2003 (2002) - 2006 -- Team 294, Beach Cities Robotics
2007 (2006) - Present -- Team 125, NUTRONS
Unread 24-03-2004, 20:46
Crebb's Avatar
Crebb Crebb is offline
AKA: James M.
FRC #5279 (Bionic Eagles)
Crebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud of
I found an ipart of a chain and tried to assemble it in inventor. It took about 20 minutes to make about a foot's worth of chain. It also made the computer run very very slow. Instead of using chain I just made a rotational constraint between the 2 sprockets that the chain would have gone between. It may not look as realistic, but it works.
Shibuya Hoppmann, Mechanical Engineer
VCU School of Engineering 2012
Team 5279 2016-Present
Team 384 2003-2015
Unread 03-04-2004, 12:33
psychoCHIPMUNKK's Avatar
psychoCHIPMUNKK psychoCHIPMUNKK is offline
Technical Manager
#0241 (Last Minute Fix)
Team Role: Driver
psychoCHIPMUNKK has a little shameless behaviour in the past
Send a message via AIM to psychoCHIPMUNKK Send a message via Yahoo to psychoCHIPMUNKK
How would you constrain the chain to the sprockets so that it runs as it should in real life when you're driving the constraints?
Team 241
Unread 03-04-2004, 20:56
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
Smart-aleck answer: with great difficulty!
Mentor answer: Maybe someone smarter than I has gotten this to work, but I have yet to get more than three links to follow a constrained path around two sprockets. But, since three links can do it, I feel that it should be possible to do a whole loop of links. The links were constrained to each other by their pivot pin centerlines and mated on one side plate.
To control the motion, I used a common Inventor motion animation cheat: I created a surface which is the path that is tangent to the inside of the link rollers as they contact the sprockets and move between them - kind of like if you stretched a rubberband around the chain path. I then used a tangent constraint to "hold" the link rollers to the path.
I'll try to remember to post the files on Streamline next week, in case anyone wants to drive themselves crazy trying to make it work with more links.
Pete Kieselbach
Unread 16-04-2004, 22:36
Pat Roche Pat Roche is offline
Mechanical Engineer
FRC #0134 (Team Discovery)
Pat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to beholdPat Roche is a splendid one to behold
Send a message via AIM to Pat Roche
I did something similar also...setting a rotational constraint based on the ratio of the two sprockets. With out the program(other computer) infront of me i couldnt tell you how i did it. Basically it demonstrated the sprocket/ratios effect on the final output.
-Pat
Team Discovery #134 Alumni 1999-2004
Division by Zero #229 Alumni 2004-2009
Team Discovery again?
2010 and Beyond
Where have the last 11 years have gone?
Globe motor dimension drawing jskene Motors 0 15-02-2004 13:34
chain ridding up and off sprocket problem... davidhoare Technical Discussion 4 04-02-2004 10:13
25 or 35 chain? Alan Ing Technical Discussion 24 02-03-2003 13:56
1/4" chain and links from small parts archiver 2001 2 24-06-2002 00:18
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
