Go to Post If I can do it, it's not art. - Ether [more]
Unread 23-03-2004, 19:50
Kevin Karan's Avatar
Kevin Karan Kevin Karan is offline
Linux Guy
AKA: maxdamage
None #0174 (Arctic Warriors)
Kevin Karan will become famous soon enoughKevin Karan will become famous soon enough
Send a message via AIM to Kevin Karan
digital input question...
Alright, feeling stupid. I know that the digial inputs give wierd junk since they are char variables. So what bit do I read and how. Thanks
It isnt ALWAYS the programmers falt!
2004: Buckeye team website award
2002: Rutgers semi-finalists
2001: National semi-finalists
2001: Rutgers semi-finalists
1998: Manchester Rookie All-Star Award
Unread 23-03-2004, 20:21
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: digital input question...
If you just want to tell if it is HIGH or LOW, you can do a check if it is 1 or 0. If for some reason you have to actually access the bits, experiment. I'm not sure if the chip is big- or little-endie.
Unread 23-03-2004, 20:25
Linux Guy
AKA: maxdamage
The digital inputs are given as a char, but only one of the bits are actualy accurate, but I dont know what one. I know there is a post on this forum about it, but I cannot find it. AND, i cant remember how to get the value of a specific bit under c, is it var:1 or is it var&1
Unread 23-03-2004, 21:27
the digital inputs on the RC are already defined in the code for you - they can only have a value of 1 or 0
all you need to do is look at the right variable
rc_dig_in01 is digital input one on the RC
so you can do stuff like
if (rc_dig_in01 ==1) variableXYZ=123;
if (rc_dig_in14 ==0) variableQRS=127;
what else do you want to do with them?
Unread 24-03-2004, 05:57
Programming User
Looking back at my old post, I meant that, but I see how you didn't get it. You can't access a certain bit in a variable in an actual function. The first syntax you stecified can be used in a struct like this:
stuct bitVariable
int bit0:1;
int bit1:1;
int bit2:1;
int bit3:1;
Basically, tht gives each of the variables inside it one bit of the int. (at least, I think I got that right... ) Like Ken said though, you can just read the variable directly.
Unread 24-03-2004, 10:38
10intheCrunch's Avatar
10intheCrunch 10intheCrunch is offline
Who's John V-Neun?
AKA: Alex Baxter
None #0254 (Cheesy Poofs)
10intheCrunch is a jewel in the rough10intheCrunch is a jewel in the rough10intheCrunch is a jewel in the rough10intheCrunch is a jewel in the rough
Send a message via AIM to 10intheCrunch
I'm pretty sure you can, if they are set up in a struct together. Say:
if(SomeStructbits.bit0) blah;
If you only want to see the first bit of any variable, though, use modulus.
if(someVar % 2) morestufftodo;
If you aren't familiar with modulus, it gives the remainder of dividing by the number you mod by, ie modding by 2 gives you one or zero depending on if the number is even or odd (or rather, if the first bit is 1 or 0).
Good luck.
~Alex Baxter
Programming, Arms operation, Team 254
Unread 24-03-2004, 10:50
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
If you want the 2 least significant bits, wouldn't it make more sense to do:
if(someVar & 3) evenmorestufftodo;
Unread 08-04-2004, 14:35
That is what I would do, becasue the modulus operator is often slow (of course depending on the microprocessor). I haven't checked on the PIC, but if you ever want to move your code to a different platform, it's best to write for the lowest common denominator.
Sorry for bringing this thread up from the dead.
Unread 11-04-2004, 22:42
Linux Guy
AKA: maxdamage
sorry for not being at all active on my threads lately... at buckeye I came up with something that worked well, though I cant remember it...
Unread 12-04-2004, 07:34
AKA: Jamie Bliss
I HATE that!
counting digital input CharlieWilken Programming 9 22-03-2004 19:56
Digital In Question Tom Bottiglieri Control System 5 02-03-2004 17:09
Question about input pins. Tom Bottiglieri Programming 3 15-02-2004 15:12
How do u hook up the digital input to the sensor's wires Fares Technical Discussion 2 14-02-2003 16:41
Robot Digital Input Mike Norton Technical Discussion 5 16-01-2003 14:31
